| | delete drive letter of startvolume? Hello on the first disk is XP installed, on second vista. That means vistas directory boot is on the xp drive Now I do not want to see the XP disk in vista therefore I try to delete the driveletter d: in Diskmanager But it fails with error message: Teh driveletter of the volume could not be deleted. Because the volume is a start or system volume. (translated from german:-) Why does vista need the startvolume? it only contains the bootloader I thought. How can I make the disk invisible? THanks for any help Michael |
| | Re: delete drive letter of startvolume? Hi Michael, You can't, at least not the way you're trying to do it. The system has that volume marked as the boot volume. In order for any OS to load, that volume *has* to be accessible. Right now, the system's bios loads the mbr on that disk, which then points to the boot files on that disk. Then the boot files point to the actual location of the Vista installation on the other drive. If you remove it from the equation, not only will you lose the redirect, but your pc will also lose its designated boot device. Nothing would boot from any hard drive. By the way, deleting that drive in diskmanager would not make XP invisible, it would remove that partition and everything on it (rendering your XP installation unbootable). You would need to use a third party boot manager, and then do a startup repair on Vista to move the boot files. The boot manager must be capable of allowing each OS to boot from its own system volume, and of hiding other partitions/volumes from it. This is a fairly complicated task, not something for the novice. There are several available that can do it, my preference being BootIT NG from terabyteunlimited, but it's not the only one. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org "MIchael" <Heirichsen@web.de> wrote in message news:OVJEegpcHHA.284@TK2MSFTNGP05.phx.gbl... > Hello > on the first disk is XP installed, on second vista. > That means vistas directory boot is on the xp drive > Now I do not want to see the XP disk in vista therefore I try to delete > the driveletter d: in Diskmanager > But it fails with error message: > > Teh driveletter of the volume could not be deleted. Because the volume is > a start or system volume. > (translated from german:-) > Why does vista need the startvolume? it only contains the bootloader I > thought. > How can I make the disk invisible? > THanks for any help > Michael > > |
| | Re: delete drive letter of startvolume? It does me sorrow that I can not understand your very good English. Perhaps you could explain your problem in German is this group: news://msnews.microsoft.com/microsof...a.installation "MIchael" <Heirichsen@web.de> wrote in message news:OVJEegpcHHA.284@TK2MSFTNGP05.phx.gbl... > Hello > on the first disk is XP installed, on second vista. > That means vistas directory boot is on the xp drive > Now I do not want to see the XP disk in vista therefore I try to delete the > driveletter d: in Diskmanager > But it fails with error message: > > Teh driveletter of the volume could not be deleted. Because the volume is a > start or system volume. > (translated from german:-) > Why does vista need the startvolume? it only contains the bootloader I > thought. > How can I make the disk invisible? > THanks for any help > Michael > > |
| | Re: delete drive letter of startvolume? You should be able to go into your BIOS and change the Vista drive to the first hard drive in boot priority. With the Vista install DVD as first in boot priority, run the startup repair "MIchael" <Heirichsen@web.de> wrote in message news:OVJEegpcHHA.284@TK2MSFTNGP05.phx.gbl... > Hello > on the first disk is XP installed, on second vista. > That means vistas directory boot is on the xp drive > Now I do not want to see the XP disk in vista therefore I try to delete > the driveletter d: in Diskmanager > But it fails with error message: > > Teh driveletter of the volume could not be deleted. Because the volume is > a start or system volume. > (translated from german:-) > Why does vista need the startvolume? it only contains the bootloader I > thought. > How can I make the disk invisible? > THanks for any help > Michael > > |
| | Re: delete drive letter of startvolume? Why are you suggesting that a person posting in English post to another group in German? We understand him perfectly. -- ---- Crosspost, do not multipost http://www.blakjak.demon.co.uk/mul_crss.htm How to ask a question http://support.microsoft.com/kb/555375 How to Post http://www.dts-l.org/goodpost.htm http://www.db-pc.com _________________________________________________________________________________ "Michael Jennings" <metarhyme@gmail.com> wrote in message news:eO4c6mrcHHA.588@TK2MSFTNGP06.phx.gbl... > It does me sorrow that I can not understand your very good English. > Perhaps you could explain your problem in German is this group: > news://msnews.microsoft.com/microsof...a.installation > |
| | #6 (permalink) |
| | Re: delete drive letter of startvolume? He may not understand *us* perfectly. Your criticism of my response does not notice the fact that his computer speaks German as does he, presumably. What is he trying to do? Well, it's either to get rid of XP altogether, or it's to hide the Vista volume from XP using Windows - it could be either one or the other. Rather than ask him to clarify, I posted a newsgroup which may be useful to the OP. My German is infinitely inferior to his English. If I had seen Rick Rogers' and John Barnes' responses I wouldn't have responded to MIchael's post, because they nail down one possibility. I wanted him to clearly communicate his difficulty and receive a response he could understand and act upon. There it sat. I knew both answers. How to respond? Give the kid a break with a link to install auf Deutsch. "David B." <brooks.dj@nospam.hotmail.com> wrote in message news:71EA3D98-E293-4BBC-9449-5A84FD1EDEE5@microsoft.com... > Why are you suggesting that a person posting in English post to another > group in German? We understand him perfectly. > > "Michael Jennings" <metarhyme@gmail.com> wrote in message > news:eO4c6mrcHHA.588@TK2MSFTNGP06.phx.gbl... >> It does me sorrow that I can not understand your very good English. >> Perhaps you could explain your problem in German is this group: >> news://msnews.microsoft.com/microsof...a.installation >> > |
