| | ntoskrnl.exe problem with Vista beta 2? I'm having problems trying to install Vista Beta 2. I currently run WinXP32 on a SATA HDD. I'm trying to install Vista64, i downloaded the ISO from the MS site, and burned it to DVD. I then booted from the dvd and it started the "loading files" stage, but then comes up with an error about missin ntoskrnl.exe. Any ideas? I am running a 64bit CPU btw ![]() |
| Ntoskrnl.exe corrupt | Vista General | |||
| C:\ntoskrnl.exe | Windows Updates | |||
| Vista configures update and gets ntoskrnl.exe error | Windows Updates | |||
| ntoskrnl.exe: Recend Vista-updates that could have changed this fi | Vista security | |||
| ntoskrnl.exe error with Vista install? | Vista installation & setup | |||
