| | Vista system file check problems! This is maddening! I had posted a problem with png in Vista. I believe that it is causing graphic display problems with IE7. One reply suggested that I use my installation disk and run the system file check utility (sfc /scannow) to repair what may be a corrupted file. I inserted the Vista installation disk and rebooted my system, eventually the "repair" prompt menu appeared. I selected the cmd prompt which then launched the command window. I then entered sfc /scannow, and within a few seconds received the following error message, "windows resource protection could not perform the requested operation". Believe me, I am not one who throws up his hands in utter despair, but - as much as I hate to admit it, Vista is about to give me a thorough beat down! There just has to be an easier way to fix a corrupted or missing system file in Vista! I consider myself to have above average experience with operating systems, and I am freaking out! I can't imagine what this must be like for the average PC user with Vista installed trying to find satisfaction with a problem issue! My prayers go out to them! Please someone help! |
| | Re: Vista system file check problems! > This is maddening! I had posted a problem with png in Vista. I believe > that > it is causing graphic display problems with IE7. Post the problem again. Sounds more like a video driver to me. -Frank |
| | RE: Vista system file check problems! Hello, Please send me the cbs.log file from the c:\windows\logs\cbs folder. Replacing files in Windows Vista can be a challenge so hopefully this is one of the protected files that SFC can replace. Remove the online from my email address when sending me the log file Compress it please into a zip file. Thanks, Darrell Gorter[MSFT] This posting is provided "AS IS" with no warranties, and confers no rights -------------------- |>Thread-Topic: Vista system file check problems! |>thread-index: Acdp1ISrHYR6/6HKS8CM0u2GuRvuIg== |>X-WBNR-Posting-Host: 207.46.19.168 |>From: =?Utf-8?B?QnJhd2x5?= <Brawly@discussions.microsoft.com> |>Subject: Vista system file check problems! |>Date: Sun, 18 Mar 2007 20:13:08 -0700 |>Lines: 16 |>Message-ID: <70099DEF-2F20-48F6-BD01-1A3856ADDB92@microsoft.com> |>MIME-Version: 1.0 |>Content-Type: text/plain; |> charset="Utf-8" |>Content-Transfer-Encoding: 7bit |>X-Newsreader: Microsoft CDO for Windows 2000 |>Content-Class: urn:content-classes:message |>Importance: normal |>Priority: normal |>X-MimeOLE: Produced By Microsoft MimeOLE V6.00.3790.2757 |>Newsgroups: microsoft.public.windows.vista.general |>Path: TK2MSFTNGHUB02.phx.gbl |>Xref: TK2MSFTNGHUB02.phx.gbl microsoft.public.windows.vista.general:65830 |>NNTP-Posting-Host: tk2msftsbfm01.phx.gbl 10.40.244.148 |>X-Tomcat-NG: microsoft.public.windows.vista.general |> |>This is maddening! I had posted a problem with png in Vista. I believe that |>it is causing graphic display problems with IE7. One reply suggested that I |>use my installation disk and run the system file check utility (sfc /scannow) |>to repair what may be a corrupted file. I inserted the Vista installation |>disk and rebooted my system, eventually the "repair" prompt menu appeared. I |>selected the cmd prompt which then launched the command window. I then |>entered sfc /scannow, and within a few seconds received the following error |>message, "windows resource protection could not perform the requested |>operation". Believe me, I am not one who throws up his hands in utter |>despair, but - as much as I hate to admit it, Vista is about to give me a |>thorough beat down! There just has to be an easier way to fix a corrupted or |>missing system file in Vista! I consider myself to have above average |>experience with operating systems, and I am freaking out! I can't imagine |>what this must be like for the average PC user with Vista installed trying to |>find satisfaction with a problem issue! My prayers go out to them! Please |>someone help! |> |
