Vista - Vista 64bit ultimate - need a compatible wireless card
Old 03-20-2007   #1 (permalink)
Gonzo
I have Windows Vista 64bit Ultimate version and need a wireless card (PCI or
USB). My ADSL router is a 54mb Netgear D834G router. I bought a PCI
netgear WG311T card to find they only do drivers for the 32bit versions, any
ideas if what adapter with 64bit drivers I could buy to connect to my
wireless network? USB or PCI.
Old 03-20-2007   #2 (permalink)
opus512
RE: Vista 64bit ultimate - need a compatible wireless card
> Go with an Intel based card. I too bought a Netgear, different model and the beta drivers are flakey at best. I've been running a cable to my onboard NIC. Helped a buddy pick out a new laptop the other day and every one I could check that had wireless was running an Intel based adapter.
Old 03-21-2007   #3 (permalink)
Gonzo
Do you have a link to are wireless card that will work on Vista 64 bit , USB
or PCI?
Old 03-21-2007   #4 (permalink)
James
Re: Vista 64bit ultimate - need a compatible wireless card
On Wed, 21 Mar 2007 01:38:13 -0700, Gonzo
>or PCI?
I use a Asus wl-138g pci card with vista 64, that shows up in device
manager as a broadcom card.
James
They think it's all over.... it is now.
Take the FUN out of my email address to reply.
Old 03-21-2007   #5 (permalink)
Gonzo
Are you using vista drivers or XP?
> >or PCI?
> James
Old 03-21-2007   #6 (permalink)
James
On Wed, 21 Mar 2007 06:20:36 -0700, Gonzo
>> >or PCI?
>> James
Vista drivers, it found the card at install
James
64 bit vista compatible wireless N pci card Network & Sharing
is this graphics card compatible with vista ultimate? Graphic cards
Vista sp 1 (64bit ultimate) - cannot connect to wireless networks Vista networking & sharing
Compatible wireless card? Vista hardware & devices
Wireless USB and/or PC Card compatible with Vista RC1 Vista hardware & devices
