Vista - Program uninstallation problems
Old 06-14-2006   #1 (permalink)
Brian Wescombe
I've tried to install a few Cyberlink programs using Beta build 5384 (Power
Producer 3/Power Director 4 express). They installed (with the program
compatability dialog box appearing), but don't actually work. When I try to
uniinstall them, I get an error that the program is designed for Win
98/2000/XP only, and the uninstall fails (I don't get a program compatibilty
box). Although Vista is only on a spare partitiion, these non-working
programs are using up disc space.
Is there a safe way to remove them?
By the way, PowerProducer (v2 or 3) will not work on an XP machine running
IE7 Beta either, and this program does not require internet access!
Old 06-14-2006   #2 (permalink)
Mark D. VandenBerg
RE: Program uninstallation problems
Is the Vista version you are testing x86 or x64?
I ask this because it could be the uninstall parts of the programs in
question are written in 16-bit, which as everyone knows, will not run in a
64-bit environment.
Old 06-15-2006   #3 (permalink)
Brian Wescombe
Re: Program uninstallation problems
"Mark D. VandenBerg" <MarkDVandenBerg@discussions.microsoft.com> wrote in
message news:B93E148B-5C7E-41F0-BE4E-4D383C957FAD@microsoft.com...
> 64-bit environment.
Sorry, it's Vista 32-bit.
Old 06-15-2006   #4 (permalink)
Mark D. VandenBerg
Sorry, thought I'd take a shot...
> > 64-bit environment.
Automatical uninstallation of my already installed program .NET General
halo 2 uninstallation Vista Games
Uninstallation of Atheros Vista installation & setup
Uninstallation Vista installation & setup
Uninstallation Vista file management
