| | I wish these $%^&*( hardware manufacturers would get their acts together! Why is it that so many hardware manufacturers seem to know less about Vista than I do? I've had two instances, now, in which the information provided by the hardware manufacturer was simply WRONG, and I was able to get the hardware in question working just fine. 1. Netgear: I have a GA511 gigabit PCMCIA NIC. When Vista is allowed to install it, device manager reports that it's working, but it doesn't. Manually tweaking the registers for the NIC got it working with the Vista default driver, but I couldn't force it to 1-gig only operation -- it would lock up unless allowed to autodetect. When it would autodetect 1-gig, it would report the speed as 10 mbps (though actually running at gigabit speeds). However, autodetect was unreliable -- half the time it would connect at 100 mbps. Repeated contact with Netgear was futile. I finally reached a knowledgable tech who told me, "Oh, yeah -- I know about that. I'm trying to work something out." Finally, I decided I'd play with other drivers for the GA511 chipset, and found an internal alternative driver in Vista that works perfectly (except for the false speed report, but that's cosmetic only). I can now force the NIC to default to 1-gig and it works reliably. So, no new driver necessary. Way to go, Netgear! How many customers did you lose because you know less about your products than they do? 2. Adaptec SlimSCSI 1480b Cardbus SCSI adapter. I've got some old HP scanners lying around. They're very good scanners and I don't want to replace them. I used to use them in an XP laptop with an Adaptec 1460c PCMCIA SCSI adapter. That card can't be installed under Vista on my new laptop. The Adaptec website has a page that lists Vista compatibility for its various products. It indicated that, though the 1460c wouldn't work underVista, Adaptec's 1480b adapter would, and there were downloadable drivers available on the website. I found the card on eBay (great deal -- $35 for a card that retails for over $200) and went to the Adaptec website to download the driver. Well, Adapatec has changed the website -- now the Vista page says that it is working on a driver and will have one out eventually, but the card will not work with Vista now. Great! Just for kicks, I downloaded an old NT driver for the 1480b and installed it. Bingo -- Device Manager reports it's working perfectly. I plugged in my oldest HP scanner, a LaserJet IIcx that is about 15 years old. Vista recognized (despite it not being plug and play!) and installed the right driver. All my HP software works perfectly, including the very useful Deskcopy utility. So, no new driver necessary. Way to go, Adaptec! How many customers did you lose because you know less about your products than they do? What is it with these companies? What are their technicians doing, anyway? I'm not a computer professional, and I can get their stuff working under Vista. Why can't they figure this out? |
| | Re: I wish these $%^&*( hardware manufacturers would get their acts together! my guess is that they don't want it to work in vista so they can sell new hardware. a lot of manufactures are getting on that band wagon. "PTravel" <ptravel@travelersvideo.com> wrote in message news:%23zg$Z%23mbHHA.5044@TK2MSFTNGP05.phx.gbl... > Why is it that so many hardware manufacturers seem to know less about > Vista than I do? I've had two instances, now, in which the information > provided by the hardware manufacturer was simply WRONG, and I was able to > get the hardware in question working just fine. > > 1. Netgear: I have a GA511 gigabit PCMCIA NIC. When Vista is allowed to > install it, device manager reports that it's working, but it doesn't. > Manually tweaking the registers for the NIC got it working with the Vista > default driver, but I couldn't force it to 1-gig only operation -- it > would lock up unless allowed to autodetect. When it would autodetect > 1-gig, it would report the speed as 10 mbps (though actually running at > gigabit speeds). However, autodetect was unreliable -- half the time it > would connect at 100 mbps. Repeated contact with Netgear was futile. I > finally reached a knowledgable tech who told me, "Oh, yeah -- I know about > that. I'm trying to work something out." Finally, I decided I'd play with > other drivers for the GA511 chipset, and found an internal alternative > driver in Vista that works perfectly (except for the false speed report, > but that's cosmetic only). I can now force the NIC to default to 1-gig > and it works reliably. So, no new driver necessary. > > Way to go, Netgear! How many customers did you lose because you know less > about your products than they do? > > 2. Adaptec SlimSCSI 1480b Cardbus SCSI adapter. I've got some old HP > scanners lying around. They're very good scanners and I don't want to > replace them. I used to use them in an XP laptop with an Adaptec 1460c > PCMCIA SCSI adapter. That card can't be installed under Vista on my new > laptop. The Adaptec website has a page that lists Vista compatibility for > its various products. It indicated that, though the 1460c wouldn't