| | Vista Upgrade-Sound not working I just upgraded my HP Pavilion m1000y Media Center to Vista Ultimate 32-bit. The sound button on the bottom right corner has an X over it and says "No Audio Output Device is Installed." When I go to the Device Manager, under "Sound, video, and game controllers' it shows "Hauppage WinTV-PVR PCI II (Encoder-16)". Then, under other devices, it shows "Multimedia Audio Controller" with a yellow exclamation point over it. How should I go about solving this problem? Thank you. |
| | Re: Vista Upgrade-Sound not working You can do 2 things to resolve this: 1. In device manager, right click on the multimedia audio controller and then click on update driver. Follow the instructions to search for the driver and, if found, install it. This may not give you the latest & greatest driver for your sound. It also may not know what to get. 2. Do you know what sound card you have? If you do not have a Vista driver for it already, go to its website and see if one is available. Read the instructions and install accordingly. I know my install came up similarly for Creative Audigy 2zs. I got the driver off their site, installed and had sound after a reboot. Good luck. John G. "Anish" <Anish@discussions.microsoft.com> wrote in message news:3302E2EE-3FDD-4745-A1A1-B6ACD018345D@microsoft.com... >I just upgraded my HP Pavilion m1000y Media Center to Vista Ultimate >32-bit. > The sound button on the bottom right corner has an X over it and says "No > Audio Output Device is Installed." When I go to the Device Manager, under > "Sound, video, and game controllers' it shows "Hauppage WinTV-PVR PCI II > (Encoder-16)". Then, under other devices, it shows "Multimedia Audio > Controller" with a yellow exclamation point over it. How should I go about > solving this problem? Thank you. |
| | Re: Vista Upgrade-Sound not working I did try that and it didn't work. Also, I did to a clean install of Vista. I thought the Hauppage input was my sound card? How do I found what sound card I have? Thanks. "John Gallagher" wrote: > You can do 2 things to resolve this: > > 1. In device manager, right click on the multimedia audio controller and > then click on update driver. Follow the instructions to search for the > driver and, if found, install it. This may not give you the latest & > greatest driver for your sound. It also may not know what to get. > 2. Do you know what sound card you have? If you do not have a Vista driver > for it already, go to its website and see if one is available. Read the > instructions and install accordingly. > > I know my install came up similarly for Creative Audigy 2zs. I got the > driver off their site, installed and had sound after a reboot. > > Good luck. > > John G. > > "Anish" <Anish@discussions.microsoft.com> wrote in message > news:3302E2EE-3FDD-4745-A1A1-B6ACD018345D@microsoft.com... > >I just upgraded my HP Pavilion m1000y Media Center to Vista Ultimate > >32-bit. > > The sound button on the bottom right corner has an X over it and says "No > > Audio Output Device is Installed." When I go to the Device Manager, under > > "Sound, video, and game controllers' it shows "Hauppage WinTV-PVR PCI II > > (Encoder-16)". Then, under other devices, it shows "Multimedia Audio > > Controller" with a yellow exclamation point over it. How should I go about > > solving this problem? Thank you. > > |
| | Re: Vista Upgrade-Sound not working Anish wrote: > I just upgraded my HP Pavilion m1000y Media Center to Vista Ultimate > 32-bit. The sound button on the bottom right corner has an X over it > and says "No Audio Output Device is Installed." When I go to the > Device Manager, under "Sound, video, and game controllers' it shows > "Hauppage WinTV-PVR PCI II (Encoder-16)". Then, under other devices, > it shows "Multimedia Audio Controller" with a yellow exclamation > point over it. How should I go about solving this problem? Thank you. ===================================== Apparently you need a Vista compatible driver. Based on the info I could find at the following Hauppage sites...the driver you need is not available. Maybe contacting Hauppauge Support would be worth a try. Software for WinTV-PVR-pci http://www.hauppauge.com/pages/suppo...rt_pvrpci.html Hauppauge Support http://www.hauppauge.com/pages/support/support.html Contact Information http://www.hauppauge.com/pages/contact/contact_us.html -- John Inzer MS Picture It! - Digital Image MVP Digital Image Highlights and FAQs http://tinyurl.com/aczzp Notice This is not tech support I am a volunteer Solutions that work for me may not work for you Proceed at your own risk |
