| | Help Lost my sidebar After install, i clicked on the windows sidebar and it dissapeared. since then i havent been able to find it, it is not minimised, and when i turn it on in controll panell it doesnt appear. however if i increase my screen resolution to max i can see the gadgets down the bottom right hand corner not attached to the sidebar, when i attach them to the side bar they dissapear totaly. how do i get it back the way it was? -- Thanks For Coming |
| | Re: Help Lost my sidebar Right click your Taskbar > click Task Manager > Process (tab) > select the "sidebar.exe" process > click End Process. Restart the system, open Control Panel > launch Sidebar. -- -- Andre Windows Connected | http://www.windowsconnected.com Extended64 | http://www.extended64.com Blog | http://www.extended64.com/blogs/andre http://spaces.msn.com/members/adacosta "puzzled?user?" <puzzleduser@discussions.microsoft.com> wrote in message news:530737FC-2478-4872-B131-9AA875A25CA3@microsoft.com... > After install, i clicked on the windows sidebar and it dissapeared. since > then i havent been able to find it, it is not minimised, and when i turn > it > on in controll panell it doesnt appear. however if i increase my screen > resolution to max i can see the gadgets down the bottom right hand corner > not > attached to the sidebar, when i attach them to the side bar they dissapear > totaly. > > how do i get it back the way it was? > -- > Thanks For Coming |
| | RE: Help Lost my sidebar it's somewhere in the start menu. use the search function. "puzzled?user?" wrote: > After install, i clicked on the windows sidebar and it dissapeared. since > then i havent been able to find it, it is not minimised, and when i turn it > on in controll panell it doesnt appear. however if i increase my screen > resolution to max i can see the gadgets down the bottom right hand corner not > attached to the sidebar, when i attach them to the side bar they dissapear > totaly. > > how do i get it back the way it was? > -- > Thanks For Coming |
| | RE: Help Lost my sidebar sorry, I should have read your full post before responding. I don't know where my mind is at today. try right-clicking the sidebar icon in the system tray, and see if you can change the options there. try setting it to be "always on top of other windows". "Kip" wrote: > it's somewhere in the start menu. use the search function. > > "puzzled?user?" wrote: > > > After install, i clicked on the windows sidebar and it dissapeared. since > > then i havent been able to find it, it is not minimised, and when i turn it > > on in controll panell it doesnt appear. however if i increase my screen > > resolution to max i can see the gadgets down the bottom right hand corner not > > attached to the sidebar, when i attach them to the side bar they dissapear > > totaly. > > > > how do i get it back the way it was? > > -- > > Thanks For Coming |
| | Re: Help Lost my sidebar On the process tab cannot see sidebar.exe i need more help to find that file and correct problems "Andre Da Costa [Extended64]" wrote: > Right click your Taskbar > click Task Manager > Process (tab) > select the > "sidebar.exe" process > click End Process. Restart the system, open Control > Panel > launch Sidebar. > -- > -- > Andre > Windows Connected | http://www.windowsconnected.com > Extended64 | http://www.extended64.com > Blog | http://www.extended64.com/blogs/andre > http://spaces.msn.com/members/adacosta > > "puzzled?user?" <puzzleduser@discussions.microsoft.com> wrote in message > news:530737FC-2478-4872-B131-9AA875A25CA3@microsoft.com... > > After install, i clicked on the windows sidebar and it dissapeared. since > > then i havent been able to find it, it is not minimised, and when i turn > > it > > on in controll panell it doesnt appear. however if i increase my screen > > resolution to max i can see the gadgets down the bottom right hand corner > > not > > attached to the sidebar, when i attach them to the side bar they dissapear > > totaly. > > > > how do i get it back the way it was? > > -- > > Thanks For Coming > > > |
| lost sidebar | Vista mail | |||
| Lost sidebar | Vista General | |||
| Lost Vista Sidebar | Vista performance & maintenance | |||
| Lost Vista Sidebar | Vista General | |||
| Lost Sidebar Clock | Vista General | |||