work > underVista, Adaptec's 1480b adapter would, and there were downloadable > drivers available on the website. I found the card on eBay (great deal -- > $35 for a card that retails for over $200) and went to the Adaptec website > to download the driver. Well, Adapatec has changed the website -- now the > Vista page says that it is working on a driver and will have one out > eventually, but the card will not work with Vista now. Great! Just for > kicks, I downloaded an old NT driver for the 1480b and installed it. > Bingo -- Device Manager reports it's working perfectly. I plugged in my > oldest HP scanner, a LaserJet IIcx that is about 15 years old. Vista > recognized (despite it not being plug and play!) and installed the right > driver. All my HP software works perfectly, including the very useful > Deskcopy utility. So, no new driver necessary. > > Way to go, Adaptec! How many customers did you lose because you know less > about your products than they do? > > What is it with these companies? What are their technicians doing, > anyway? I'm not a computer professional, and I can get their stuff working > under Vista. Why can't they figure this out? |
| | Re: I wish these $%^&*( hardware manufacturers would get their acts together! BigJim wrote: > my guess is that they don't want it to work in vista so they can sell new > hardware. > a lot of manufactures are getting on that band wagon. Your "guess" is correct. This has been the plan ever since Microsoft, through its monopolization of the desktop, and its "partners" came together with the idea of "you scratch my back and I'll scratch yours, and together we'll be able to enrich ourselves at the expense of our user base." Microsoft over the years has proven to be a relentless money grabbing corporation whose reason for being is to enrich its owners. It is no wonder that Bill Gates is the richest man in the world and Screaming Ballard is the 14th richest man. Every upgrade cycle has been a story of forced obsolescence requiring its user base to upgrade both its software and hardware. All this is done in the name of innovation, when in fact, the majority of users have rather simple needs (email, web browsing, word processing, etc) that previous versions already provided. The idea that the old should be in the landfills of this world and the consumer should forever be consuming has become a fine art thanks to the likes of Microsoft and its "partners". Welcome to the world of the corporate domination of life on planet earth, lead in part (a major part) by the greed of Microsoft - the most profitable corporation the world has ever known. Cheers. > "PTravel" <ptravel@travelersvideo.com> wrote in message > news:%23zg$Z%23mbHHA.5044@TK2MSFTNGP05.phx.gbl... >> Why is it that so many hardware manufacturers seem to know less about >> Vista than I do? I've had two instances, now, in which the information >> provided by the hardware manufacturer was simply WRONG, and I was able to >> get the hardware in question working just fine. >> >> 1. Netgear: I have a GA511 gigabit PCMCIA NIC. When Vista is allowed to >> install it, device manager reports that it's working, but it doesn't. >> Manually tweaking the registers for the NIC got it working with the Vista >> default driver, but I couldn't force it to 1-gig only operation -- it >> would lock up unless allowed to autodetect. When it would autodetect >> 1-gig, it would report the speed as 10 mbps (though actually running at >> gigabit speeds). However, autodetect was unreliable -- half the time it >> would connect at 100 mbps. Repeated contact with Netgear was futile. I >> finally reached a knowledgable tech who told me, "Oh, yeah -- I know >> about >> that. I'm trying to work something out." Finally, I decided I'd play >> with other drivers for the GA511 chipset, and found an internal >> alternative driver in Vista that works perfectly (except for the false >> speed report, >> but that's cosmetic only). I can now force the NIC to default to 1-gig >> and it works reliably. So, no new driver necessary. >> >> Way to go, Netgear! How many customers did you lose because you know >> less about your products than they do? >> >> 2. Adaptec SlimSCSI 1480b Cardbus SCSI adapter. I've got some old HP >> scanners lying around. They're very good scanners and I don't want to >> replace them. I used to use them in an XP laptop with an Adaptec 1460c >> PCMCIA SCSI adapter. That card can't be installed under Vista on my new >> laptop. The Adaptec website has a page that lists Vista compatibility >> for >> its various products. It indicated that, though the 1460c wouldn't work >> underVista, Adaptec's 1480b adapter would, and there were downloadable >> drivers available on the website. I found the card on eBay (great deal >> -- $35 for a card that retails for over $200) and went to the Adaptec >> website >> to download the driver. Well, Adapatec has changed the website -- now >> the Vista page says that it is working on a driver and will have one out >> eventually, but the card will not work with Vista now. Great! Just for >> kicks, I downloaded an old NT driver for the 1480b and installed