| | Photo card reader problem Using 32-bit Vista Business with 4Gb of RAM, I have tried using copy and paste from my Jessops Universal Card Reader to Windows Explorer as I have some problems using Photoshop Elements 5's built in transfer program which does not work properly. (It is version 5.0.2 of Elements which has the Vista patch.) It was not successful because I get the warning message :- "An unexpected error is preventing the operation. Make a note of this error code, which might be useful if you get additional help to resolve this problem. Error 0x80070456: The media in the drive may have changed." Either one of the files will transfer, or they do and Elements thinks one file is corrupt, so I think this is a Vista problem which is also stopping the transfer in Elements. (The problem in Elements is that if I try to use the card reader Elements detects the correct number of photos but then gives this irritating message :- "Files were not obtained from this device. Adobe Photoshop Elements 5.0.2 cannot obtain files from this device. Please ensure that the device is connected properly, or that the battery is charged, and try again." This means that I have to download from my camera, which I prefer not to do as I have a card reader which worked perfectly in XP, taking 1 or 2 seconds per photo against minutes per photo from the camera.) Any suggestions gratefully received. Viv |
| | RE: Photo card reader problem Does this problem mean that the Jessops Universal Card Reader does not work with Vista, even though it worked in XP? I cannot see anything on www.jessops.co.uk to suggest that it does, or does not, work with Vista. Is there any way of telling? "Viv" wrote: > Using 32-bit Vista Business with 4Gb of RAM, I have tried using copy and > paste from my Jessops Universal Card Reader to Windows Explorer as I have > some problems using Photoshop Elements 5's built in transfer program which > does not work properly. (It is version 5.0.2 of Elements which has the Vista > patch.) > > It was not successful because I get the warning message :- > "An unexpected error is preventing the operation. Make a note of this error > code, which might be useful if you get additional help to resolve this > problem. Error 0x80070456: The media in the drive may have changed." > Either one of the files will transfer, or they do and Elements thinks one > file is corrupt, so I think this is a Vista problem which is also stopping > the transfer in Elements. > > (The problem in Elements is that if I try to use the card reader Elements > detects the correct number of photos but then gives this irritating message > :- > "Files were not obtained from this device. Adobe Photoshop Elements 5.0.2 > cannot obtain files from this device. Please ensure that the device is > connected properly, or that the battery is charged, and try again." > This means that I have to download from my camera, which I prefer not to do > as I have a card reader which worked perfectly in XP, taking 1 or 2 seconds > per photo against minutes per photo from the camera.) > > Any suggestions gratefully received. > > Viv |
| | Re: Photo card reader problem I am having this same problem with my 1GB SanDisk Cruzer. Also, sometimes when I plug it in, I get a blue screen and my computer reboots. I haven't figured it out yet, but I sure would like to. There doesn't seem to be much information on the net about this error. -- lancefisher ------------------------------------------------------------------------ lancefisher's Profile: http://forums.techarena.in/member.php?userid=24495 View this thread: http://forums.techarena.in/showthread.php?t=712132 http://forums.techarena.in |
| | Re: Photo card reader problem Lance, Yes, Vista is quite flaky. I am having programs close down because of problems, although I do not know what the cause is. I have solved the card reader problem by moving my expansion card with 4 USB 2.0 sockets from my XP computer to my Vista one. It is possible that all of the USB sockets connected direct to my mainboard are not capable of providing enough power to start the download. Roll on the first Service Patch which will solve, I hope, some of the many problems. Good luck with resolving your problems. Viv "lancefisher" wrote: > > I am having this same problem with my 1GB SanDisk Cruzer. Also, > sometimes when I plug it in, I get a blue screen and my computer > reboots. I haven't figured it out yet, but I sure would like to. > There doesn't seem to be much information on the net about this error. > > > -- > lancefisher > ------------------------------------------------------------------------ > lancefisher's Profile: http://forums.techarena.in/member.php?userid=24495 > View this thread: http://forums.techarena.in/showthread.php?t=712132 > > http://forums.techarena.in > > |
