Vista - My solution for sleep problems
Old 03-27-2007   #1 (permalink)
MarcS
Well I have solved the sleep problem for my computer. My computer would only
go as far as powering down my monitor, but the computer itself would not
sleep. After trying everything (and I do have a wireless keyboard and mouse)
I found my culprit. I have a home network and media sharing was turned on.
Somehow this is what was preventing my computer from going into sleep mode. I
turned off media sharing in the Network and Sharing Center and rebooted my
computer. After that no problem with sleeping at all.
Hope this helps others.
Marc
Old 03-27-2007   #2 (permalink)
jonah
Re: My solution for sleep problems
On Tue, 27 Mar 2007 16:52:27 -0700, MarcS
>Marc
I just use Vallium
8-)
Jonah
Old 03-27-2007   #3 (permalink)
Riffrafter
That's a new one I hadn't heard - thanks. I was going nuts trying to figure
this out and the thing that finally worked for me was turning off the "Wake
on Lan" setting of my NIC card (under Properties, advanced settings I think
from Device Manager). Not sure who posted that gem, but I am in their debt.
I also have Media Sharing turned on but really have no need for it. I'll
probably turn that off too just to be safe.
-Riff
"MarcS" <MarcS@discussions.microsoft.com> wrote in message
news:135E52BC-7DEB-4A8B-ACF7-9E7DED0CCDF4@microsoft.com...
> only
> mouse)
> mode. I
> Marc
help with solution of 64 bit internet problems Network & Sharing
Desktop problems - Solution Vista General
Sleep & Loss of Internet connection solution Vista networking & sharing
Solution to Vista Sleep Problem Vista General
Install Problems Possible Solution>>>> Vista installation & setup