it. >> Bingo -- Device Manager reports it's working perfectly. I plugged in my >> oldest HP scanner, a LaserJet IIcx that is about 15 years old. Vista >> recognized (despite it not being plug and play!) and installed the right >> driver. All my HP software works perfectly, including the very useful >> Deskcopy utility. So, no new driver necessary. >> >> Way to go, Adaptec! How many customers did you lose because you know >> less about your products than they do? >> >> What is it with these companies? What are their technicians doing, >> anyway? I'm not a computer professional, and I can get their stuff >> working >> under Vista. Why can't they figure this out? -- The "Wow" starts now. http://www.youtube.com/watch?v=KyLqUf4cdwc&eurl= "No sane person wants Vista, so Microsoft is making sure they have no choice." http://www.aaxnet.com/editor/edit043.html |
| | Re: I wish these $%^&*( hardware manufacturers would get their acts together! "...a story of forced obsolescence..." In this case the "story" is fiction since no one is forced to upgrade anything by anyone. If a computer is upgrade is is only because the owner CHOOSES to upgrade. If "forced obsolescence" were true as you suggest older computers would not be performing their jobs well, some still using Windows 3.1. "The idea that the old should be in the landfills" That may be your CHOICE, but not mine. I use more than age to determine if something is suitable for a job and nothing prevents anyone else from doing the same. This applies to almost everything, not just computers. -- Jupiter Jones [MVP] http://www3.telus.net/dandemar http://www.dts-l.org "NoStop" <nospam@nospam.com> wrote in message news:1174837220.617370@netadmin1.interbaun.net... > Your "guess" is correct. This has been the plan ever since > Microsoft, > through its monopolization of the desktop, and its "partners" came > together > with the idea of "you scratch my back and I'll scratch yours, and > together > we'll be able to enrich ourselves at the expense of our user base." > > Microsoft over the years has proven to be a relentless money > grabbing > corporation whose reason for being is to enrich its owners. It is no > wonder > that Bill Gates is the richest man in the world and Screaming > Ballard is > the 14th richest man. Every upgrade cycle has been a story of forced > obsolescence requiring its user base to upgrade both its software > and > hardware. All this is done in the name of innovation, when in fact, > the > majority of users have rather simple needs (email, web browsing, > word > processing, etc) that previous versions already provided. > > The idea that the old should be in the landfills of this world and > the > consumer should forever be consuming has become a fine art thanks to > the > likes of Microsoft and its "partners". Welcome to the world of the > corporate domination of life on planet earth, lead in part (a major > part) > by the greed of Microsoft - the most profitable corporation the > world has > ever known. > > Cheers. > > >> "PTravel" <ptravel@travelersvideo.com> wrote in message >> news:%23zg$Z%23mbHHA.5044@TK2MSFTNGP05.phx.gbl... >>> Why is it that so many hardware manufacturers seem to know less >>> about >>> Vista than I do? I've had two instances, now, in which the >>> information >>> provided by the hardware manufacturer was simply WRONG, and I was >>> able to >>> get the hardware in question working just fine. >>> >>> 1. Netgear: I have a GA511 gigabit PCMCIA NIC. When Vista is >>> allowed to >>> install it, device manager reports that it's working, but it >>> doesn't. >>> Manually tweaking the registers for the NIC got it working with >>> the Vista >>> default driver, but I couldn't force it to 1-gig only operation -- >>> it >>> would lock up unless allowed to autodetect. When it would >>> autodetect >>> 1-gig, it would report the speed as 10 mbps (though actually >>> running at >>> gigabit speeds). However, autodetect was unreliable -- half the >>> time it >>> would connect at 100 mbps. Repeated contact with Netgear was >>> futile. I >>> finally reached a knowledgable tech who told me, "Oh, yeah -- I >>> know >>> about >>> that. I'm trying to work something out." Finally, I decided I'd >>> play >>> with other drivers for the GA511 chipset, and found an internal >>> alternative driver in Vista that works perfectly (except for the >>> false >>> speed report, >>> but that's cosmetic only). I can now force the NIC to default to >>> 1-gig >>> and it works reliably. So, no new driver necessary. >>> >>> Way to go, Netgear! How many customers did you lose because you >>> know >>> less about your products than they do? >>> >>> 2. Adaptec SlimSCSI 1480b Cardbus SCSI adapter. I've got some >>> old HP >>> scanners lying around. They're very good scanners and I don't >>> want to >>> replace them. I used to use them in an XP laptop with an Adaptec >>> 1460c >>> PCMCIA SCSI adapter. That card can't be installed under Vista on >>> my new >>> laptop. The Adaptec website has a page that lists Vista >>> compatibility >>> for >>> its various products. It indicated that, though the 1460c >>> wouldn't work >>> underVista, Adaptec's 