| | Re: Vista Upgrade-Sound not working The Hauppauge card is a video pvr card -- NOT an audio controller Right click the Multimedia Audio Controller icon in Device Manager and check to see who the manufacturer is and then download the appropriate Vista drivers from their web site. "John Inzer" <oobie@doobie.xyz> wrote in message news:ONoUOxucHHA.2416@TK2MSFTNGP04.phx.gbl... > Anish wrote: >> I just upgraded my HP Pavilion m1000y Media Center to Vista Ultimate >> 32-bit. The sound button on the bottom right corner has an X over it >> and says "No Audio Output Device is Installed." When I go to the >> Device Manager, under "Sound, video, and game controllers' it shows >> "Hauppage WinTV-PVR PCI II (Encoder-16)". Then, under other devices, >> it shows "Multimedia Audio Controller" with a yellow exclamation >> point over it. How should I go about solving this problem? Thank you. > ===================================== > Apparently you need a Vista compatible driver. > > Based on the info I could find at the following > Hauppage sites...the driver you need is not > available. Maybe contacting Hauppauge Support > would be worth a try. > > Software for WinTV-PVR-pci > http://www.hauppauge.com/pages/suppo...rt_pvrpci.html > > Hauppauge Support > http://www.hauppauge.com/pages/support/support.html > > Contact Information > http://www.hauppauge.com/pages/contact/contact_us.html > > -- > John Inzer > MS Picture It! - > Digital Image MVP > > Digital Image > Highlights and FAQs > http://tinyurl.com/aczzp > > Notice > This is not tech support > I am a volunteer > > Solutions that work for > me may not work for you > > Proceed at your own risk > > |
| | #6 (permalink) |
| | Re: Vista Upgrade-Sound not working Go to the HP website, and look up the specs for your computer. you should also be able to download drivers from the HP support site, but if not at least it should tell you what sound card you have. "Anish" <Anish@discussions.microsoft.com> wrote in message news:FB5E90BA-7656-4B65-BF80-3DBDF21E440C@microsoft.com... >I did try that and it didn't work. Also, I did to a clean install of Vista. >I > thought the Hauppage input was my sound card? How do I found what sound > card > I have? Thanks. > > > "John Gallagher" wrote: > >> You can do 2 things to resolve this: >> >> 1. In device manager, right click on the multimedia audio controller and >> then click on update driver. Follow the instructions to search for the >> driver and, if found, install it. This may not give you the latest & >> greatest driver for your sound. It also may not know what to get. >> 2. Do you know what sound card you have? If you do not have a Vista >> driver >> for it already, go to its website and see if one is available. Read the >> instructions and install accordingly. >> >> I know my install came up similarly for Creative Audigy 2zs. I got the >> driver off their site, installed and had sound after a reboot. >> >> Good luck. >> >> John G. >> >> "Anish" <Anish@discussions.microsoft.com> wrote in message >> news:3302E2EE-3FDD-4745-A1A1-B6ACD018345D@microsoft.com... >> >I just upgraded my HP Pavilion m1000y Media Center to Vista Ultimate >> >32-bit. >> > The sound button on the bottom right corner has an X over it and says >> > "No >> > Audio Output Device is Installed." When I go to the Device Manager, >> > under >> > "Sound, video, and game controllers' it shows "Hauppage WinTV-PVR PCI >> > II >> > (Encoder-16)". Then, under other devices, it shows "Multimedia Audio >> > Controller" with a yellow exclamation point over it. How should I go >> > about >> > solving this problem? Thank you. >> >> |
| | #7 (permalink) |
| | Re: Vista Upgrade-Sound not working The Manufacturer is unknown. "Cal Bear '66" wrote: > The Hauppauge card is a video pvr card -- NOT an audio controller > > Right click the Multimedia Audio Controller icon in Device Manager and > check to see who the manufacturer is and then download the appropriate > Vista drivers from their web site. > > > "John Inzer" <oobie@doobie.xyz> wrote in message > news:ONoUOxucHHA.2416@TK2MSFTNGP04.phx.gbl... > > Anish wrote: > >> I just upgraded my HP Pavilion m1000y Media Center to Vista Ultimate > >> 32-bit. The sound button on the bottom right corner has an X over it > >> and says "No Audio Output Device is Installed." When I go to the > >> Device Manager, under "Sound, video, and game controllers' it shows > >> "Hauppage WinTV-PVR PCI II (Encoder-16)". Then, under other devices, > >> it shows "Multimedia Audio Controller" with a yellow exclamation > >> point over it. How should I go about solving this problem? Thank you. > > ===================================== > > Apparently