1.    27 Mar 2007 #1
    Googs Guest
    Extended desktop problem
    Hi
    I'm having major difficulties in getting my vista business laptop to
    run correctly with my acer 1916w monitor (17" widescreen). I want to
    use the acer as the main dispay and the laptop as the secondary one,
    and i've configured vista to do just that. It works fine, except that
    the dispay on the acer monitor is wrong, in that if i maximise a
    window then the window stretches beyond the edge of the screen, so
    that the right hand side of the window cannot be seen, only about 1cm
    of it, so that i can barely see the edge of the close button. the
    taskbar is fine, i can see all icons in that, and the display on the
    laptop is fine too.
    here are the settings (using the intel graphics media to control the
    settings):
    monitor 1 - acer 1916w
    color - 3bit
    screen resolution - 1440 x 900
    refresh rate - 60 hertz
    Aspect ration options - full screen (no border)
    monitor 2 - hp 15" widescreen laptop screen
    screen resolution - 1680 x 1050
    rresh rate - 60 hertz
    i've tried playing around with the settings but it's no use, i'm still
    missing that 1cm to the right of the screen when i maximise a window
    in the acer monitor. Also, i don't know if it's my imagination, but
    the desktop icons and other icons and toolbars look lot bigger on the
    acer monitor than they did when i ran the monitor off an xp machine.
    Is it possible to change the size of toolbars and icons on the monitor
    without changing it on the laptop screen?
    Thanks.
  2.    27 Mar 2007 #2
    Googs Guest
    Re: Extended desktop problem
    On 27 Mar, 15:17, "Googs" <thegoogs...@gmail.com> wrote:
    > Hi
    > laptop is fine too.
    > settings):
    > color - 3bit
    > Thanks.
    Actually, i just noticed that my toolbar is also stetching out of the
    screen, i can see the volume icon, but not the time.
  3.    27 Mar 2007 #3
    Craig Guest
    Hi there,
    Have you tried adjusting the monitors viewable settings and shrink the
    horizontal and then move it to the right position that you want?
    Just a thought.
    Cheers
    Craig
    "Googs" <thegoogster@gmail.com> wrote in message
    news:1175005034.281436.69340@d57g2000hsg.googlegroups.com...
    > Hi
    > laptop is fine too.
    > settings):
    > color - 3bit
    > Thanks.
  4.    28 Mar 2007 #4
    Googs Guest
    Hi Craig
    My monitor allows me to change the position of the screen, so i can
    move the screen around, but not shrink the screen so that it fits
    horizontally.
    THanks
    On 27 Mar, 18:12, "Craig" <craigNOSPAMvandergr...@lllow.com> wrote:
    > Hi there,
    > Just a thought.
    > Cheers
    > Craig
    > "Googs" <thegoogs...@gmail.com> wrote in message
    > > Hi
    > > laptop is fine too.
    > > settings):
    > > color - 3bit
    > > Thanks.
Problem with extended desktop to multiple monitors when screen saver comes on
I have a Vista Ultimate laptop connected to two monitors. I can extend my desktop to the second monitor just fine. But when I come back from a...
Vista General
extended desktop problem, Vista 64bit
I have been using a second monitor (Acer AL2216W) with my Vista Home Premium 64bit laptop as an extended desktop and all worked fine until yesterday....
Graphic cards
Vista (Business x32) Extended desktop problem
Hi- I have a Dell Latitude D630 With the Intel 965 graphics chipset. At work, I dock my notebook and use the notebook LCD as the primary display...
Vista hardware & devices
can't extended desktop onto this monitor
HI I have Acer aspire 5310 basic vista with broken screen and I can't extended to the 2 monitor because is not exist in display setting. I can boot...
Graphic cards
Extended Desktop - limited use
I don't fully understand the use of an extended desktop - when I extend my desktop on the external monitor all I get is the background picture from...
Vista General
Changing Extended Desktop
How can I change the direction of the extension for my extended desktop? I am using a laptop and an external monitor. The desktop is now extended...
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
