Vista - Connection problems - help
Old 03-21-2007   #1 (permalink)
Poppa Rotzee
Windows Vista Ultimate 64bit. Is anyone else having this problem? I go along
fine for awhile, maybe a day or so and my connection works fine. Then out of
the blue, I'm not connected. When doing a repair I'm told there is a problem
and to reset the connection. I do a reset but this doesn't help either. I
have another computer connected to the router and on a 2 computer network
that works fine. I can't fix it at all unless I reboot. Everything is fine
after a restart. Anyone know what's happening? Thanks.
Old 03-21-2007   #2 (permalink)
Rick Rogers
Re: Connection problems - help
Sounds like a problem with the netword card's driver file. You might check
with the manufacturer for an updated one.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
"Poppa Rotzee" <rot@zee.com> wrote in message
news:%23OZeFrBbHHA.4616@TK2MSFTNGP03.phx.gbl...
> along fine for awhile, maybe a day or so and my connection works fine.
> Then out of the blue, I'm not connected. When doing a repair I'm told
> there is a problem and to reset the connection. I do a reset but this
> doesn't help either. I have another computer connected to the router and
> on a 2 computer network that works fine. I can't fix it at all unless I
> reboot. Everything is fine after a restart. Anyone know what's happening?
> Thanks.
Old 03-22-2007   #3 (permalink)
Poppa Rotzee
Thanks, Rick for the reply. I have a USB wireless adapter that I changed to.
I'll see if this solves the problem. I can't find any different drivers for
my Realtek RTL8201CL 10/100 NIC. Windows says I have the latest drivers but
it is reporting a nVidia card and drivers. So if this works I may just keep
using the USB NIC until I find more current drivers.
"Rick Rogers" <rick@mvps.org> wrote in message
news:e8oTk5BbHHA.2188@TK2MSFTNGP04.phx.gbl...
> Hi,
> Best of Luck,
>> Thanks.
SP 1 & Connection Problems Vista General
Connection Problems? Vista General
Connection problems...PLEASE HELP!!! Network & Sharing
Wi-Fi connection problems Vista networking & sharing
IE 7 Connection problems & Windows Mail Connection Vista General