you need a Vista compatible driver. > > > > Based on the info I could find at the following > > Hauppage sites...the driver you need is not > > available. Maybe contacting Hauppauge Support > > would be worth a try. > > > > Software for WinTV-PVR-pci > > http://www.hauppauge.com/pages/suppo...rt_pvrpci.html > > > > Hauppauge Support > > http://www.hauppauge.com/pages/support/support.html > > > > Contact Information > > http://www.hauppauge.com/pages/contact/contact_us.html > > > > -- > > John Inzer > > MS Picture It! - > > Digital Image MVP > > > > Digital Image > > Highlights and FAQs > > http://tinyurl.com/aczzp > > > > Notice > > This is not tech support > > I am a volunteer > > > > Solutions that work for > > me may not work for you > > > > Proceed at your own risk > > > > > |
| | #8 (permalink) |
| | Re: Vista Upgrade-Sound not working Click on Details tab of the devices Properties page and select Manufacturer from the Property drop down list. Or call HP. I have a HP a1540n and the built in audio controller is Realtek. Also check the HP site and see if the audio controller is listed on the specifications page for your m1000y. NOTHING from Hauppauge will help you. "Anish" <Anish@discussions.microsoft.com> wrote in message news:1203D7F9-EF7A-4B19-9D9A-AC6AA054DB58@microsoft.com... > The Manufacturer is unknown. > > "Cal Bear '66" wrote: > >> The Hauppauge card is a video pvr card -- NOT an audio controller >> >> Right click the Multimedia Audio Controller icon in Device Manager and >> check to see who the manufacturer is and then download the appropriate >> Vista drivers from their web site. >> >> >> "John Inzer" <oobie@doobie.xyz> wrote in message >> news:ONoUOxucHHA.2416@TK2MSFTNGP04.phx.gbl... >> > Anish wrote: >> >> I just upgraded my HP Pavilion m1000y Media Center to Vista Ultimate >> >> 32-bit. The sound button on the bottom right corner has an X over it >> >> and says "No Audio Output Device is Installed." When I go to the >> >> Device Manager, under "Sound, video, and game controllers' it shows >> >> "Hauppage WinTV-PVR PCI II (Encoder-16)". Then, under other devices, >> >> it shows "Multimedia Audio Controller" with a yellow exclamation >> >> point over it. How should I go about solving this problem? Thank you. >> > ===================================== >> > Apparently you need a Vista compatible driver. >> > >> > Based on the info I could find at the following >> > Hauppage sites...the driver you need is not >> > available. Maybe contacting Hauppauge Support >> > would be worth a try. >> > >> > Software for WinTV-PVR-pci >> > http://www.hauppauge.com/pages/suppo...rt_pvrpci.html >> > >> > Hauppauge Support >> > http://www.hauppauge.com/pages/support/support.html >> > >> > Contact Information >> > http://www.hauppauge.com/pages/contact/contact_us.html >> > >> > -- >> > John Inzer >> > MS Picture It! - >> > Digital Image MVP >> > >> > Digital Image >> > Highlights and FAQs >> > http://tinyurl.com/aczzp >> > >> > Notice >> > This is not tech support >> > I am a volunteer >> > >> > Solutions that work for >> > me may not work for you >> > >> > Proceed at your own risk >> > >> > >> |
| | #9 (permalink) |
| | Re: Vista Upgrade-Sound not working Also see if the HP site has updated Vista audio drivers for your m1000y. Or check the XP updates page and it might list the audio controller there "Cal Bear '66" <xxx@xxx.org> wrote in message news:C4D6F987-3168-4A3C-B0EB-676CDFEB2F9E@microsoft.com... Click on Details tab of the devices Properties page and select Manufacturer from the Property drop down list. Or call HP. I have a HP a1540n and the built in audio controller is Realtek. Also check the HP site and see if the audio controller is listed on the specifications page for your m1000y. NOTHING from Hauppauge will help you. "Anish" <Anish@discussions.microsoft.com> wrote in message news:1203D7F9-EF7A-4B19-9D9A-AC6AA054DB58@microsoft.com... > The Manufacturer is unknown. > > "Cal Bear '66" wrote: > >> The Hauppauge card is a video pvr card -- NOT an audio controller >> >> Right click the Multimedia Audio Controller icon in Device Manager and >> check to see who the manufacturer is and then download the appropriate >> Vista drivers from their web site. >> >> >> "John Inzer" <oobie@doobie.xyz> wrote in message >> news:ONoUOxucHHA.2416@TK2MSFTNGP04.phx.gbl... >> > Anish wrote: >> >> I just upgraded my HP Pavilion m1000y Media Center to Vista Ultimate >> >> 32-bit. The sound button on the bottom right corner has an X over it >> >> and says "No Audio Output Device is Installed." When I go to the >> >> Device Manager, under "Sound, video, and game controllers' it