| | Links To replace Show desktop Icon Does Not work |
| | Re: Links To replace Show desktop Icon Does Not work Did you rename the file extension from .txt to .scf as the instructions say to do? -- Maxwell Bluemeanie ---- "Vistagurl" <Vistagurl@discussions.microsoft.com> wrote in message news:920C8626-7192-49B4-8DC4-95BD1EE7CE8E@microsoft.com... > http://support.microsoft.com/kb/q190355/ > all it does is make a notepad icon Please help! |
| | Re: Links To replace Show desktop Icon Does Not work Yes I did "Max" wrote: > Did you rename the file extension from .txt to .scf as the instructions say > to do? > > -- > Maxwell Bluemeanie > ---- > "Vistagurl" <Vistagurl@discussions.microsoft.com> wrote in message > news:920C8626-7192-49B4-8DC4-95BD1EE7CE8E@microsoft.com... > > http://support.microsoft.com/kb/q190355/ > > all it does is make a notepad icon Please help! > > |
| | Re: Links To replace Show desktop Icon Does Not work In Vista, Show Desktop.scf is not used. Rather, go to C:\Users\Default\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch and Copy the Show Desktop shortcut file. Paste it into C:\Users\(YOUR NAME)\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch "Vistagurl" <Vistagurl@discussions.microsoft.com> wrote in message news:920C8626-7192-49B4-8DC4-95BD1EE7CE8E@microsoft.com... > http://support.microsoft.com/kb/q190355/ > all it does is make a notepad icon Please help! |
| | Re: Links To replace Show desktop Icon Does Not work Thanks! I did it! but its not the same icon . but Il live hehe "dean-dean" wrote: > In Vista, Show Desktop.scf is not used. Rather, go to > > C:\Users\Default\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch > > and Copy the Show Desktop shortcut file. Paste it into > > C:\Users\(YOUR NAME)\AppData\Roaming\Microsoft\Internet Explorer\Quick > Launch > > > > > "Vistagurl" <Vistagurl@discussions.microsoft.com> wrote in message > news:920C8626-7192-49B4-8DC4-95BD1EE7CE8E@microsoft.com... > > http://support.microsoft.com/kb/q190355/ > > all it does is make a notepad icon Please help! > > |
| | #6 (permalink) |
| | Re: Links To replace Show desktop Icon Does Not work Right-click on the icon and choose Properties, then click on change icon. It should take you to %SystemRoot%\system32\imageres.dll. Choose the appropriate icon (OK, APPLY, OK). "Vistagurl" <Vistagurl@discussions.microsoft.com> wrote in message news:AE32DD2E-602A-41DE-A796-E2AE92E09EB8@microsoft.com... > Thanks! I did it! but its not the same icon . but Il live hehe > > "dean-dean" wrote: > >> In Vista, Show Desktop.scf is not used. Rather, go to >> >> C:\Users\Default\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch >> >> and Copy the Show Desktop shortcut file. Paste it into >> >> C:\Users\(YOUR NAME)\AppData\Roaming\Microsoft\Internet Explorer\Quick >> Launch >> >> >> >> >> "Vistagurl" <Vistagurl@discussions.microsoft.com> wrote in message >> news:920C8626-7192-49B4-8DC4-95BD1EE7CE8E@microsoft.com... >> > http://support.microsoft.com/kb/q190355/ >> > all it does is make a notepad icon Please help! >> >> |
| | #7 (permalink) |
| | Worked like a charm! Thank you! My Show Desktop icon recently disappeared and I had rebuilt it with the text file but the icon was old-style. This method restored the icon as well. Thank you so much! If you are still curious about the issue you were having with the file appearing as a text file, I am guessing that the problem you are having with the icon is that perhaps your folder settings do not show dot extensions for your files with known application mappings. So the file would still a .txt file just with .scf in the name first. Open a windows explorer window, press the alt key, choose Folder Options from the tools menu, click the view tab. If Hide Extensions for Knwon File Types is checked, uncheck it. The file now may end in .txt. I don't know about others, but I always leave mine showing extensions. EggHeadCafe.com - .NET Developer Portal of Choice http://www.eggheadcafe.com |
| Show Desktop Icon | Vista General | |||
| IE7 Desktop Icon Won't Show | Vista General | |||
| Desktop Icon Text - Hide or Show | Tutorials | |||
| adding show the desktop icon to quick launch | Vista General | |||