| | Re: Photo card reader problem =?Utf-8?B?Vml2?= <Viv@discussions.microsoft.com> wrote in news:C0932100-AD05-48B1-ACE5-5FA67382D614@microsoft.com: > Lance, > > Yes, Vista is quite flaky. I am having programs close down > because of problems, although I do not know what the cause is. > > I have solved the card reader problem by moving my expansion card > with 4 USB 2.0 sockets from my XP computer to my Vista one. It is > possible that all of the USB sockets connected direct to my > mainboard are not capable of providing enough power to start the > download. > > Roll on the first Service Patch which will solve, I hope, some of > the many problems. Good luck with resolving your problems. > > Viv > > "lancefisher" wrote: > >> >> I am having this same problem with my 1GB SanDisk Cruzer. Also, >> sometimes when I plug it in, I get a blue screen and my computer >> reboots. I haven't figured it out yet, but I sure would like to. >> There doesn't seem to be much information on the net about this >> error. >> >> >> -- >> lancefisher >> ------------------------------------------------------------------ >> ------ lancefisher's Profile: >> http://forums.techarena.in/member.php?userid=24495 View this >> thread: http://forums.techarena.in/showthread.php?t=712132 >> >> http://forums.techarena.in >> >> > I have a Sandisk Imagemate 8 in 1 USB card reader that I plug into a external Belkin 2.0 7 port powered USB hub works perfect everytime. I prefer ACDsee & Paint Shop Pro over the Windows programs but all work fine with transfering the pictures. |
| | #6 (permalink) |
| | Re: Photo card reader problem I am also receiving the same error code, but not from a card reader, although I do have a Jessops card reader that works fine with Vista. I am running Vista Home Premium on both my laptop and my PC. Having successfully written a large number of RAW files to DVD on the laptop using Nero, the files will not then copy from the DVD to the PC when I try to drag & drop. This is when I receive the error message "An unexpected error is preventing the operation. Make a note of this error code, which might be useful if you get additional help to resolve this problem. Error 0x80070456: The media in the drive may have changed." But where is the 'additional help to resolve the problem', as searching the Microsoft site yealds no results. Regards, Adrian "Dave Cox" wrote: > =?Utf-8?B?Vml2?= <Viv@discussions.microsoft.com> wrote in > news:C0932100-AD05-48B1-ACE5-5FA67382D614@microsoft.com: > > > Lance, > > > > Yes, Vista is quite flaky. I am having programs close down > > because of problems, although I do not know what the cause is. > > > > I have solved the card reader problem by moving my expansion card > > with 4 USB 2.0 sockets from my XP computer to my Vista one. It is > > possible that all of the USB sockets connected direct to my > > mainboard are not capable of providing enough power to start the > > download. > > > > Roll on the first Service Patch which will solve, I hope, some of > > the many problems. Good luck with resolving your problems. > > > > Viv > > > > "lancefisher" wrote: > > > >> > >> I am having this same problem with my 1GB SanDisk Cruzer. Also, > >> sometimes when I plug it in, I get a blue screen and my computer > >> reboots. I haven't figured it out yet, but I sure would like to. > >> There doesn't seem to be much information on the net about this > >> error. > >> > >> > >> -- > >> lancefisher > >> ------------------------------------------------------------------ > >> ------ lancefisher's Profile: > >> http://forums.techarena.in/member.php?userid=24495 View this > >> thread: http://forums.techarena.in/showthread.php?t=712132 > >> > >> http://forums.techarena.in > >> > >> > > > > I have a Sandisk Imagemate 8 in 1 USB card reader that I plug into a > external Belkin 2.0 7 port powered USB hub works perfect everytime. I > prefer ACDsee & Paint Shop Pro over the Windows programs but all > work fine with transfering the pictures. > |
| | #7 (permalink) |
| | Re: Photo card reader problem Hi. I`m not very good in English, so sorry. But I`ve also had same problems with my 1 Gb Transcend v168 transfering files to my laptop and the same message "An unexpected error is preventing the operation. Make a note of this error code, which might be useful if you get additional help to resolve this problem. Error 0x80070456: The file in the drive may have changed." So operation was failed. At this time no information about this at all except here. "Harrier" wrote: > I am also receiving the same error code, but not from a card reader, although > I do have a Jessops card reader that works fine with Vista. > I am running Vista Home Premium on both my laptop and my PC. Having > successfully written a large number of RAW files to DVD on the laptop using > Nero, the files will not then copy from the DVD to the PC when I try to drag > & drop. This is when I receive the error message "An unexpected error is > preventing the operation. Make a note of this error > code, which might be useful if you get additional help to resolve this > problem. Error 0x80070456: The media in the drive may have changed." > > But where is the 'additional help to resolve the problem', as searching the > Microsoft site yealds no results. > > Regards, > Adrian > > > "Dave Cox" wrote: > > > =?Utf-8?B?Vml2?