| | Visa will not auto-sleep The auto-sleep option only works 50% of the time for me. Manually pressing the sleep button always works. Why does the auto-sleep function often fail? |
| | Re: Visa will not auto-sleep /Paul/ said: > The auto-sleep option only works 50% of the time for me. Manually pressing > the sleep button always works. > > Why does the auto-sleep function often fail? Perhaps an application that is, in effect, telling the PC that it is being used is suspect. What's running? |
| | Re: Visa will not auto-sleep Paul wrote: > The auto-sleep option only works 50% of the time for me. Manually > pressing the sleep button always works. > > Why does the auto-sleep function often fail? A couple of possibilities. Auto-sleep is supposed to kick in during periods of inactivity. Sometimes, there might be things going on in the background that cause it to think the system is not inactive. If you are connected to a broadband connection, that can be picked up as possible network activity. One thing that might help avoid that is if your computer BIOS has a wake on lan function, try turning it off. When the system boots, the first screen usually has an instruction to hit a specified key if you want to enter setup, that gets you into the BIOS. Then you need to navigate through the various screens to see if your system has a wake on lan function and see if it is enabled. If yes, disable it, save and exit. ***Note, this may not entirely solve the problem as some background activity might still be read as activity as opposed to inactivity. Another possibility is some systems have the ability boot by simply pressing a key on the keyboard. Small motion, any small vibration, might transmit from the mouse that again, might make it appear as though the system is active. Again, same approach as above, I believe this function can also be turned off in the BIOS. And, again, not perfect but it may up the percentage of times the function works for you. Also, be sure you have noting set to run in the background. Other possibilities are items that might automatically check for updates including Windows auto update function. If you have an always on connection, those things will check as will anything set to auto check for new e-mail. -- Michael Solomon |
| | Re: Visa will not auto-sleep "Paul" <Paul@discussions.microsoft.com> wrote in message news:C7F71664-F7FD-4806-82BA-DE1B8FD3FDF3@microsoft.com... > The auto-sleep option only works 50% of the time for me. Manually > pressing > the sleep button always works. > > Why does the auto-sleep function often fail? I think I've noticed screen savers seem to prevent, or greatly delay idling to sleep. Not done any conclusive studies yet, but may be I will. 8-) -- Paul Smith, Yeovil, UK. Microsoft MVP Windows Shell/User. http://www.windowsresource.net/ *Remove nospam. to reply by e-mail* |
| | Re: Visa will not auto-sleep Only IE7, Messenger and Outlook running. Just shut all apps down and tried again... Now it turns off. Why would these apps stop it from auto-sleeping? I have just turned the apps back on and auto-sleep is working fine again....What's up? Why soes it work sometimeas and not others? Should I have hybrid sleep on or off? "dev" wrote: > /Paul/ said: > > > The auto-sleep option only works 50% of the time for me. Manually pressing > > the sleep button always works. > > > > Why does the auto-sleep function often fail? > > Perhaps an application that is, in effect, telling the PC that it is > being used is suspect. > What's running? > |
| | #6 (permalink) |
| | Re: Visa will not auto-sleep /Paul/ said: > > "dev" wrote: > >> /Paul/ said: >> >>> The auto-sleep option only works 50% of the time for me. Manually pressing >>> the sleep button always works. >>> >>> Why does the auto-sleep function often fail? >> >> Perhaps an application that is, in effect, telling the PC that it is >> being used is suspect. >> What's running? > > Only IE7, Messenger and Outlook running. Just shut all apps down and tried > again... Now it turns off. > > Why would these apps stop it from auto-sleeping? > > I have just turned the apps back on and auto-sleep is working fine > again....What's up? Why soes it work sometimeas and not others? > > Should I have hybrid sleep on or off? If the problem persists, try toggling hybrid sleep to the other mode, as a test. |
| | #7 (permalink) |
| | Re: Visa will not auto-sleep Paul wrote: > Only IE7, Messenger and Outlook running. Just shut all apps down and > tried again... Now it turns off. > > Why would these apps stop it from auto-sleeping? > Because messenger and Outlook check for messages and random intervals. Even with auto send and receive turned off, with IE open, random packets can be transmitted and this would register as system activity. That fact it didn't happen when you closed and reopened the apps was coincidental as the sleep function may have been set to start in a period when those applications were still idle. -- Michael Solomon |
| | #8 (permalink) |
| | RE: Visa will not auto-sleep If you tried using the sleep button enough times, it will fail occasionally also. Hp tech support has no answer. Bug report to Vista Developemnt group has no response. "Paul" wrote: > The auto-sleep option only works 50% of the time for me. Manually pressing > the sleep button always works. > > Why does the auto-sleep function often fail? |
| Will not auto-sleep | Vista General | |||
| Vista won't auto sleep after SP1 | Vista General | |||
| auto standby instead of auto sleep | Vista General | |||
| No Auto Sleep - Manual Sleep OK | Vista General | |||
| Auto-sleep and hibernation problems | Vista General | |||