| | Re: Vista system file check problems! On Sun, 18 Mar 2007 20:13:08 -0700, Brawly <Brawly@discussions.microsoft.com> wrote: >This is maddening! I had posted a problem with png in Vista. I believe that >it is causing graphic display problems with IE7. One reply suggested that I >use my installation disk and run the system file check utility (sfc /scannow) >to repair what may be a corrupted file. I inserted the Vista installation >disk and rebooted my system, eventually the "repair" prompt menu appeared. I >selected the cmd prompt which then launched the command window. I then >entered sfc /scannow, and within a few seconds received the following error >message, "windows resource protection could not perform the requested >operation". Believe me, I am not one who throws up his hands in utter >despair, but - as much as I hate to admit it, Vista is about to give me a >thorough beat down! There just has to be an easier way to fix a corrupted or >missing system file in Vista! I consider myself to have above average >experience with operating systems, and I am freaking out! I can't imagine >what this must be like for the average PC user with Vista installed trying to >find satisfaction with a problem issue! My prayers go out to them! Please >someone help! I haven't tried, so just a wild guess. Have you turned off UAC first? Also isn't there another choice to do repair besides from the command prompt? There used to be in XP, but its been so long since I used it I forgot. I can't imagine Microsoft would be dumb enough to only include a command prompt option to do repairs from the OS DVD, there should be (I hope) another method. In fact going way back several years I remember once when XP came up with one of those weird recovered from messages, but said it had to do something else, forget what but I know I didn't go to no command prompt. I was actually quite impressed to see one of Windows hidden commands take over and rebuild the hive or something as it showed a bunch of stuff go flying by on the screen as it proceeded for the next twenty minutes to put on quite a show and ended up fixed whatever was wrong with all but a couple files of countless thousands. I would assume Vista got smarter, not dumber. Of course we can only hope. |
| | Re: Vista system file check problems! Does SFC have to be run from an elevated command prompt? ""Darrell Gorter[MSFT]"" <Darrellg@online.microsoft.com> wrote in message news:ST1IFZdaHHA.2372@TK2MSFTNGHUB02.phx.gbl... > Hello, > Please send me the cbs.log file from the c:\windows\logs\cbs folder. > Replacing files in Windows Vista can be a challenge so hopefully this is > one of the protected files that SFC can replace. > Remove the online from my email address when sending me the log file > Compress it please into a zip file. > Thanks, > Darrell Gorter[MSFT] > > This posting is provided "AS IS" with no warranties, and confers no rights > -------------------- > |>Thread-Topic: Vista system file check problems! > |>thread-index: Acdp1ISrHYR6/6HKS8CM0u2GuRvuIg== > |>X-WBNR-Posting-Host: 207.46.19.168 > |>From: =?Utf-8?B?QnJhd2x5?= <Brawly@discussions.microsoft.com> > |>Subject: Vista system file check problems! > |>Date: Sun, 18 Mar 2007 20:13:08 -0700 > |>Lines: 16 > |>Message-ID: <70099DEF-2F20-48F6-BD01-1A3856ADDB92@microsoft.com> > |>MIME-Version: 1.0 > |>Content-Type: text/plain; > |> charset="Utf-8" > |>Content-Transfer-Encoding: 7bit > |>X-Newsreader: Microsoft CDO for Windows 2000 > |>Content-Class: urn:content-classes:message > |>Importance: normal > |>Priority: normal > |>X-MimeOLE: Produced By Microsoft MimeOLE V6.00.3790.2757 > |>Newsgroups: microsoft.public.windows.vista.general > |>Path: TK2MSFTNGHUB02.phx.gbl > |>Xref: TK2MSFTNGHUB02.phx.gbl > microsoft.public.windows.vista.general:65830 > |>NNTP-Posting-Host: tk2msftsbfm01.phx.gbl 10.40.244.148 > |>X-Tomcat-NG: microsoft.public.windows.vista.general > |> > |>This is maddening! I had posted a problem with png in Vista. I believe > that > |>it is causing graphic display problems with IE7. One reply suggested > that I > |>use my installation disk and run the system file check utility (sfc > /scannow) > |>to repair what may be a corrupted file. I inserted the Vista > installation > |>disk and rebooted my system, eventually the "repair" prompt menu > appeared. I > |>selected the cmd prompt which then launched the command window. I then > |>entered sfc /scannow, and within a few seconds received the following > error > |>message, "windows resource protection could not perform the requested > |>operation". Believe me, I am not one who throws up his hands in utter > |>despair, but - as much as I hate to admit it, Vista is about to give me > a > |>thorough beat down! There just has to be an easier way to fix a > corrupted or > |>missing system file in Vista! I consider myself to have above average > |>experience with operating systems, and I am freaking out! I can't > imagine > |>what this must be like for the average PC user with Vista installed > trying to > |>find satisfaction with a problem issue! My prayers go out to them! > Please > |>someone help! > |> > |
| | #6 (permalink) |
| | RE: Vista system file check problems! Hello Darrell, Thank you for responding. I have attempted to email you the CBS log file for your review, and I did read that you would prefer it sent to you "offline". Forgive my ignorance, but just how do I do that? I sent it to you via Outlook, and the email was returned to me. Could you give me a small tutorial? Thanks again! ""Darrell Gorter[MSFT]"" wrote: > Hello, > Please send me the cbs.log file from the c:\windows\logs\cbs folder. > Replacing files in Windows Vista can be a challenge so hopefully this is > one of the protected files that SFC can replace. > Remove the online from my email address when sending me the log file > Compress it please into a zip file. > Thanks, > Darrell Gorter[MSFT] > > This posting is provided "AS IS" with no warranties, and confers no rights > -------------------- > |>Thread-Topic: Vista system file check problems! > |>thread-index: Acdp1ISrHYR6/6HKS8CM0u2GuRvuIg== > |>X-WBNR-Posting-Host: 207.46.19.168 > |>From: =?Utf-8?B?QnJhd2x5?= <Brawly@discussions.microsoft.com> > |>Subject: Vista system file check problems! > |>Date: Sun, 18 Mar 2007 20:13:08 -0700 > |>Lines: 16 > |>Message-ID: <70099DEF-2F20-48F6-BD01-1A3856ADDB92@microsoft.com> > |>MIME-Version: 1.0 > |>Content-Type: text/plain; > |> charset="Utf-8" > |>Content-Transfer-Encoding: 7bit > |>X-Newsreader: Microsoft CDO for Windows 2000 > |>Content-Class: urn:content-classes:message > |>Importance: normal > |>Priority: normal > |>X-MimeOLE: Produced By Microsoft MimeOLE V6.00.3790.2757 > |>Newsgroups: microsoft.public.windows.vista.general > |>Path: TK2MSFTNGHUB02.phx.gbl > |>Xref: TK2MSFTNGHUB02.phx.gbl microsoft.public.windows.vista.general:65830 > |>NNTP-Posting-Host: tk2msftsbfm01.phx.gbl 10.40.244.148 > |>X-Tomcat-NG: microsoft.public.windows.vista.general > |> > |>This is maddening! I had posted a problem with png in Vista. I believe > that > |>it is causing graphic display problems with IE7. One reply suggested > that I > |>use my installation disk and run the system file check utility (sfc > /scannow) > |>to repair what may be a corrupted file. I inserted the Vista > installation > |>disk and rebooted my system, eventually the "repair" prompt menu > appeared. I > |>selected the cmd prompt which then launched the command window. I then > |>entered sfc /scannow, and within a few seconds received the following > error > |>message, "windows resource protection could not perform the requested > |>operation". Believe me, I am not one who throws up his hands in utter > |>despair, but - as much as I hate to admit it, Vista is about to give me a > |>thorough beat down! There just has to be an easier way to fix a > corrupted or > |>missing system file in Vista! I consider myself to have above average > |>experience with operating systems, and I am freaking out! I can't > imagine > |>what this must be like for the average PC user with Vista installed > trying to > |>find satisfaction with a problem issue! My prayers go out to them! > Please > |>someone help! > |> > > |