| | #7 (permalink) |
| | Re: delete drive letter of startvolume? Having a bad day are we? It was a simple question, how is that criticizing? He seems to have a good handle on English, his post was actually more understandable than some I've seen where English is there native language. -- ---- Crosspost, do not multipost http://www.blakjak.demon.co.uk/mul_crss.htm How to ask a question http://support.microsoft.com/kb/555375 How to Post http://www.dts-l.org/goodpost.htm http://www.db-pc.com _________________________________________________________________________________ "Michael Jennings" <metarhyme@gmail.com> wrote in message news:u7HcKfvcHHA.3976@TK2MSFTNGP06.phx.gbl... > He may not understand *us* perfectly. Your criticism of my response does > not notice the fact that his computer speaks German as does he, > presumably. > What is he trying to do? Well, it's either to get rid of XP altogether, or > it's to > hide the Vista volume from XP using Windows - it could be either one or > the > other. Rather than ask him to clarify, I posted a newsgroup which may be > useful to the OP. My German is infinitely inferior to his English. > > If I had seen Rick Rogers' and John Barnes' responses I wouldn't have > responded to MIchael's post, because they nail down one possibility. > I wanted him to clearly communicate his difficulty and receive a response > he could understand and act upon. There it sat. I knew both answers. > How to respond? Give the kid a break with a link to install auf Deutsch. > |
| | #8 (permalink) |
| | Re: delete drive letter of startvolume? Yes, I am transitioning from WTF to FTS. Their it is, "there native language." "David B." <brooks.dj@nospam.hotmail.com> wrote in message news:55276F47-BBAB-4CA4-8F7F-6FF8EE506BC4@microsoft.com... > Having a bad day are we? It was a simple question, how is that criticizing? > He seems to have a good handle on English, his post was actually more > understandable than some I've seen where English is there native language. |
| | #9 (permalink) |
| | Re: delete drive letter of startvolume? And I bet you've never made a grammar mistake in your life, I could find all kinds of problems with your OP "It does me sorrow that I can not understand your very good English. Perhaps you could explain your problem in German is this group:" but I have better things to do, go find someone else to whine to. -- ---- Crosspost, do not multipost http://www.blakjak.demon.co.uk/mul_crss.htm How to ask a question http://support.microsoft.com/kb/555375 How to Post http://www.dts-l.org/goodpost.htm http://www.db-pc.com _________________________________________________________________________________ "Michael Jennings" <metarhyme@gmail.com> wrote in message news:u7XlzFwcHHA.2316@TK2MSFTNGP04.phx.gbl... > Yes, I am transitioning from WTF to FTS. Their it is, "there native > language." > > "David B." <brooks.dj@nospam.hotmail.com> wrote in message > news:55276F47-BBAB-4CA4-8F7F-6FF8EE506BC4@microsoft.com... >> Having a bad day are we? It was a simple question, how is that >> criticizing? >> He seems to have a good handle on English, his post was actually more >> understandable than some I've seen where English is there native >> language. > > |
| | #10 (permalink) |
| | Re: delete drive letter of startvolume? Yup, there's a typo. You asked me to explain my post. I explained my post. I don't think you examined the original post or my reply to you carefully. I expressed my exasperation. You then accused me of complaining, which you do a lot of. You may be unaware of that. You could check to see if this is so: http://groups.google.com/groups/prof...G1szzZ9g&hl=en I think you put your finger on something - the shift from problem solving to complaining in this group. Thanks for encouraging me to leave. "David B." <brooks.dj@nospam.hotmail.com> wrote in message news:eoQxqKwcHHA.1312@TK2MSFTNGP06.phx.gbl... > And I bet you've never made a grammar mistake in your life, I could find all > kinds of problems with your OP "It does me sorrow that I can not understand > your very good English. Perhaps you could explain your problem in German is > this group:" but I have better things to do, go find someone else to whine > to. > > "Michael Jennings" <metarhyme@gmail.com> wrote in message > news:u7XlzFwcHHA.2316@TK2MSFTNGP04.phx.gbl... >> Yes, I am transitioning from WTF to FTS. Their it is, "there native >> language." >> >> "David B." <brooks.dj@nospam.hotmail.com> wrote in message >> news:55276F47-BBAB-4CA4-8F7F-6FF8EE506BC4@microsoft.com... >>> Having a bad day are we? It was a simple question, how is that >>> criticizing? >>> He seems to have a good handle on English, his post was actually more >>> understandable than some I've seen where English is there native >>> language. >> >> > |
| Flash Drive has no drive letter... Not in Disk Management | Vista hardware & devices | |||
| Phantom CD Drive after reassigning Recovery Partition drive letter | Vista installation & setup | |||
| LastWriteTime and Locating the drive letter of a flash drive. | PowerShell | |||
| USB drive letters and mapped drive letter issues | Vista hardware & devices | |||
