| Guest | problem with memory (graphics shared memory) would you please answer the Q posted on http://thevistaforums.com/index.php?...57&#entry64257 i don't know but i think it has with shared memory. *I posted the Q on that site. |
| Guest | Re: problem with memory (graphics shared memory) It's sounds like your laptop is just like mine, though mine only has 32MB of memory. Mine . On some PCs you get an option on how much you could share. But that seems totally dependant on the Motherboard maker and the BIOS the OEMS loaded. I had a PC with an onboard video and in the different BIOS released that would take away and then re-add the option of how much to share. On a PC, the easy way to fix it, is to buy a video card and not use the on-board card. On a laptop, if it doesn't have an option in teh BIOS. Don't know how you can stop it. Obviously, you can try and add more system RAM to your laptop if that is an option. Though in your picture you show, 562 in use, that means technically you still have about 400MB left to do whatever. The cached memory is stuff loaded, but possible not in use. If you want to stop Vista from caching anything, you can set the Superfetch service to Stop and either reboot or stop the service manually. You might look at buying a 2GB flash drive, and using the readyboost technology to help out Tturning off stuff like Aero will save you a little ram, though I didn't see any change in ram usage on my laptop. it says I have 372MB of ram in use, and I know 255MB of that is not going to video Finally, it's my understanding that in the AGP-Shared system memory world, the video card only uses that system memory, when it actually needs it. I feel pretty confident that it's not carving out 255MB of ram for video on boot. generally, if you're not playing a 3D game, then you're probably not using very much, if any of the on-board ram. I'm sure there is a tool out there that can tell how much video ram is in actual use, but for basic 2D fuctions of the desktop, I'm sure that number would be within the 64MB on-board ram you have(again, this would be running in classic mode). Does you laptop offer you the option to upgrade the video card ram ? "black2night" <adn3an@hotmail.com.(Donotspam)> wrote in message news:974466F4-CF36-4DA7-9DCF-8E51858C9E6B@microsoft.com... > would you please answer the Q posted on > http://thevistaforums.com/index.php?...57&#entry64257 > > i don't know but i think it has with shared memory. > > *I posted the Q on that site. > |
| Guest | Re: problem with memory (graphics shared memory) Why tell us. I suggest you go to that site and see if they have an answer for you. I don't why you expect an answer here for a question not asked here. Why don't you try asking it. "black2night" <adn3an@hotmail.com.(Donotspam)> wrote in message news:974466F4-CF36-4DA7-9DCF-8E51858C9E6B@microsoft.com... > would you please answer the Q posted on > http://thevistaforums.com/index.php?...57&#entry64257 > > i don't know but i think it has with shared memory. > > *I posted the Q on that site. > |
| Guest | Re: problem with memory (graphics shared memory) thank you for your helpfull response.I'm at this moment downloading drivers & software from ati for my radeon x300, some told me that you could change the shared memory settings from the software since threre is no option to do that in bios. "Dale White" wrote: > It's sounds like your laptop is just like mine, though mine only has 32MB of > memory. Mine . On some PCs you get an option on how much you could share. > But that seems totally dependant on the Motherboard maker and the BIOS the > OEMS loaded. I had a PC with an onboard video and in the different BIOS > released that would take away and then re-add the option of how much to > share. > > On a PC, the easy way to fix it, is to buy a video card and not use the > on-board card. On a laptop, if it doesn't have an option in teh BIOS. Don't > know how you can stop it. > > Obviously, you can try and add more system RAM to your laptop if that is an > option. Though in your picture you show, 562 in use, that means technically > you still have about 400MB left to do whatever. The cached memory is stuff > loaded, but possible not in use. If you want to stop Vista from caching > anything, you can set the Superfetch service to Stop and either reboot or > stop the service manually. > > You might look at buying a 2GB flash drive, and using the readyboost > technology to help out > > Tturning off stuff like Aero will save you a little ram, though I didn't see > any change in ram usage on my laptop. it says I have 372MB of ram in use, > and I know 255MB of that is not going to video > > Finally, it's my understanding that in the AGP-Shared system memory world, > the video card only uses that system memory, when it actually needs it. I > feel pretty confident that it's not carving out 255MB of ram for video on > boot. generally, if you're not playing a 3D game, then you're probably not > using very much, if any of the on-board ram. I'm sure there is a tool out > there that can tell how much video ram is in actual use, but for basic 2D > fuctions of the desktop, I'm sure that number would be within the 64MB > on-board ram you have(again, this would be running in classic mode). > > Does you laptop offer you the option to upgrade the video card ram ? > > > "black2night" <adn3an@hotmail.com.(Donotspam)> wrote in message > news:974466F4-CF36-4DA7-9DCF-8E51858C9E6B@microsoft.com... > > would you please answer the Q posted on > > http://thevistaforums.com/index.php?...57&#entry64257 > > > > i don't know but i think it has with shared memory. > > > > *I posted the Q on that site. > > > > > |
| Shared graphics memory in vista | Vista hardware & devices | |||
| Dedicated Graphical Memory & Shared System Memory | Vista hardware & devices | |||
| Shared Memory | Vista performance & maintenance | |||
| Shared memory with graphics card | Vista General | |||
| Ati Radeon 9550 using system memory? 511mb shared system memory. | Vista hardware & devices | |||