| | #7 (permalink) |
| | Re: Vista system file check problems! Darrellg@online.microsoft.com Remove "online" from the above address, so that it says @microsoft.com -Michael "Brawly" <Brawly@discussions.microsoft.com> wrote in message news:EF309C71-463D-4343-A11B-70F6FB719091@microsoft.com... > Hello Darrell, > > Thank you for responding. I have attempted to email you the CBS log file > for your review, and I did read that you would prefer it sent to you > "offline". Forgive my ignorance, but just how do I do that? I sent it to > you via Outlook, and the email was returned to me. Could you give me a small > tutorial? Thanks again! > > ""Darrell Gorter[MSFT]"" wrote: > >> Hello, >> Please send me the cbs.log file from the c:\windows\logs\cbs folder. >> Replacing files in Windows Vista can be a challenge so hopefully this is >> one of the protected files that SFC can replace. >> Remove the online from my email address when sending me the log file >> Compress it please into a zip file. >> Thanks, >> Darrell Gorter[MSFT] >> >> This posting is provided "AS IS" with no warranties, and confers no rights >> -------------------- >> |>Thread-Topic: Vista system file check problems! >> |>thread-index: Acdp1ISrHYR6/6HKS8CM0u2GuRvuIg== >> |>X-WBNR-Posting-Host: 207.46.19.168 >> |>From: =?Utf-8?B?QnJhd2x5?= <Brawly@discussions.microsoft.com> >> |>Subject: Vista system file check problems! >> |>Date: Sun, 18 Mar 2007 20:13:08 -0700 >> |>Lines: 16 >> |>Message-ID: <70099DEF-2F20-48F6-BD01-1A3856ADDB92@microsoft.com> >> |>MIME-Version: 1.0 >> |>Content-Type: text/plain; >> |> charset="Utf-8" >> |>Content-Transfer-Encoding: 7bit >> |>X-Newsreader: Microsoft CDO for Windows 2000 >> |>Content-Class: urn:content-classes:message >> |>Importance: normal >> |>Priority: normal >> |>X-MimeOLE: Produced By Microsoft MimeOLE V6.00.3790.2757 >> |>Newsgroups: microsoft.public.windows.vista.general >> |>Path: TK2MSFTNGHUB02.phx.gbl >> |>Xref: TK2MSFTNGHUB02.phx.gbl microsoft.public.windows.vista.general:65830 >> |>NNTP-Posting-Host: tk2msftsbfm01.phx.gbl 10.40.244.148 >> |>X-Tomcat-NG: microsoft.public.windows.vista.general >> |> >> |>This is maddening! I had posted a problem with png in Vista. I believe >> that >> |>it is causing graphic display problems with IE7. One reply suggested >> that I >> |>use my installation disk and run the system file check utility (sfc >> /scannow) >> |>to repair what may be a corrupted file. I inserted the Vista >> installation >> |>disk and rebooted my system, eventually the "repair" prompt menu >> appeared. I >> |>selected the cmd prompt which then launched the command window. I then >> |>entered sfc /scannow, and within a few seconds received the following >> error >> |>message, "windows resource protection could not perform the requested >> |>operation". Believe me, I am not one who throws up his hands in utter >> |>despair, but - as much as I hate to admit it, Vista is about to give me a >> |>thorough beat down! There just has to be an easier way to fix a >> corrupted or >> |>missing system file in Vista! I consider myself to have above average >> |>experience with operating systems, and I am freaking out! I can't >> imagine >> |>what this must be like for the average PC user with Vista installed >> trying to >> |>find satisfaction with a problem issue! My prayers go out to them! >> Please >> |>someone help! >> |> >> >> |
| | #8 (permalink) |
