| | control panel freezing? hello, every time i try to access the "control panel" the screen freezes and i can't scroll or click on anything. when i checked my performance, my cpu usage was constantly at 100%. can anybody help? |
| | Re: control panel freezing? celicancer wrote: > hello, > > every time i try to access the "control panel" the screen freezes and i > can't scroll or click on anything. when i checked my performance, my cpu > usage was constantly at 100%. can anybody help? There are various ways of getting to the control panel. Which way are you using, and does it happen if you use a different way? e.g. open Explorer and click on control panel from there. |
| control panel wont open for me.....Freezing after avast install | Vista General | |||
| control panel and freezing | Vista performance & maintenance | |||
| How can I control the size of icons in Control Panel? | Vista General | |||
| Lost Control of Control Panel | Vista General | |||
| Control Panel | Vista performance & maintenance | |||
