Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Vista logon changes Dual monitor display settings
Closed Thread
Thread Tools Display Modes
Old 03-18-2007   #1 (permalink)
sgk00
Guest
I use an external monitor with my laptop for a dual monitor extended desktop.
I want the external monitor to be the primary. This is easily setup via my
video driver software, windows display settings, or third party SW like
UltrMon. The problem is at logon Windows Vista resets the display settings
to make the Laptop screen the primary display, and changes the "layout" of
the monitor locations, and sometimes the refresh rate of the external
monitor. This happens at any logon whether from system restart or a simple
logon from locking the system.
I experimented with UltraMon to see if simply forcing the display settings I
want via the StartUp menu would work. It appears the change Vista causes
happens after the services and StartUp programs load. This seems consistent
with the fact that a simple unlock logon causes the same problem.
Note: the reset occurs at the end of the logon sequence. The logon screen
itself is always positioned correctly, and the desktop is redrawn properly on
both monitors until the end of the sequence when the display is changed.
System Info: Dell XPS M1212 Laptop, NVidia Ge Force Go 7400 Adapter, Dell
2007WFP external Monitor, Windows Vista Home Premium Upgrade, all latest
drivers from Dell and MS, clean system (only OEM as delivered software with a
by the book upgrade to Vista), software passed vista compatibility checks.
Old 03-22-2007   #2 (permalink)
sgk00
Guest
RE: Vista logon changes Dual monitor display settings
I think I solved my own problem. After a second pass at selectively enabling
each service, I found that disabling "Windows Event Log" solved the
problem... at least for now.
Right click the Computer Icon, select Manage, open Services and
Applications, open the Services snap in, find "Windows Event Log", right
click "Windows Event Log", select Properties, in the dialog select Disable.
The restart.
Hope this helps others
Old 04-12-2007   #3 (permalink)
yerfttam@gmail.com
Guest
Re: Vista logon changes Dual monitor display settings
> The restart.
> "sgk00" wrote:
> > I use an externalmonitorwith my laptop for adualmonitorextended desktop.
> > I want the externalmonitorto be the primary. This is easily setup via my
> > UltrMon. The problem is at logon WindowsVistaresets the display settings
> > themonitorlocations, and sometimes the refresh rate of the external
> > want via the StartUp menu would work. It appears the changeVistacauses
> > 2007WFP externalMonitor, WindowsVistaHome Premium Upgrade, all latest
> > by the book upgrade toVista), software passedvistacompatibility checks.- Hide quoted text -
> - Show quoted text -
Found a different solution that I wanted to pass on. For me, Nvidia
has a control panel that allows you to change the monitor
configuration. It appears that Windows and NVidia were fighting over
control, and Nvidia was winning. So, I stopped changing the dual
monitor settings in Windows -- starting changing them in Nvidia, and
my problems went away.
HTH!
Old 04-20-2007   #4 (permalink)
Thomas51
Guest
I too was having the same problem with my laptop and an external
monitor. Whenever I logged in, my display settings would get all get
reset.
I tried disabling the Windows event log as suggested and that corrected
the monitor issue, but had some other unintended consequences. By
disabling the event log, the Windows Task Scheduler also becomes
disabled, thus any applications dependent on the Task Scheduler won't
run.
After further research I found the root cause of the dual monitor
problem. There is a task in the task scheduler called TMM (Microsoft
Transient Multi-Monitor Manager). I disabled this task, and all seems
to work fine now.
Hope this helps others.
Thomas
Thomas51
Thomas51's Profile: http://forums.techarena.in/member.php?userid=24828
View this thread: http://forums.techarena.in/showthread.php?t=708148
Old 06-10-2007   #5 (permalink)
Josh
Guest
Disabling TMM worked for me too, thanks a million!
But when TMM was off, it wouldn't detect if I had one plugged in when I
logged in or came out of sleep, which was helpful. So I came up with a few
modified settings of the TMM task. Basically, it tells TMM to run at log-on
and when coming out of sleep, but to turn off after a minute so it won't be
active during lock or unlocks. I still have to rearange every morning though.
Here it is.
