Vista - Problems with DVD decrypter
Old 03-15-2007   #1 (permalink)
Per
When I try to burn an ISO or IMG file with DVD DEcrypter it burns fine to
about 30% and then the buffer goes to zero for a long time before it fills
at starts burning again. Is this a problem with DVD Decrypter only?
Old 03-15-2007   #2 (permalink)
Synapse Syndrome
Re: Problems with DVD decrypter
"Per" <no@tak.dk> wrote in message
news:eU3Iv$wZHHA.4720@TK2MSFTNGP06.phx.gbl...
Try AnyDVD. That works fine in Vista. DVDShrink might so as well, and it's
free.
ss.
Old 03-15-2007   #3 (permalink)
Per
"Synapse Syndrome" <synapse@NOSPAMgomez404.elitemail.org> skrev i
meddelelsen news:lt-dnTkjrsx14mTYnZ2dnUVZ8tGqnZ2d@bt.com...
>> fills at starts burning again. Is this a problem with DVD Decrypter only?
> it's free.
eh where do you burn in AnyDVD?!? Anyway I may have solved it by upgrading
to IMGburn wich is the replacement for DVD Decrypter.
Old 04-09-2008   #4 (permalink)
jane1043
Try the following tools
Pavtube DVD Copy
It is an easy to use and powerful DVD copy tool. The program makes it
possible to copy DVD to DVD with excellent DVD copying quality.
With Pavtube DVD Copy, you own the most efficient way to create backup
copies of your DVD movie collection. These working copies allow you to
play your DVDs on home and computer DVD players every day without the
inevitable risk of getting your originals scratched or damaged. You get
disc protection with no loss of playback quality.
The program contains functions of DVD burner. So it can not only copy
DVD movie to ISO file or DVD folder and backup DVD to hard disk drive,
but also burn ISO file and DVD folder to DVDs.
Click here to download: 'Pavtube DVD Copy Software for Clone DVD, Best
Copy DVD to DVD Solution!' (http://www.pavtube.com/dvd_copy/)
DVD Shrink
DVD Shrink is a useful program to back up DVD discs. This freeware can
also be used in conjunction with a DVD burning software such as Nero to
make copies of the DVD video disc. This software supports Windows
9x/2000/XP. DVD Shrink operates in quite a similar way to DVD43 and
other decrypter programs.
Click here to download: 'dvdshrink.org: FREE Backup Solution for your
DVD movies!' (http://www.dvdshrink.org/)
DVD Decrypter
This is another software that can be used to decrypt copy-protected
DVD. Besides, DVD Decrypter can also record images to disc. The software
is free and the new release DVDDecrypter 3.5.4.0 is free for
downloading.
Click here to download:http://www.vgmcentral.com/dvddecrypter/index.htm
DVDFab HD
DVDFab HD Decrypter is a simple version of DVDFab Platinum. It copies
entire DVD movie to hard disk, and removes all the protections (CSS, RC,
RCE, APS, UOPs and Sony ARccOS) while copying. It also comes with full
HD-DVD and Blu-Ray support (Removes AACS).
Click here to download:'Fastest DVD Copy Software | Best DVD Decrypter
from DVDFab' (http://www.dvdfab.com/free.htm)
jane1043
Posted via http://www.vistaheads.com
Old 05-18-2008   #5 (permalink)
Jazz2008
Buying DVD-Video film is not as simple as buying VCD disc or Cassette,
as each DVD disc contains various icons, pointing out different
Specifications. If you muddled to purchase some DVD film, maybe it can
not play on DVD player. So it is necessary for you to learn about the
common signs on the DVD disc.
1. Sign for DVD Video
The standard DVD-Video laser disc: on each pack of DVD laser disc, you
must have seen the sign, showing the content on the DVD disc is in line
with DVD-Video standard audio-visual materials and all the function
Compliance with the definition of specifications. As long as you see the
sign, you will be sure that it is a DVD-Video laser video-audio disc,
which can play on DVD players.
2. DOLBY DIGITAL Dolby
The sign shows that the audio signal on the disc has used AC-3 encoder
processing, which allows you to enjoy the digital sound effects. DTS,
MPEG2 etc are similar with it.
3. NTSC OR PAL
Video system signs: Generally speaking, video system and the region
Restrictions usually are combined together. However, under some
circumstances, they will be separate. Commonly, there are two video
system signs, one of which, NTSC is the video output system for USA.
Europe and mainland of China use PAL system. In addition, beside these
two signs there are the appropriate region restrictions. “All” stands
for unlocking region. The number presents the region where you can enjoy
this film.
4. Subtitle
Multi-subtitle playback: the icon shows that it offers various
different subtitles on the disc. The figure among them says out the
number. However, some of DVD discs don’t use this kind of subtitle,
which requires you to take notes of the character of outside pack. After
this, you can make sure whether there is the subtitle that you what to
see.
5. Aspect ratio
Video format: If it is shown as 4:3, which says out the image has been
processed into 4:3, which is fit for playback on the traditional TV set.
If 16:9 is shown on the outside package, while you want the playback on
TV set with 4:3, you have to watch it as Letterbox or Pan & Scan mode.
Then the quality may be affected slightly.
6. RESTRICTED
The film classification: copyrighted films mostly are divided by the
Film classification system of USA, which divided the film as G, PG,
PG-13, R, NC-17 etc.
Without a doubt, these signs are very useful. Of course, when choosing
DVD disc, you should pay attention to the reality of the coverage. In
fact, the Pirated films are no more the content of the disc. For
example, some DVDs are duplicated as VCD. This won’t keep in line with
the original one. But the outside package still uses the introduction of
the authentic. These should be taken notes of.
More dvd ripper tools may be used:'Best DVD ripping software, rip DVD
to all format of video - Pavtube DVD Ripper'
(http://www.pavtube.com/dvd_ripper)
Jazz2008
Problems starting command prompt on cygwin on vista ultimate, problems not had on Win2k3SP2 Vista General
dvd decrypter Media Center
2 different vista problems. Memory dump crash and startup repair cannot fix problems Vista General
Dvd Decrypter Software
Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems Vista installation & setup
