| | Need help in printing via the old "LPT" port in Vista I am using an old DOS-based program which is very old, but very convinient for me to use. In Windows XP, I was able to get around this problem by using the following commands: Start Run CMD net use lpt1 \\violin1\brother /persistent:yes where "violin1" is the computer name and "brother" is the printer name. See the following link: http://support.microsoft.com/default...b;en-us;314499 I have also verified using the "net view \\violin1" command that "Brother" is being used as LPT1 for Printing" However, when I try to use the print command within the DOS program, nothing happens. No errors, but just sits there until I manually close the window. I am running my old DOS-based program to be compatible under Windows 95. Anyone with ideas as to why this is not working with Vista Ultimate? |
| | Re: Need help in printing via the old "LPT" port in Vista Sorry Michael, havent got an answer but could it be that your using 'old' stuff and Microsoft isn't supporting this stuff any more ? "Michael B." <mystic02removethisplease@verizon.net> wrote in message news:7uTKh.183$Sf2.25@trnddc01... >I am using an old DOS-based program which is very old, but very convinient >for me to use. In Windows XP, I was able to get around this problem by >using the following commands: > > Start > Run > CMD > net use lpt1 \\violin1\brother /persistent:yes > > where "violin1" is the computer name and "brother" is the printer name. > See the following link: > > http://support.microsoft.com/default...b;en-us;314499 > > I have also verified using the "net view \\violin1" command that "Brother" > is being used as LPT1 for Printing" > > However, when I try to use the print command within the DOS program, > nothing happens. No errors, but just sits there until I manually close > the window. I am running my old DOS-based program to be compatible under > Windows 95. > > Anyone with ideas as to why this is not working with Vista Ultimate? |
| FTP Server - "FTP Port is used" error message" | .NET General | |||
| Vista not wotking with "My Computer" or "Control Panel", "Screen Saver" | Vista General | |||
| Vista cannot find a suitable driver for a "Generic Serial" port | Vista General | |||
| Need help in printing via the old "LPT" port in Vista | Vista installation & setup | |||
| WM5 Sync with Vista "Windows Calender", "Contacts", and "Mail" | Vista General | |||
