Vista Tutorial - Problem with Vista's Internet Explorer
Old 03-22-2007   #1 (permalink)
Steve
Guest
I have a new PC running Vista Ultimate connected by ethernet cable to a
Belkin F5D7632 wired/wireless router. My old XP machine, which is on the
same desk as my new PC, is connected to the same router via a Belkin wireless
connecter. When I access some websites, my old PC has no problems, but Vista
cannot process some pages - e.g. when trying to buy a ticket on
www.virgintrains.co.uk I can get onto the home page but not find trains - it
just 'hangs' and that green indicator progresses very very very slowly, and
nothing happens. My old PC is fine with the same webpage. I have noticed
this with some other websites too - that blue circle timer just goes round
and round! Also, my Skype calls often drop off after 4-5 minutes. So, if my
old XP machine is working fine with the same webpage, it must be Vista, since
both machines are connected to the same router? Can anyone help please? Are
there any updates for this?
Thanks very much for your help.
Steve
Old 03-22-2007   #2 (permalink)
LaRoux
Guest
Re: Problem with Vista's Internet Explorer
Try disabling the Phishing filter. I've seen it hang up trying to verify.
"Steve" <Steve@discussions.microsoft.com> wrote in message
news:238DEF66-90E6-4710-B61F-D3E1B2376FE5@microsoft.com...
> wireless
> Vista
> it
> and
> my
> since
> Are
> Steve
Old 03-22-2007   #3 (permalink)
Michael Solomon
Guest
> a Belkin F5D7632 wired/wireless router. My old XP machine, which is
> on the same desk as my new PC, is connected to the same router via a
> Belkin wireless connecter. When I access some websites, my old PC
> has no problems, but Vista cannot process some pages - e.g. when
> trying to buy a ticket on www.virgintrains.co.uk I can get onto the
> home page but not find trains - it just 'hangs' and that green
> indicator progresses very very very slowly, and nothing happens. My
> old PC is fine with the same webpage. I have noticed this with some
> other websites too - that blue circle timer just goes round and
> if my old XP machine is working fine with the same webpage, it must
> be Vista, since both machines are connected to the same router? Can
> anyone help please? Are there any updates for this?
Websites need to be updated in order to maintain browser compatibility. XP
used IE6 and Vista is using IE7. It's possible a number of these sites have
not yet updated for IE7 compatibility. As to Skype, have you checked with
them, their website for updated software compatible with Vista and any other
necessary updates they might have posted.
Michael Solomon
Old 03-22-2007   #4 (permalink)
Alpha
Guest
"Michael Solomon" <user@#notme.com> wrote in message
news:Ocs6aPNbHHA.2552@TK2MSFTNGP06.phx.gbl...
Wow...how useful...backward INCOMPATABILITY!
Old 03-23-2007   #5 (permalink)
Steve
Guest
I think the Phishing Filter was already disabled, as I have Norton Internet
Security.
Steve
> > wireless
> > Vista
> > it
> > and
> > my
> > since
> > Are
> > Steve
Old 03-23-2007   #6 (permalink)
watercress_soup
Guest
i've noticed a lot more script errors since going from xp ie7 to vista ie7.
maybe its just me. although most sites still work fine, just an error
message. i have java 6 and flash installed. any other thirdparty addons i
should know about? or is it just like you say websites not having updated
yet?
steve
> XP used IE6 and Vista is using IE7. It's possible a number of these sites
> have not yet updated for IE7 compatibility. As to Skype, have you checked
> with them, their website for updated software compatible with Vista and
> any other necessary updates they might have posted.
> Michael Solomon
Old 03-23-2007   #7 (permalink)
Michael Solomon
Guest
> vista ie7. maybe its just me. although most sites still work fine,
> just an error message. i have java 6 and flash installed. any other
> thirdparty addons i should know about? or is it just like you say
> websites not having updated yet?
Actually, it doesn't take much to trigger a script error. The smallest
error in code can cause it and if you didn't receive the error message, you
might not even know such an error existed on that page. You can turn off
script error reporting. In IE7, go to Tools, select Internet Options, go to
the Advanced tab, be sure the options to display script errors, I believe
there are 2 such options, are NOT selected, click apply and ok.
Yes, it could be the sites have not been updated or it could mean the sites
have been updated but there's some bad or unrecognized code on the page
which is triggering the script error notification.
Michael Solomon
Internet Explorer Problem Vista performance & maintenance
Internet Explorer 8 Problem Software
Vista Internet Explorer/Windows Explorer shortcut problem Vista General
Internet explorer problem Vista General
Add Internet Explorer to Vista's Desktop (FxDeskie 1.2) Vista General