shows >> >> "Hauppage WinTV-PVR PCI II (Encoder-16)". Then, under other devices, >> >> it shows "Multimedia Audio Controller" with a yellow exclamation >> >> point over it. How should I go about solving this problem? Thank you. >> > ===================================== >> > Apparently you need a Vista compatible driver. >> > >> > Based on the info I could find at the following >> > Hauppage sites...the driver you need is not >> > available. Maybe contacting Hauppauge Support >> > would be worth a try. >> > >> > Software for WinTV-PVR-pci >> > http://www.hauppauge.com/pages/suppo...rt_pvrpci.html >> > >> > Hauppauge Support >> > http://www.hauppauge.com/pages/support/support.html >> > >> > Contact Information >> > http://www.hauppauge.com/pages/contact/contact_us.html >> > >> > -- >> > John Inzer >> > MS Picture It! - >> > Digital Image MVP >> > >> > Digital Image >> > Highlights and FAQs >> > http://tinyurl.com/aczzp >> > >> > Notice >> > This is not tech support >> > I am a volunteer >> > >> > Solutions that work for >> > me may not work for you >> > >> > Proceed at your own risk >> > >> > >> |
| | #10 (permalink) |
| | Re: Vista Upgrade-Sound not working Here is a new update. Vista actually installed a driver for Realtek AC'97 Audio. That eliminated the "No Audio Output Device is Installed" problem. It says the sound is on, and that the speakers are working, but no sound is coming. The multimedia controller still has its error message, but, I was prompted to go to the Creative website to download a driver for Creative Audigy Audio Processor (WDM). What is that? "Cal Bear '66" wrote: > Also see if the HP site has updated Vista audio drivers for your m1000y. > Or check the XP updates page and it might list the audio controller there > > > "Cal Bear '66" <xxx@xxx.org> wrote in message > news:C4D6F987-3168-4A3C-B0EB-676CDFEB2F9E@microsoft.com... > Click on Details tab of the devices Properties page and select > Manufacturer from the Property drop down list. > Or call HP. I have a HP a1540n and the built in audio controller is > Realtek. > Also check the HP site and see if the audio controller is listed on the > specifications page for your m1000y. > NOTHING from Hauppauge will help you. > > > "Anish" <Anish@discussions.microsoft.com> wrote in message > news:1203D7F9-EF7A-4B19-9D9A-AC6AA054DB58@microsoft.com... > > The Manufacturer is unknown. > > > > "Cal Bear '66" wrote: > > > >> The Hauppauge card is a video pvr card -- NOT an audio controller > >> > >> Right click the Multimedia Audio Controller icon in Device Manager and > >> check to see who the manufacturer is and then download the appropriate > >> Vista drivers from their web site. > >> > >> > >> "John Inzer" <oobie@doobie.xyz> wrote in message > >> news:ONoUOxucHHA.2416@TK2MSFTNGP04.phx.gbl... > >> > Anish wrote: > >> >> I just upgraded my HP Pavilion m1000y Media Center to Vista Ultimate > >> >> 32-bit. The sound button on the bottom right corner has an X over it > >> >> and says "No Audio Output Device is Installed." When I go to the > >> >> Device Manager, under "Sound, video, and game controllers' it shows > >> >> "Hauppage WinTV-PVR PCI II (Encoder-16)". Then, under other devices, > >> >> it shows "Multimedia Audio Controller" with a yellow exclamation > >> >> point over it. How should I go about solving this problem? Thank > you. > >> > ===================================== > >> > Apparently you need a Vista compatible driver. > >> > > >> > Based on the info I could find at the following > >> > Hauppage sites...the driver you need is not > >> > available. Maybe contacting Hauppauge Support > >> > would be worth a try. > >> > > >> > Software for WinTV-PVR-pci > >> > http://www.hauppauge.com/pages/suppo...rt_pvrpci.html > >> > > >> > Hauppauge Support > >> > http://www.hauppauge.com/pages/support/support.html > >> > > >> > Contact Information > >> > http://www.hauppauge.com/pages/contact/contact_us.html > >> > > >> > -- > >> > John Inzer > >> > MS Picture It! - > >> > Digital Image MVP > >> > > >> > Digital Image > >> > Highlights and FAQs > >> > http://tinyurl.com/aczzp > >> > > >> > Notice > >> > This is not tech support > >> > I am a volunteer > >> > > >> > Solutions that work for > >> > me may not work for you > >> > > >> > Proceed at your own risk > >> > > >> > > >> > |
| No sound since Vista upgrade | Sound & Audio | |||
| Sound problems after upgrade to Vista | Vista hardware & devices | |||
| No Sound With Upgrade To Win Vista | Vista General | |||
| Sound (and brightness) not working, after Vista Upgrade | Vista hardware & devices | |||
| Vista upgrade- but no sound | Vista General | |||
