| | Printer problem and Solution Home network with 3 XPs (2 with a printer set to shared) and 1 Vista computer Tried to give Vista PC access to shared printer on one of the XP units Of course, I tried Add Printer | Network Total failure - no printers detected So I lied: Add Printer | Local; name of port \\Bernard\B's HPLaser (the XP unit is called Bernard and the printer's share name is "B's HPLaser") This worked just fine. Wonder why? -- Bernard V Liengme www.stfx.ca/people/bliengme remove caps from email |
| | Re: Printer problem and Solution I'm having the exact same problem (I'm trying to access an HP Laser Jet 1012 connected to an XP PC from my new Vista laptop) and would like to try your solution, but I don't understand what you did. Can you give more details? Thanks. Bernard Liengme wrote: > Home network with 3 XPs (2 with a printer set to shared) and 1 Vista > computer > Tried to give Vista PC access to shared printer on one of the XP units > Of course, I tried Add Printer | Network > Total failure - no printers detected > So I lied: Add Printer | Local; name of port \\Bernard\B's HPLaser > (the XP unit is called Bernard and the printer's share name is "B's > HPLaser") > This worked just fine. Wonder why? |
| | RE: Printer problem and Solution Thank you so much. The printer i installed didn’t have downloadable Vista drivers so i hooked the printer to my laptop installed it then plugged the printer back into the host pc then i went back to Pc#2 and clicked Start/ Printers and Faxes, right hand click on the printer and select properties then click the port's tab at the top then select Add Port... in the port types box leave local port selected then click New Port and type the path like this "\\Hostpc\Printer name" without quotes then select OK and make the printer your default printer "Bernard Liengme" wrote: > Home network with 3 XPs (2 with a printer set to shared) and 1 Vista > computer > Tried to give Vista PC access to shared printer on one of the XP units > Of course, I tried Add Printer | Network > Total failure - no printers detected > So I lied: Add Printer | Local; name of port \\Bernard\B's HPLaser > (the XP unit is called Bernard and the printer's share name is "B's > HPLaser") > This worked just fine. Wonder why? > -- > Bernard V Liengme > www.stfx.ca/people/bliengme > remove caps from email > > > |
| Networked Printer Offline - A Solution | Vista print fax & scan | |||
| Lexmark 4500 series printer solution | Vista print fax & scan | |||
| My printer keeps disapearing solution | General Discussion | |||
| Active Directory Domain Services Is Currently Not Available- Printer Missing Solution | Vista networking & sharing | |||
| printer not working help. solution for print spooler service not workiing | Vista installation & setup | |||
