Vista - Low mic signal
Old 06-14-2006   #1 (permalink)
Angel Massa
Low mic signal
Yesterday I was trying voice recognition on Vista. The feature looks great
on the tutorial but after finishing it and trying to control with voice it
didn't worked as expected. I've noticed that the signal bar was very low so
I checked for mic signal volume. It was already set at 100% but I'm getting
a very low signal.
On Windows XP with same audio hardware and mic I get good signal.
Anyone had similar problems?
Regards,
Angel.
Old 06-14-2006   #2 (permalink)
Balasubramanian Ramanathan
Re: Low mic signal
Yes...its true...i have also having same problem with using voip..with
windows xp the voip was so clear and good. i use voip for calling
landlines..the incoming audio is totally distored and breaks oftne..the same
at the other end, the receiver is not able to hear me properly..slow
transmisson of audio signal and its not clear and broken..it was not
happening in widows xp
"Angel Massa" <angel2@puntweb.com> wrote in message
news:eSx1KF5jGHA.4660@TK2MSFTNGP03.phx.gbl...
> so I checked for mic signal volume. It was already set at 100% but I'm
> getting a very low signal.
> Regards,
> Angel.
Old 06-14-2006   #3 (permalink)
Merzhin
Re: Low mic signal
I got this issue 2 months ago with Skype and I found that checking Mic Boost
in Audio devices manager fixed the problem.
Try to do it.
Control Panel | Manage Audio Devices | Microphone | Properties | Others >
check Microphone Boost box.
Merzhin
Brittany - France
"Balasubramanian Ramanathan" <rbsubramanian@hotmail.com> wrote in message
news:egNGqO5jGHA.1260@TK2MSFTNGP05.phx.gbl...
> same at the other end, the receiver is not able to hear me properly..slow
>> great on the tutorial but after finishing it and trying to control with
>> voice it didn't worked as expected. I've noticed that the signal bar was
>> very low so I checked for mic signal volume. It was already set at 100%
>> but I'm getting a very low signal.
>> Regards,
>> Angel.
Old 06-14-2006   #4 (permalink)
Re: Low mic signal
Yes...i tried the option...stilll it is having problem
"Merzhin" <KerguellecATmsn.com> wrote in message
news:6A0A33D3-E16B-4ADC-91D2-ED70B3A1C8F5@microsoft.com...
>Boost in Audio devices manager fixed the problem.
> Try to do it.
> Merzhin
> Brittany - France
>>> Regards,
>>> Angel.
No tv signal Media Center
No signal sent to VDU General Discussion
Signal strength for DVB-T& signal in Windows Vista Home Premium MC Vista General
WiFi Signal Strength: No Signal Vista networking & sharing
Very low mic signal Vista General
