| | Wireless networking trouble with Vista I've read lots of posts about this, but no solution. Vista seems to have some problem with wireless connections. We can have two machines next to each other, one running XP and the other with Vista, and the XP one will be solid with excellent signal while the Vista will continuously drift in and out. All the hardware is on the HCL. Here's a clue: When the Vista machine isn't associated with any access point, the "list of available networks" will show the local wireless network's SSID with five bars of strength. We connect to it and the signal strength as reflected in the bars will shortly go down to one or two bars and network connectivity will become intermittent and unreliable. The XP machine sitting next to it doesn't do any of this. I've seen this in two different environments with different brands of access points and network cards. Installing the latest drivers/firmware (even though all are on the HCL) has had no effect. Is there a solution for this? Thanks. |
| | Re: Wireless networking trouble with Vista Hi Julie, This may apply: An outdated network router may not function correctly when you use it together with new networking features in Windows Vista http://support.microsoft.com/kb/932134 -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org "Julie" <julie@somewhere.org> wrote in message news:evwTVLEbHHA.1400@TK2MSFTNGP06.phx.gbl... > I've read lots of posts about this, but no solution. > > Vista seems to have some problem with wireless connections. We can have > two > machines next to each other, one running XP and the other with Vista, and > the > XP one will be solid with excellent signal while the Vista will > continuously drift > in and out. All the hardware is on the HCL. > > Here's a clue: When the Vista machine isn't associated with any access > point, > the "list of available networks" will show the local wireless network's > SSID with > five bars of strength. We connect to it and the signal strength as > reflected in > the bars will shortly go down to one or two bars and network connectivity > will > become intermittent and unreliable. The XP machine sitting next to it > doesn't > do any of this. > > I've seen this in two different environments with different brands of > access points > and network cards. Installing the latest drivers/firmware (even though > all are on > the HCL) has had no effect. > > Is there a solution for this? > > Thanks. > > |
| | Re: Wireless networking trouble with Vista "Julie" <julie@somewhere.org> wrote in message news:evwTVLEbHHA.1400@TK2MSFTNGP06.phx.gbl... > I've read lots of posts about this, but no solution. > > Vista seems to have some problem with wireless connections. We can have > two > machines next to each other, one running XP and the other with Vista, and > the > XP one will be solid with excellent signal while the Vista will > continuously drift > in and out. All the hardware is on the HCL. 3 machines in close proximity here. This is Vista and the other 2 are XP. Sometimes there is another XP about 30 feet away that is also on. No problems wi-fi here. Suggest you may do better looking for better hardware or maybe an updated driver for your hardware (not router but the wireless NIC) |
| | Re: Wireless networking trouble with Vista I have 2 HP DV6000-series laptops, one XP, one Vista. Like you, the XP machine WiLAN performance is faultless. The Vista one has very poor connectivity and data speeds are horrible. It doesn't help that the WiFi dialogs, so simple and easy in XP are now a convoluted mess in Vista! I have HP working on it though. Probably a driver issue. J :-) "jinky" <jamiemagnet@gmail.com> wrote in message news:jinky.2q4lq5@no-mx.tabletquestions.com... > > Hey Julie, > You are not alone, the same thing is happening to me. If I run my > wireless router in unsecured mode, it works fine, I get five bars of > connectivity. As soon as I add security, my connectivity starts to drop > down to almost nothing and eventually I loose my connection. I have an > XP laptop and a Vista laptop. The XP laptop works perfectly connecting > to the route while sitting about 6 inches away from the Vista machine, > the Vista machine connects after a reboot, but after a short time > looses its connection and cannot connect back to it without a reboot. > > > Jamie > > > -- > jinky |
| | Re: Wireless networking trouble with Vista I also have a HP DV6000 which I upgraded from XP to Vista. Which WLAN chip do you have? I have the Intel Pro 3945ABG, and I was able to find a later (and better) driver on Intel's site than what HP's site offered. Gary VanderMolen "James David Byrne" <jamesbyrne@ukonline.co.uk> wrote in message news:%23x%23j799jHHA.4800@TK2MSFTNGP02.phx.gbl... >I have 2 HP DV6000-series laptops, one XP, one Vista. Like you, the XP machine WiLAN performance is faultless. The Vista one has >very poor connectivity and data speeds are horrible. It doesn't help that the WiFi dialogs, so simple and easy in XP are now a >convoluted mess in Vista! I have HP working on it though. Probably a driver issue. > > J :-) > > "jinky" <jamiemagnet@gmail.com> wrote in message news:jinky.2q4lq5@no-mx.tabletquestions.com... >> >> Hey Julie, >> You are not alone, the same thing is happening to me. If I run my >> wireless router in unsecured mode, it works fine, I get five bars of >> connectivity. As soon as I add security, my connectivity starts to drop >> down to almost nothing and eventually I loose my connection. I have an >> XP laptop and a Vista laptop. The XP laptop works perfectly connecting >> to the route while sitting about 6 inches away from the Vista machine, >> the Vista machine connects after a reboot, but after a short time >> looses its connection and cannot connect back to it without a reboot. >> >> >> Jamie >> >> >> -- >> jinky > |
| | #6 (permalink) |
| | Re: Wireless networking trouble with Vista It appears that vista is unable to connect to any wi-fi network that requires username/password authentication. This 'chipset' problem may be also be causing problems for those of you that do connect, then activate some security feature such as wep. "Gary VanderMolen" wrote: > I also have a HP DV6000 which I upgraded from XP to Vista. > Which WLAN chip do you have? I have the Intel Pro 3945ABG, > and I was able to find a later (and better) driver on Intel's site > than what HP's site offered. > > Gary VanderMolen > > "James David Byrne" <jamesbyrne@ukonline.co.uk> wrote in message news:%23x%23j799jHHA.4800@TK2MSFTNGP02.phx.gbl... > >I have 2 HP DV6000-series laptops, one XP, one Vista. Like you, the XP machine WiLAN performance is faultless. The Vista one has > >very poor connectivity and data speeds are horrible. It doesn't help that the WiFi dialogs, so simple and easy in XP are now a > >convoluted mess in Vista! I have HP working on it though. Probably a driver issue. > > > > J :-) > > > > "jinky" <jamiemagnet@gmail.com> wrote in message news:jinky.2q4lq5@no-mx.tabletquestions.com... > >> > >> Hey Julie, > >> You are not alone, the same thing is happening to me. If I run my > >> wireless router in unsecured mode, it works fine, I get five bars of > >> connectivity. As soon as I add security, my connectivity starts to drop > >> down to almost nothing and eventually I loose my connection. I have an > >> XP laptop and a Vista laptop. The XP laptop works perfectly connecting > >> to the route while sitting about 6 inches away from the Vista machine, > >> the Vista machine connects after a reboot, but after a short time > >> looses its connection and cannot connect back to it without a reboot. > >> > >> > >> Jamie > >> > >> > >> -- > >> jinky > > > > > |
| Vista and (wireless?) networking? | Vista General | |||
| Having trouble with Vista networking in a Domain | Vista General | |||
| Vista wireless networking | Vista networking & sharing | |||
| Vista - XP Pro Wireless Networking | Vista networking & sharing | |||
| Vista Networking LAN and Wireless | Vista networking & sharing | |||
