| | Tunneling problem I have a program that I need to use in my work that logs me into a network at the Boeing Company and allows me access to certain programs like internal email and another application. But, I am unable to get through the security fence from my Vista laptop. I have all the codes and passwords to do it from XP. I can also get into most of the other programs in what they call their "Portal." The IT guys tell me that it's because a program called "Aventail Connect SSL VPN" is not compatible with Vista. Since they also told me that a Computer Based Training program they sent me was not compatible, but I got it to work anyway, I wonder if it's possible that they are just using this as an excuse to say "We don't have any experience with Vista yet so we are not going to look at it.' Does anyone have any experience with anything like this Aventail or any other VPN program? Or, as an option, how hard is it to configure this laptop to a Dual Boot setup? They said they could give me a new copy of XP to install on this machine. Thanks, Tom |
| | Re: Tunneling problem I use two VPN product. Cisco VPN software, which they have a released version for Vista and my company's MSRA program. The MSRA uses a smartcard from Activekey to valdate me. Currently I can't get Vista to load drivers for that Smart card. According to Activekey's website support is coming. Our corporate roll out of Vista isn't expect to start until Q3'07, which is when they plan to release the new VPN software that will support Activekey's product and install correctly with Vista. You could try to do a google search to see if their is a Aventail client release for VistA, but if that doesn't pain out, you might just be stuck. "Tom Brown" <Burner2@nospam.net> wrote in message news:OzJb1z%23ZHHA.4616@TK2MSFTNGP03.phx.gbl... >I have a program that I need to use in my work that logs me into a network > at the Boeing Company and allows me access to certain programs like > internal > email and another application. But, I am unable to get through the > security > fence from my Vista laptop. I have all the codes and passwords to do it > from > XP. I can also get into most of the other programs in what they call their > "Portal." The IT guys tell me that it's because a program called > "Aventail > Connect SSL VPN" is not compatible with Vista. > > Since they also told me that a Computer Based Training program they sent > me > was not compatible, but I got it to work anyway, I wonder if it's possible > that they are just using this as an excuse to say "We don't have any > experience with Vista yet so we are not going to look at it.' > > Does anyone have any experience with anything like this Aventail or any > other VPN program? > > Or, as an option, how hard is it to configure this laptop to a Dual Boot > setup? They said they could give me a new copy of XP to install on this > machine. > > Thanks, > > Tom > |
| | Re: Tunneling problem One possible solution to consider would be to install VPC2007 and run XP and your VPN client there. Some VPN clients won't run in VPC's but I know that it is possible. "Tom Brown" <Burner2@nospam.net> wrote in message news:OzJb1z%23ZHHA.4616@TK2MSFTNGP03.phx.gbl... >I have a program that I need to use in my work that logs me into a network > at the Boeing Company and allows me access to certain programs like > internal > email and another application. But, I am unable to get through the > security > fence from my Vista laptop. I have all the codes and passwords to do it > from > XP. I can also get into most of the other programs in what they call their > "Portal." The IT guys tell me that it's because a program called > "Aventail > Connect SSL VPN" is not compatible with Vista. > > Since they also told me that a Computer Based Training program they sent > me > was not compatible, but I got it to work anyway, I wonder if it's possible > that they are just using this as an excuse to say "We don't have any > experience with Vista yet so we are not going to look at it.' > > Does anyone have any experience with anything like this Aventail or any > other VPN program? > > Or, as an option, how hard is it to configure this laptop to a Dual Boot > setup? They said they could give me a new copy of XP to install on this > machine. > > Thanks, > > Tom > |
| | Re: Tunneling problem Hello, Thank you for your experience sharing. Thanks & Regards, Ken Zhao Microsoft Online Support Microsoft Global Technical Support Center Get Secure! - www.microsoft.com/security <http://www.microsoft.com/security> ==================================================== When responding to posts, please "Reply to Group" via your newsreader so that others may learn and benefit from your issue. ==================================================== This posting is provided "AS IS" with no warranties, and confers no rights. -------------------- | From: "LaRoux" <hlx@newsgroup.nospam> | References: <OzJb1z#ZHHA.4616@TK2MSFTNGP03.phx.gbl> | Subject: Re: Tunneling problem | Date: Fri, 16 Mar 2007 12:24:37 -0500 | Lines: 37 | X-Priority: 3 | X-MSMail-Priority: Normal | X-Newsreader: Microsoft Outlook Express 6.00.2900.3028 | X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2900.3028 | X-RFC2646: Format=Flowed; Response | Message-ID: <u7yK6$#ZHHA.208@TK2MSFTNGP05.phx.gbl> | Newsgroups: microsoft.public.windows.vista.general | NNTP-Posting-Host: 216.52.180.252 | Path: TK2MSFTNGHUB02.phx.gbl!TK2MSFTNGP01.phx.gbl!TK2MSFTNGP05.phx.gbl | Xref: TK2MSFTNGHUB02.phx.gbl microsoft.public.windows.vista.general:64231 | X-Tomcat-NG: microsoft.public.windows.vista.general | | One possible solution to consider would be to install VPC2007 and run XP and | your VPN client there. Some VPN clients won't run in VPC's but I know that | it is possible. | | "Tom Brown" <Burner2@nospam.net> wrote in message | news:OzJb1z%23ZHHA.4616@TK2MSFTNGP03.phx.gbl... | >I have a program that I need to use in my work that logs me into a network | > at the Boeing Company and allows me access to certain programs like | > internal | > email and another application. But, I am unable to get through the | > security | > fence from my Vista laptop. I have all the codes and passwords to do it | > from | > XP. I can also get into most of the other programs in what they call their | > "Portal." The IT guys tell me that it's because a program called | > "Aventail | > Connect SSL VPN" is not compatible with Vista. | > | > Since they also told me that a Computer Based Training program they sent | > me | > was not compatible, but I got it to work anyway, I wonder if it's possible | > that they are just using this as an excuse to say "We don't have any | > experience with Vista yet so we are not going to look at it.' | > | > Does anyone have any experience with anything like this Aventail or any | > other VPN program? | > | > Or, as an option, how hard is it to configure this laptop to a Dual Boot | > setup? They said they could give me a new copy of XP to install on this | > machine. | > | > Thanks, | > | > Tom | > | | | |
| Problem of Tunneling HTTP-Traffic over PuTTY on Vista | Software | |||
| VPN Split tunneling | Vista networking & sharing | |||
| SSH tunneling problem | Vista General | |||
| Terredo Tunneling, etc. | Vista General | |||
| Tunneling problem | Vista General | |||