<?xml version="1.0" encoding="UTF-16"?>
<Task version="1.2"
xmlns="http://schemas.microsoft.com/windows/2004/02/mit/task">
<RegistrationInfo>
<Source>MobilePC Display Handling</Source>
<Author>Microsoft Corporation</Author>
<Description>Microsoft Transient Multi-Monitor Manager</Description>
<URI>Microsoft\Windows\MobilePC\TMM</URI>
<SecurityDescriptor>DA;;FA;;;BA)(A;;FA;;;SY)(A;;FR;;;AU)</SecurityDescriptor>
</RegistrationInfo>
<Triggers>
<LogonTrigger id="0023ede2-0e7c-42ce-ac3a-9872e974d53f">
<ExecutionTimeLimit>PT1M</ExecutionTimeLimit>
<Enabled>true</Enabled>
<Delay>PT2S</Delay>
</LogonTrigger>
<EventTrigger id="b79242a8-a65d-434d-a58a-da06a95fa5d1">
<Subscription><QueryList><Query Id="0" Path="System"><Select
Path="System">*[System[Provider[@Name='Microsoft-Windows-Power-Troubleshooter'] and EventID=1]]</Select></Query></QueryList></Subscription>
<Delay>PT2S</Delay>
</EventTrigger>
</Triggers>
<Principals>
<Principal id="Users">
<GroupId>Authenticated Users</GroupId>
<RunLevel>LeastPrivilege</RunLevel>
</Principal>
</Principals>
<Settings>
<IdleSettings>
<Duration>PT10M</Duration>
<WaitTimeout>PT1H</WaitTimeout>
<StopOnIdleEnd>false</StopOnIdleEnd>
<RestartOnIdle>false</RestartOnIdle>
</IdleSettings>
<MultipleInstancesPolicy>Parallel</MultipleInstancesPolicy>
<DisallowStartIfOnBatteries>false</DisallowStartIfOnBatteries>
<StopIfGoingOnBatteries>false</StopIfGoingOnBatteries>
<AllowHardTerminate>true</AllowHardTerminate>
<StartWhenAvailable>true</StartWhenAvailable>
<RunOnlyIfNetworkAvailable>false</RunOnlyIfNetworkAvailable>
<AllowStartOnDemand>true</AllowStartOnDemand>
<Hidden>false</Hidden>
<RunOnlyIfIdle>false</RunOnlyIfIdle>
<WakeToRun>false</WakeToRun>
<Priority>7</Priority>
</Settings>
<Actions Context="Users">
<ComHandler>
<ClassId>{35EF4182-F900-4632-B072-8639E4478A61}</ClassId>
</ComHandler>
</Actions>
</Task>
> reset.
> run.
> to work fine now.
> Thomas
> Thomas51
Old 08-03-2007   #6 (permalink)
Sparkle
Guest
The layout problem was annoying me too, my external monitor kept defualting
to the right. I have a DELL FP1905 Monitor and noticed that the monitor
driver was defaulting to the Generic PnP driver, then realized I never
installed the driver for this monitor. Once I installed the Dell driver for
the FP1905 display (including restart, and updating the monitor layout
settings once more) it seems to work flawlessly now. Vista must save layout
settings per driver type and only resets the settings associated with the
generic driver.
Old 10-02-2007   #7 (permalink)
Nuegen
Guest
So I have removed Windows Event Log with vlite. But I still have this problem.
I can't remove TMM (Microsoft Transient Multi-Monitor Manager) because
Windows Task Scheduler is disabled, thus disabling all task schedules.
And I can't install a driver for my CT-934D monitor because they came with
no drivers. Searching didn't help.
So I ask, when is this going to be fixed?
Old 10-18-2007   #8 (permalink)
_Tux_
Guest
I found this problem to be caused by a registry setting created by the nvidia
drivers I installed.
It created a DWORD registry value in HKLM\Software\Microsoft\TMM called
UseIViewHelper and set it to 1. I renamed this key to "UseIViewHelper old",
rebooted and the problem is now gone.
When I login, the external monitor resolution stays as it should and if I
unplug it, Vista detects this and switches the laptop monitor back to be the
main desktop.
great!
Old 10-26-2007   #9 (permalink)
-kds
Guest
Do you have any idea how to do a fix for non nvidia? I have a dell w/ intel
integrated 965 and am getting truly annoyed...
Thanks!
> main desktop.
> great!
Old 10-26-2007   #10 (permalink)
MICHAEL
Guest
Have a look at this thread;
Particularly this post;
<quote>
I too was having the same problem with my laptop and an external monitor. Whenever I logged in,
my display settings would get all get reset.
I tried disabling the Windows event log as suggested and that corrected the monitor issue, but
had some other unintended consequences. By disabling the event log, the Windows Task Scheduler
also becomes disabled, thus any applications dependent on the Task Scheduler won't run.
After further research I found the root cause of the dual monitor problem. There is a task in
the task scheduler called TMM (Microsoft Transient Multi-Monitor Manager). I disabled this
task, and all seems to work fine now.
</quote>
Do not disable the Event Log, but try going into Task Scheduler and
disabling TMM (Microsoft Transient Multi-Monitor Manager).
That seems to have worked for me, too.
This has been just another very annoying Vista bug.
-Michael
* _Tux_:
> main desktop.
> great!
Closed Thread
Display Modes
Dual monitor display settings revert on startup Cal Vista General 6 06-25-2008 03:50 AM
Loosing Display Settings On Monitor Macman2007uk Vista hardware & devices 4 06-06-2008 09:03 AM
which monitor to use under display settings? bluestone Vista General 4 06-16-2007 09:09 PM
Monitor Not In Selection List in Display Settings in Vista Ultimate Maxwell Edision Vista hardware & devices 1 04-24-2007 12:37 PM
Display Settings Window appears everytime I logon Kayli Vista installation & setup 0 06-24-2006 02:19 PM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
