Vista - Gadget Sidebar Problem
Old 03-27-2007   #1 (permalink)
Shabacca
The message " Windows Sidebar has stopped working" happens frequently when I
reach the desktop in VISTA. Checking online brings no results, so I have to
close the program.
Does anyone have a solution to the problem?
Thanks
Old 08-17-2007   #2 (permalink)
John Bryntze
RE: Gadget Sidebar Problem
This sounds that you have a gadget added that crashes the sidebar.
Close all none default Vista gadgets and check if you get this error again.
If the error disappears, add all none default vista gadgets one by one until
you find the faulting gadget. Then contact the gadget author (can be seen in
"show details") and asked for an updated version if existing.
To read more how a Vista sidebar gadget works:
http://john.bryntze.net/jbkb/index.p...idebar_Gadgets
> close the program.
> Thanks
sidebar: gadget problem General Discussion
sidebar gadget border color problem Vista performance & maintenance
sidebar gadget General Discussion
Gadget Sidebar Vista General
RE: Gadget Sidebar Problem Vista General