= <Viv@discussions.microsoft.com> wrote in > > news:C0932100-AD05-48B1-ACE5-5FA67382D614@microsoft.com: > > > > > Lance, > > > > > > Yes, Vista is quite flaky. I am having programs close down > > > because of problems, although I do not know what the cause is. > > > > > > I have solved the card reader problem by moving my expansion card > > > with 4 USB 2.0 sockets from my XP computer to my Vista one. It is > > > possible that all of the USB sockets connected direct to my > > > mainboard are not capable of providing enough power to start the > > > download. > > > > > > Roll on the first Service Patch which will solve, I hope, some of > > > the many problems. Good luck with resolving your problems. > > > > > > Viv > > > > > > "lancefisher" wrote: > > > > > >> > > >> I am having this same problem with my 1GB SanDisk Cruzer. Also, > > >> sometimes when I plug it in, I get a blue screen and my computer > > >> reboots. I haven't figured it out yet, but I sure would like to. > > >> There doesn't seem to be much information on the net about this > > >> error. > > >> > > >> > > >> -- > > >> lancefisher > > >> ------------------------------------------------------------------ > > >> ------ lancefisher's Profile: > > >> http://forums.techarena.in/member.php?userid=24495 View this > > >> thread: http://forums.techarena.in/showthread.php?t=712132 > > >> > > >> http://forums.techarena.in > > >> > > >> > > > > > > > I have a Sandisk Imagemate 8 in 1 USB card reader that I plug into a > > external Belkin 2.0 7 port powered USB hub works perfect everytime. I > > prefer ACDsee & Paint Shop Pro over the Windows programs but all > > work fine with transfering the pictures. > > |
| | #8 (permalink) |
| | Re: Photo card reader problem I have the Problem 0x80070456 with my DVD RW Drive in my Acer 5022WLMI Laptop. If i want to copy Files lager than 1MB then i get Error 0x80070456... "Andrey" wrote: > Hi. I`m not very good in English, so sorry. But I`ve also had same problems > with my 1 Gb Transcend v168 transfering files to my laptop and the same > message "An unexpected error is preventing the operation. Make a note of this > error > code, which might be useful if you get additional help to resolve this > problem. Error 0x80070456: The file in the drive may have changed." So > operation was failed. At this time no information about this at all except > here. > > "Harrier" wrote: > > > I am also receiving the same error code, but not from a card reader, although > > I do have a Jessops card reader that works fine with Vista. > > I am running Vista Home Premium on both my laptop and my PC. Having > > successfully written a large number of RAW files to DVD on the laptop using > > Nero, the files will not then copy from the DVD to the PC when I try to drag > > & drop. This is when I receive the error message "An unexpected error is > > preventing the operation. Make a note of this error > > code, which might be useful if you get additional help to resolve this > > problem. Error 0x80070456: The media in the drive may have changed." > > > > But where is the 'additional help to resolve the problem', as searching the > > Microsoft site yealds no results. > > > > Regards, > > Adrian > > > > > > "Dave Cox" wrote: > > > > > =?Utf-8?B?Vml2?= <Viv@discussions.microsoft.com> wrote in > > > news:C0932100-AD05-48B1-ACE5-5FA67382D614@microsoft.com: > > > > > > > Lance, > > > > > > > > Yes, Vista is quite flaky. I am having programs close down > > > > because of problems, although I do not know what the cause is. > > > > > > > > I have solved the card reader problem by moving my expansion card > > > > with 4 USB 2.0 sockets from my XP computer to my Vista one. It is > > > > possible that all of the USB sockets connected direct to my > > > > mainboard are not capable of providing enough power to start the > > > > download. > > > > > > > > Roll on the first Service Patch which will solve, I hope, some of > > > > the many problems. Good luck with resolving your problems. > > > > > > > > Viv > > > > > > > > "lancefisher" wrote: > > > > > > > >> > > > >> I am having this same problem with my 1GB SanDisk Cruzer. Also, > > > >> sometimes when I plug it in, I get a blue screen and my computer > > > >> reboots. I haven't figured it out yet, but I sure would like to. > > > >> There doesn't seem to be much information on the net about this > > > >> error. > > > >> > > > >> > > > >> -- > > > >> lancefisher > > > >> ------------------------------------------------------------------ > > > >> ------ lancefisher's Profile: > > > >> http://forums.techarena.in/member.php?userid=24495 View this > > > >> thread: http://forums.techarena.in/showthread.php?t=712132 > > > >> > > > >> http://forums.techarena.in > > > >> > > > >> > > > > > > > > > > I have a Sandisk Imagemate 8 in 1 USB card reader that I plug into a > > > external Belkin 2.0 7 port powered USB hub works perfect everytime. I > > > prefer ACDsee & Paint Shop Pro over the Windows programs but all > > > work fine with transfering the pictures. > > > |
| | #9 (permalink) |
