| | Using "help" When I try to open "help" I get the following error message: Internet Explorer cannon download/ from Windows. Internet Explorer was not able to open this internet site. The requested site is either unavailbe or cannot be found. Please try again later. |
| | RE: Using "help" Are you connected to the Internet? Help uses Online Help by default. If you don't want to use online help, open help & support, options, settings, uncheck online help. "AKBettie" wrote: > When I try to open "help" I get the following error message: > > Internet Explorer cannon download/ from Windows. > > Internet Explorer was not able to open this internet site. The requested > site is either unavailbe or cannot be found. Please try again later. |
| | RE: Using "help" Yes I'm connected. "Mary" wrote: > Are you connected to the Internet? Help uses Online Help by default. If you > don't want to use online help, open help & support, options, settings, > uncheck online help. > > "AKBettie" wrote: > > > When I try to open "help" I get the following error message: > > > > Internet Explorer cannon download/ from Windows. > > > > Internet Explorer was not able to open this internet site. The requested > > site is either unavailbe or cannot be found. Please try again later. |
| | RE: Using "help" But I will try that. "Mary" wrote: > Are you connected to the Internet? Help uses Online Help by default. If you > don't want to use online help, open help & support, options, settings, > uncheck online help. > > "AKBettie" wrote: > > > When I try to open "help" I get the following error message: > > > > Internet Explorer cannon download/ from Windows. > > > > Internet Explorer was not able to open this internet site. The requested > > site is either unavailbe or cannot be found. Please try again later. |
| | Re: Using "help" Try the fix offered at this site: Fix Windows Vista Help and Support http://www.windows-now.com/blogs/kmk...d-support.aspx It re-associates the .xml file type to its default settings. A recent installation of a program may have "stolen" the .xml association. "AKBettie" <AKBettie@discussions.microsoft.com> wrote in message news:358BFC75-8090-45D3-95A5-FB87A418A09E@microsoft.com... > When I try to open "help" I get the following error message: > > Internet Explorer cannon download/ from Windows. > > Internet Explorer was not able to open this internet site. The requested > site is either unavailbe or cannot be found. Please try again later. |
| | #6 (permalink) |
| | Re: Using "help" Thanks. I just found this here http://windowshelp.microsoft.com/com...6-e38f698af15d It fixed the problem. I do have Dreamweaver installed. "dean-dean" wrote: > Try the fix offered at this site: > > Fix Windows Vista Help and Support > http://www.windows-now.com/blogs/kmk...d-support.aspx > > It re-associates the .xml file type to its default settings. A recent > installation of a program may have "stolen" the .xml association. > > > "AKBettie" <AKBettie@discussions.microsoft.com> wrote in message > news:358BFC75-8090-45D3-95A5-FB87A418A09E@microsoft.com... > > When I try to open "help" I get the following error message: > > > > Internet Explorer cannon download/ from Windows. > > > > Internet Explorer was not able to open this internet site. The requested > > site is either unavailbe or cannot be found. Please try again later. > |
| | #7 (permalink) |
| | Re: Using "help" Installed Dreamweaver, per chance? If so, see the following TechNote from Adobe: Vista help system stops working when Dreamweaver is the default XML editor: http://www.adobe.com/cfusion/knowled...fm?id=kb400789 Error "Internet Explorer was not able to open this Internet site" when using Help and Support in Windows Vista: http://www.winhelponline.com/articles/171/1/ -- Regards, Ramesh Srinivasan, Microsoft MVP [Windows Shell/User] Windows® Troubleshooting http://www.winhelponline.com "AKBettie" <AKBettie@discussions.microsoft.com> wrote in message news:358BFC75-8090-45D3-95A5-FB87A418A09E@microsoft.com... When I try to open "help" I get the following error message: Internet Explorer cannon download/ from Windows. Internet Explorer was not able to open this internet site. The requested site is either unavailbe or cannot be found. Please try again later. |
| SOLVED! "Cannot load Contacts" "0x8004104E" "MSOE.DLL" | Vista mail | |||
| Unwanted Multiple contacts in "To","CC","BCC" of email send catago | Vista mail | |||
| Vista not wotking with "My Computer" or "Control Panel", "Screen Saver" | Vista General | |||
| How can I add the icons "Delete", "Cut", "Copy" and "Paste" in Vis | Vista file management | |||
| WM5 Sync with Vista "Windows Calender", "Contacts", and "Mail" | Vista General | |||