| | Re: Vista system file check problems! Hello Adam, Great suggestion, but it actually has nothing to do with the UAC (I have attempted the procedure with UAC turned off). To run sfc /scannow from your desktop, you need to open the cmd utility by right clicking on the cmd launcher in the start menu and selecting "administrator" whereas you can enter the sfc /command utility to repair or verify system protected files. This utility has worked fine for me, but has indicated that there are corrupt files (after completing 98% of the check) which has confirmed my fears. The problem I am having is using the utility to correct the damaged or missing files. The utility is ineffective from desktop running as administrator, and is ineffective inserting the Vista installation disk, rebooting and initiating the command module. When I attempt it I receive an error message as follows: "windows resource protection could not perform the requested operation". I have several people helping me with it, any contribution you could make would be outstanding! I just hope a solution is reached. I fear I may have to conduct a clean reinstall my Vista operating system to correct this problem - I wish to avoid this because my system is set up to dual-boot both Vista and WinXP. I am sure you can see the dilemma i'm in! Thanks. "Adam Albright" wrote: > On Sun, 18 Mar 2007 20:13:08 -0700, Brawly > <Brawly@discussions.microsoft.com> wrote: > > >This is maddening! I had posted a problem with png in Vista. I believe that > >it is causing graphic display problems with IE7. One reply suggested that I > >use my installation disk and run the system file check utility (sfc /scannow) > >to repair what may be a corrupted file. I inserted the Vista installation > >disk and rebooted my system, eventually the "repair" prompt menu appeared. I > >selected the cmd prompt which then launched the command window. I then > >entered sfc /scannow, and within a few seconds received the following error > >message, "windows resource protection could not perform the requested > >operation". Believe me, I am not one who throws up his hands in utter > >despair, but - as much as I hate to admit it, Vista is about to give me a > >thorough beat down! There just has to be an easier way to fix a corrupted or > >missing system file in Vista! I consider myself to have above average > >experience with operating systems, and I am freaking out! I can't imagine > >what this must be like for the average PC user with Vista installed trying to > >find satisfaction with a problem issue! My prayers go out to them! Please > >someone help! > > I haven't tried, so just a wild guess. Have you turned off UAC first? > > Also isn't there another choice to do repair besides from the command > prompt? There used to be in XP, but its been so long since I used it I > forgot. I can't imagine Microsoft would be dumb enough to only include > a command prompt option to do repairs from the OS DVD, there should be > (I hope) another method. > > In fact going way back several years I remember once when XP came up > with one of those weird recovered from messages, but said it had to do > something else, forget what but I know I didn't go to no command > prompt. I was actually quite impressed to see one of Windows hidden > commands take over and rebuild the hive or something as it showed a > bunch of stuff go flying by on the screen as it proceeded for the next > twenty minutes to put on quite a show and ended up fixed whatever was > wrong with all but a couple files of countless thousands. I would > assume Vista got smarter, not dumber. Of course we can only hope. > > > |
| | #9 (permalink) |