| | Re: Photo card reader problem Maybe there is a bug in the driver! -- http://www.goldwatches.com/watches.asp?Brand=14 "zeroq" <zeroq@discussions.microsoft.com> wrote in message news:1DE90DE9-4568-4579-9BC2-F99FEFBEBB4D@microsoft.com... >I have the Problem 0x80070456 with my DVD RW Drive in my Acer 5022WLMI > Laptop. If i want to copy Files lager than 1MB then i get Error > 0x80070456... > > > "Andrey" wrote: > >> Hi. I`m not very good in English, so sorry. But I`ve also had same >> problems >> with my 1 Gb Transcend v168 transfering files to my laptop and the same >> message "An unexpected error is preventing the operation. Make a note of >> this >> error >> code, which might be useful if you get additional help to resolve this >> problem. Error 0x80070456: The file in the drive may have changed." So >> operation was failed. At this time no information about this at all >> except >> here. >> >> "Harrier" wrote: >> >> > I am also receiving the same error code, but not from a card reader, >> > although >> > I do have a Jessops card reader that works fine with Vista. >> > I am running Vista Home Premium on both my laptop and my PC. Having >> > successfully written a large number of RAW files to DVD on the laptop >> > using >> > Nero, the files will not then copy from the DVD to the PC when I try to >> > drag >> > & drop. This is when I receive the error message "An unexpected error >> > is >> > preventing the operation. Make a note of this error >> > code, which might be useful if you get additional help to resolve this >> > problem. Error 0x80070456: The media in the drive may have changed." >> > >> > But where is the 'additional help to resolve the problem', as searching >> > the >> > Microsoft site yealds no results. >> > >> > Regards, >> > Adrian >> > >> > >> > "Dave Cox" wrote: >> > >> > > =?Utf-8?B?Vml2?= <Viv@discussions.microsoft.com> wrote in >> > > news:C0932100-AD05-48B1-ACE5-5FA67382D614@microsoft.com: >> > > >> > > > Lance, >> > > > >> > > > Yes, Vista is quite flaky. I am having programs close down >> > > > because of problems, although I do not know what the cause is. >> > > > >> > > > I have solved the card reader problem by moving my expansion card >> > > > with 4 USB 2.0 sockets from my XP computer to my Vista one. It is >> > > > possible that all of the USB sockets connected direct to my >> > > > mainboard are not capable of providing enough power to start the >> > > > download. >> > > > >> > > > Roll on the first Service Patch which will solve, I hope, some of >> > > > the many problems. Good luck with resolving your problems. >> > > > >> > > > Viv >> > > > >> > > > "lancefisher" wrote: >> > > > >> > > >> >> > > >> I am having this same problem with my 1GB SanDisk Cruzer. Also, >> > > >> sometimes when I plug it in, I get a blue screen and my computer >> > > >> reboots. I haven't figured it out yet, but I sure would like to. >> > > >> There doesn't seem to be much information on the net about this >> > > >> error. >> > > >> >> > > >> >> > > >> -- >> > > >> lancefisher >> > > >> ------------------------------------------------------------------ >> > > >> ------ lancefisher's Profile: >> > > >> http://forums.techarena.in/member.php?userid=24495 View this >> > > >> thread: http://forums.techarena.in/showthread.php?t=712132 >> > > >> >> > > >> http://forums.techarena.in >> > > >> >> > > >> >> > > > >> > > >> > > I have a Sandisk Imagemate 8 in 1 USB card reader that I plug into a >> > > external Belkin 2.0 7 port powered USB hub works perfect everytime. I >> > > prefer ACDsee & Paint Shop Pro over the Windows programs but all >> > > work fine with transfering the pictures. >> > > |
| | #10 (permalink) |
| | Re: Photo card reader problem I have an Acer Aspire M1610 with a built-in 9-in-1 card reader and Win Vista Home Premium. Cards <512MB seem to work ok, but anything larger either comes up with "Error 0x80070456: The media in the drive might have changed" or "Semaphore timeout period has expired" on a regular basis. Even my 2GB Cruzer Micro has gotten the errors. My external hard disks aren't affected by this, even though I have swapped the HDD's and Cruzer's USB port. Maybe Vista is having issues with large Flash RAM? Media that has been tried: Sony 1GB Memory Stick Pro Duo - errors Sandisk 2GB Cruzer Micro USB stick - errors Lexar 1GB SD Micro - errors (note: This media shows issues with WinXP also) Sandisk 1GB SD - errors Lexar 512MB SD Micro - no errors Sandisk 128MB CF - no errors Lexar 512MB CF - no errors Unknown brand 128MB SD Micro - no errors -- chevy_boy ------------------------------------------------------------------------ chevy_boy's Profile: http://forums.techarena.in/member.php?userid=34793 View this thread: http://forums.techarena.in/showthread.php?t=712132 http://forums.techarena.in |
| Flash Memory Card Reader - 16 GB SD Card - Won't Read | Vista hardware & devices | |||
| SD Card Reader Problem | General Discussion | |||
| Generic Card reader problem | Drivers | |||
| VPN & Smart Card reader problem | Vista General | |||
| nw8000 internal SD card reader handles every card as read-only | Vista hardware & devices | |||
