| | My entire system hangs every 3 to 4 minutes I'm wondering if this has been addressed elsewhere. In nay case, just upgraded to Vista. Now every 3 or 4 minutes, my entire system just freeezes for about 30 seconds. I'm afraid I'm not very savvy, but I know this much: Dell E520, upgraded from XP, running Home Premium, system supports Aero glass, Radeon 1300 video card, 2 gigs RAM, 110 gigs free ona 140 gig hard drive, typically low CPU usage (don't run a lot of apps) I basically just surf the Net. This is very frustrating. Is there a patch out there somehwere? Is it a driver issue. I'd be happy to post any and all information about my system if you would find it helpful. Thanks for any and all input. |
| | Re: My entire system hangs every 3 to 4 minutes Upgrade from XP - Did you perform the "Prep" work beforehand ? Since the "Freeze" happens at a fixed interval, I would download & run SysInternals Process Explorer. You can start it, log data and at the freeze point examine the log to find the process that is taking all the system resources. Indexing is a controversial aspect of Windows and can sometimes affect performance until it's data is built. I'm not saying that's your root cause but it's possible. It's a search feature that few users make use of or are aware of it's capabilities. Process Explorer's home page found here: http://www.microsoft.com/technet/sys...sExplorer.mspx "IndyBill66" <IndyBill66@discussions.microsoft.com> wrote in message news:7BFF652B-791D-41CE-AE8B-DE4B902D9258@microsoft.com... > I'm wondering if this has been addressed elsewhere. In nay case, just > upgraded to Vista. Now every 3 or 4 minutes, my entire system just > freeezes > for about 30 seconds. I'm afraid I'm not very savvy, but I know this > much: > > Dell E520, upgraded from XP, running Home Premium, system supports Aero > glass, Radeon 1300 video card, 2 gigs RAM, 110 gigs free ona 140 gig hard > drive, typically low CPU usage (don't run a lot of apps) > > I basically just surf the Net. This is very frustrating. Is there a > patch > out there somehwere? Is it a driver issue. I'd be happy to post any and > all > information about my system if you would find it helpful. Thanks for any > and > all input. |
| VISTA hangs 20 Minutes, LanmanServer starting | General Discussion | |||
| Vista hangs after 2-10 minutes of operation | Vista General | |||
| Computer hangs at startup ... for 5 minutes!! | Vista performance & maintenance | |||
| Reading defective CDs sometimes hangs the entire Windows | Vista General | |||
| RC1 installs ok but hangs after 2 minutes | Vista installation & setup | |||