1480b adapter would, and there were >>> downloadable >>> drivers available on the website. I found the card on eBay (great >>> deal >>> -- $35 for a card that retails for over $200) and went to the >>> Adaptec >>> website >>> to download the driver. Well, Adapatec has changed the website -- >>> now >>> the Vista page says that it is working on a driver and will have >>> one out >>> eventually, but the card will not work with Vista now. Great! >>> Just for >>> kicks, I downloaded an old NT driver for the 1480b and installed >>> it. >>> Bingo -- Device Manager reports it's working perfectly. I plugged >>> in my >>> oldest HP scanner, a LaserJet IIcx that is about 15 years old. >>> Vista >>> recognized (despite it not being plug and play!) and installed the >>> right >>> driver. All my HP software works perfectly, including the very >>> useful >>> Deskcopy utility. So, no new driver necessary. >>> >>> Way to go, Adaptec! How many customers did you lose because you >>> know >>> less about your products than they do? >>> >>> What is it with these companies? What are their technicians >>> doing, >>> anyway? I'm not a computer professional, and I can get their stuff >>> working >>> under Vista. Why can't they figure this out? > > -- > The "Wow" starts now. > http://www.youtube.com/watch?v=KyLqUf4cdwc&eurl= > > "No sane person wants Vista, so Microsoft is making sure they have > no > choice." > http://www.aaxnet.com/editor/edit043.html > |
| | RE: I wish these $%^&*( hardware manufacturers would get their acts to Netgear is hopeless. I tried to setup wireless NIC Adaptor; finally threw it out. Netgear said thattheyMIGHT have a driver solution by the END of April. What a joke! I will never buy their gear again,and am advising friends to do likewise with them. "PTravel" wrote: > Why is it that so many hardware manufacturers seem to know less about Vista > than I do? I've had two instances, now, in which the information provided > by the hardware manufacturer was simply WRONG, and I was able to get the > hardware in question working just fine. > > 1. Netgear: I have a GA511 gigabit PCMCIA NIC. When Vista is allowed to > install it, device manager reports that it's working, but it doesn't. > Manually tweaking the registers for the NIC got it working with the Vista > default driver, but I couldn't force it to 1-gig only operation -- it would > lock up unless allowed to autodetect. When it would autodetect 1-gig, it > would report the speed as 10 mbps (though actually running at gigabit > speeds). However, autodetect was unreliable -- half the time it would > connect at 100 mbps. Repeated contact with Netgear was futile. I finally > reached a knowledgable tech who told me, "Oh, yeah -- I know about that. > I'm trying to work something out." Finally, I decided I'd play with other > drivers for the GA511 chipset, and found an internal alternative driver in > Vista that works perfectly (except for the false speed report, but that's > cosmetic only). I can now force the NIC to default to 1-gig and it works > reliably. So, no new driver necessary. > > Way to go, Netgear! How many customers did you lose because you know less > about your products than they do? > > 2. Adaptec SlimSCSI 1480b Cardbus SCSI adapter. I've got some old HP > scanners lying around. They're very good scanners and I don't want to > replace them. I used to use them in an XP laptop with an Adaptec 1460c > PCMCIA SCSI adapter. That card can't be installed under Vista on my new > laptop. The Adaptec website has a page that lists Vista compatibility for > its various products. It indicated that, though the 1460c wouldn't work > underVista, Adaptec's 1480b adapter would, and there were downloadable > drivers available on the website. I found the card on eBay (great deal -- > $35 for a card that retails for over $200) and went to the Adaptec website > to download the driver. Well, Adapatec has changed the website -- now the > Vista page says that it is working on a driver and will have one out > eventually, but the card will not work with Vista now. Great! Just for > kicks, I downloaded an old NT driver for the 1480b and installed it. > Bingo -- Device Manager reports it's working perfectly. I plugged in my > oldest HP scanner, a LaserJet IIcx that is about 15 years old. Vista > recognized (despite it not being plug and play!) and installed the right > driver. All my HP software works perfectly, including the very useful > Deskcopy utility. So, no new driver necessary. > > Way to go, Adaptec! How many customers did you lose because you know less > about your products than they do? > > What is it with these companies? What are their technicians doing, anyway? > I'm not a computer professional, and I can get their stuff working under > Vista. Why can't they figure this out? > > |
| Is Windows VISTA -->OEM<-- ONLY for manufacturers? | Vista General | |||
| Mixing Memory Manufacturers | Vista hardware & devices | |||
| No Manufacturers list in Add Rprinter wizard | Vista print fax & scan | |||
| FIFA acts as if in slo-mo | Vista Games | |||
| Issues running games from various manufacturers | Vista Games | |||