| | Re: Vista system file check problems! Thanks Kue2. The information I have received indicates that sfc /scannow (system file check) must be run by the administrator. "Kue2" wrote: > Does SFC have to be run from an elevated command prompt? > > ""Darrell Gorter[MSFT]"" <Darrellg@online.microsoft.com> wrote in message > news:ST1IFZdaHHA.2372@TK2MSFTNGHUB02.phx.gbl... > > Hello, > > Please send me the cbs.log file from the c:\windows\logs\cbs folder. > > Replacing files in Windows Vista can be a challenge so hopefully this is > > one of the protected files that SFC can replace. > > Remove the online from my email address when sending me the log file > > Compress it please into a zip file. > > Thanks, > > Darrell Gorter[MSFT] > > > > This posting is provided "AS IS" with no warranties, and confers no rights > > -------------------- > > |>Thread-Topic: Vista system file check problems! > > |>thread-index: Acdp1ISrHYR6/6HKS8CM0u2GuRvuIg== > > |>X-WBNR-Posting-Host: 207.46.19.168 > > |>From: =?Utf-8?B?QnJhd2x5?= <Brawly@discussions.microsoft.com> > > |>Subject: Vista system file check problems! > > |>Date: Sun, 18 Mar 2007 20:13:08 -0700 > > |>Lines: 16 > > |>Message-ID: <70099DEF-2F20-48F6-BD01-1A3856ADDB92@microsoft.com> > > |>MIME-Version: 1.0 > > |>Content-Type: text/plain; > > |> charset="Utf-8" > > |>Content-Transfer-Encoding: 7bit > > |>X-Newsreader: Microsoft CDO for Windows 2000 > > |>Content-Class: urn:content-classes:message > > |>Importance: normal > > |>Priority: normal > > |>X-MimeOLE: Produced By Microsoft MimeOLE V6.00.3790.2757 > > |>Newsgroups: microsoft.public.windows.vista.general > > |>Path: TK2MSFTNGHUB02.phx.gbl > > |>Xref: TK2MSFTNGHUB02.phx.gbl > > microsoft.public.windows.vista.general:65830 > > |>NNTP-Posting-Host: tk2msftsbfm01.phx.gbl 10.40.244.148 > > |>X-Tomcat-NG: microsoft.public.windows.vista.general > > |> > > |>This is maddening! I had posted a problem with png in Vista. I believe > > that > > |>it is causing graphic display problems with IE7. One reply suggested > > that I > > |>use my installation disk and run the system file check utility (sfc > > /scannow) > > |>to repair what may be a corrupted file. I inserted the Vista > > installation > > |>disk and rebooted my system, eventually the "repair" prompt menu > > appeared. I > > |>selected the cmd prompt which then launched the command window. I then > > |>entered sfc /scannow, and within a few seconds received the following > > error > > |>message, "windows resource protection could not perform the requested > > |>operation". Believe me, I am not one who throws up his hands in utter > > |>despair, but - as much as I hate to admit it, Vista is about to give me > > a > > |>thorough beat down! There just has to be an easier way to fix a > > corrupted or > > |>missing system file in Vista! I consider myself to have above average > > |>experience with operating systems, and I am freaking out! I can't > > imagine > > |>what this must be like for the average PC user with Vista installed > > trying to > > |>find satisfaction with a problem issue! My prayers go out to them! > > Please > > |>someone help! > > |> > > > > |
| | #10 (permalink) |
| | Re: Vista system file check problems! Thanks Michael, for clearing that up. I did get the log file and we are looking at it. Thanks, Darrell Gorter[MSFT] This posting is provided "AS IS" with no warranties, and confers no rights -------------------- |>From: "MICHAEL" <u158627_emr2@dslr.net> |>References: <70099DEF-2F20-48F6-BD01-1A3856ADDB92@microsoft.com> <ST1IFZdaHHA.2372@TK2MSFTNGHUB02.phx.gbl> <EF309C71-463D-4343-A11B-70F6FB719091@microsoft.com> |>In-Reply-To: <EF309C71-463D-4343-A11B-70F6FB719091@microsoft.com> |>Subject: Re: Vista system file check problems! |>Date: Mon, 19 Mar 2007 09:46:02 -0400 |>Lines: 84 |>Organization: UNC@Chapel Hill #1! |>MIME-Version: 1.0 |>Content-Type: text/plain; |> format=flowed; |> charset="utf-8"; |> reply-type=original |>Content-Transfer-Encoding: 7bit |>X-Priority: 3 |>X-MSMail-Priority: Normal |>X-Newsreader: Microsoft Windows Mail 6.0.6000.16386 |>X-MimeOLE: Produced By Microsoft MimeOLE V6.0.6000.16386 |>Message-ID: <e$#ZwziaHHA.1400@TK2MSFTNGP06.phx.gbl> |>Newsgroups: microsoft.public.windows.vista.general |>NNTP-Posting-Host: h-74-0-64-157.atlngahp.covad.net 74.0.64.157 |>Path: TK2MSFTNGHUB02.phx.gbl!TK2MSFTNGP01.phx.gbl!TK2MSFTNGP06.phx.gbl |>Xref: TK2MSFTNGHUB02.phx.gbl microsoft.public.windows.vista.general:65997 |>X-Tomcat-NG: microsoft.public.windows.vista.general |> |>Darrellg@online.microsoft.com |> |>Remove "online" from the above address, |>so that it says @microsoft.com |> |> |>-Michael |> |>"Brawly" <Brawly@discussions.microsoft.com> wrote in message |>news:EF309C71-463D-4343-A11B-70F6FB719091@microsoft.com... |>> Hello Darrell, |>> |>> Thank you for responding. I have attempted to email you the CBS log file |>> for your review, and I did read that you would prefer it sent to you |>> "offline". Forgive my ignorance, but just how do I do that? I sent it to |>> you via Outlook, and the email was returned to me. Could you give me a small |>> tutorial? Thanks again! |>> |>> ""Darrell Gorter[MSFT]"" wrote: |>> |>>> Hello, |>>> Please send me the cbs.log file from the c:\windows\logs\cbs folder. |>>> Replacing files in Windows Vista can be a challenge so hopefully this is |>>> one of the protected files that SFC can replace. |>>> Remove the online from my email address when sending me the log file |>>> Compress it please into a zip file. |>>> Thanks, |>>> Darrell Gorter[MSFT] |>>> |>>> This posting is provided "AS IS" with no warranties, and confers no rights |>>> -------------------- |>>> |>Thread-Topic: Vista system file check problems! |>>> |>thread-index: Acdp1ISrHYR6/6HKS8CM0u2GuRvuIg== |>>> |>X-WBNR-Posting-Host: 207.46.19.168 |>>> |>From: =?Utf-8?B?QnJhd2x5?= <Brawly@discussions.microsoft.com> |>>> |>Subject: Vista system file check problems! |>>> |>Date: Sun, 18 Mar 2007 20:13:08 -0700 |>>> |>Lines: 16 |>>> |>Message-ID: <70099DEF-2F20-48F6-BD01-1A3856ADDB92@microsoft.com> |>>> |>MIME-Version: 1.0 |>>> |>Content-Type: text/plain; |>>> |> charset="Utf-8" |>>> |>Content-Transfer-Encoding: 7bit |>>> |>X-Newsreader: Microsoft CDO for Windows 2000 |>>> |>Content-Class: urn:content-classes:message |>>> |>Importance: normal |>>> |>Priority: normal |>>> |>X-MimeOLE: Produced By Microsoft MimeOLE V6.00.3790.2757 |>>> |>Newsgroups: microsoft.public.windows.vista.general |>>> |>Path: TK2MSFTNGHUB02.phx.gbl |>>> |>Xref: TK2MSFTNGHUB02.phx.gbl microsoft.public.windows.vista.general:65830 |>>> |>NNTP-Posting-Host: tk2msftsbfm01.phx.gbl 10.40.244.148 |>>> |>X-Tomcat-NG: microsoft.public.windows.vista.general |>>> |> |>>> |>This is maddening! I had posted a problem with png in Vista. I believe |>>> that |>>> |>it is causing graphic display problems with IE7. One reply suggested |>>> that I |>>> |>use my installation disk and run the system file check utility (sfc |>>> /scannow) |>>> |>to repair what may be a corrupted file. I inserted the Vista |>>> installation |>>> |>disk and rebooted my system, eventually the "repair" prompt menu |>>> appeared. I |>>> |>selected the cmd prompt which then launched the command window. I then |>>> |>entered sfc /scannow, and within a few seconds received the following |>>> error |>>> |>message, "windows resource protection could not perform the requested |>>> |>operation". Believe me, I am not one who throws up his hands in utter |>>> |>despair, but - as much as I hate to admit it, Vista is about to give me a |>>> |>thorough beat down! There just has to be an easier way to fix a |>>> corrupted or |>>> |>missing system file in Vista! I consider myself to have above average |>>> |>experience with operating systems, and I am freaking out! I can't |>>> imagine |>>> |>what this must be like for the average PC user with Vista installed |>>> trying to |>>> |>find satisfaction with a problem issue! My prayers go out to them! |>>> Please |>>> |>someone help! |>>> |> |>>> |>>> |> |> |
| How do you check on Vista if .exe file is 32-bit or 64-bit? | Vista General | |||
| Corrected machine check - many occurences in Vista system event log | Vista General | |||
| Installation/Running period problems, check my system for known in | Vista hardware & devices | |||
