Vista - Sleep Problems help ???
Old 03-12-2007   #1 (permalink)
skull791
My sleep function was working fine on my vista computer. Now I can manually
put it to sleep but it will not sleep by its self. Check settings everything
looks fine. Any ideas anyone ???
Old 03-18-2007   #2 (permalink)
Lou
Vista Will Not Idle To Sleep
In the Control Panel's Power Options, change the Multimedia Settings', When Sharing Media, from Prevent Idling To Sleep to Allow Computer To Sleep (under Change Advanced Power Settings).
EggHeadCafe.com - .NET Developer Portal of Choice
http://www.eggheadcafe.com
Old 03-27-2007   #3 (permalink)
ken
vista will not idle
thank you for that answer, was having same problem, not sure why it happened
Sleep problems Vista General
Sleep Problems Vista performance & maintenance
Sleep Problems General Discussion
Problems with Sleep... Vista General
