Vista - Microphone volume adjustment
Old 03-30-2007   #1 (permalink)
Fernando_R
Where is the microphone volume adjustment control?
Using Control Panel I found an "sensitivity control" and "balance"(I'm
translating becouse my Windows is in Brazilien Portuguese), but none of this
is the same volume adjustment that can be found at Windows XP with the
"Mixer".
The microphone sound now is too low in comparation with the volume I have
with Windows XP in other machine (with the same microphone). I put the two
available adjustment ("sensitivity" and "balance") at the maximun (+20,0 dB
and +10,5 dB) and still too low...
I'm using Windows Vista Home Premium 32 with Intel DG965RY - Audio Sigmatel
92XX on board.
Old 03-30-2007   #2 (permalink)
dev
Re: Microphone volume adjustment
> "Mixer".
> 92XX on board.
In this card, which is not the same as yours, I right-click on the
speaker icon, and see a level control under the RECORDING
TAB|PROPERTIES|LEVEL tab
Old 03-30-2007   #3 (permalink)
Daze N. Knights
Fernando:
It sounds like you already have the volume level cranked all the way up
and are, nevertheless, still experiencing a low-volume microphone
problem, as am I, and others, as well. I'm running Vista Ultimate 32
with Intel DP965LT with Sigmatel on board, but have the same problem
even using a SoundBlaster Audigy SE sound card with the latest Vista
drivers, so the problem is not limited to Sigmatel audio. I've
troubleshooted this problem up and down to no avail, thus far, and you
can read through a discussion of it, if you like, in the Creative
Discussion Forums at:
http://forums.creative.com/creativel...cending&page=1
or TinyURL: http://preview.tinyurl.com/2tslrt
Daze
> this is the same volume adjustment that can be found at Windows XP with
> the "Mixer".
> have with Windows XP in other machine (with the same microphone). I put
> the two available adjustment ("sensitivity" and "balance") at the
> maximun (+20,0 dB and +10,5 dB) and still too low...
> Sigmatel 92XX on board.
Automatic Volume Adjustment Sound & Audio
overall volume adjustment when synchronizing music Vista music pictures video
microphone volume Vista hardware & devices
Very low microphone volume Vista hardware & devices
Microphone volume... Vista performance & maintenance
