| Guest | Single Click Instead Of Double Click In XP I could, under folders and options, set my mouse so a single click would open an application instead of needing to double click. Not found out how to do this in Vista yet! |
| Guest | Re: Single Click Instead Of Double Click Same way, new location: Control Panel/Folder Options -- Maxwell Bluemeanie ---- "Port Admiral Haynes" <spam.th@t.way> wrote in message news:460ab767$0$22525$fa0fcedb@news.zen.co.uk... > In XP I could, under folders and options, set my mouse so a single click > would open an application instead of needing to double click. > > Not found out how to do this in Vista yet! |
| Guest | Re: Single Click Instead Of Double Click "Max" <max@home.com> wrote in message news:%23tAsd%23WcHHA.4172@TK2MSFTNGP05.phx.gbl... > Same way, new location: > Control Panel/Folder Options > > -- > Maxwell Bluemeanie Easy when you know how! Many thanx |
| How to single click | Vista account administration | |||
| Enable one click instead of double click selection | Vista installation & setup | |||
| My mouse double clicks frequently when I single click it | Vista hardware & devices | |||
| Single Click? | Vista General | |||
| hot to change mouse to single click instead of double click to ope | Vista hardware & devices | |||
