| Guest | Can't create system restore points I am running Windows Vista Home Premium and Windows XP Home in a dual boot raid 0 configuration. I'm aware that booting into Xp removes the restore points from Vista. However, I cannot automatically create any restore points in Vista. I can manually create a restore point but it will disappear when I reboot the system. I am rebooting into Vista, not xp and it still will show no restore points. Any advise would be appreciated |
| Guest | Re: Can't create system restore points Run cmd.exe as administrator, then vssadmin list writers command. Do you see any error on the screen? Run vssadmin list shadowstorage. Do you find allocated storage space assigned to your partition? -- M. [Windows - Shell/User MVP] /before private reply change px with pl in my e-mail address/ "rwolds9" <rwolds9@discussions.microsoft.com> wrote in message news:EB90434C-DBBE-4B03-B743-F25DEE15E3C8@microsoft.com... >I am running Windows Vista Home Premium and Windows XP Home in a dual >boot > raid 0 configuration. I'm aware that booting into Xp removes the > restore > points from Vista. However, I cannot automatically create any restore > points > in Vista. I can manually create a restore point but it will disappear > when I > reboot the system. I am rebooting into Vista, not xp and it still will > show > no restore points. Any advise would be appreciated |
| Guest | Re: Can't create system restore points "Michal Kawecki" wrote: > Run cmd.exe as administrator, then vssadmin list writers command. Do you > see any error on the screen? Run vssadmin list shadowstorage. Do you > find allocated storage space assigned to your partition? > -- > M. [Windows - Shell/User MVP] > /before private reply change px with pl in my e-mail address/ > > "rwolds9" <rwolds9@discussions.microsoft.com> wrote in message > news:EB90434C-DBBE-4B03-B743-F25DEE15E3C8@microsoft.com... > >I am running Windows Vista Home Premium and Windows XP Home in a dual > >boot > > raid 0 configuration. I'm aware that booting into Xp removes the > > restore > > points from Vista. However, I cannot automatically create any restore > > points > > in Vista. I can manually create a restore point but it will disappear > > when I > > reboot the system. I am rebooting into Vista, not xp and it still will > > show > > no restore points. Any advise would be appreciated > > > The response was " no items found that satisfy the query" |
| Guest | Re: Can't create system restore points "rwolds9" <rwolds9@discussions.microsoft.com> wrote in message news:C38B2731-4A82-4AB8-86DF-6DA5F8F79D70@microsoft.com... > > "Michal Kawecki" wrote: > >> Run cmd.exe as administrator, then vssadmin list writers command. Do >> you >> see any error on the screen? Run vssadmin list shadowstorage. Do you >> find allocated storage space assigned to your partition? > > > The response was " no items found that satisfy the query" Hm. Turn off System Restore on C:, then turn it on again. It will force allocating a space for Shadow Copy storage area on this partition. Then create one restore point and rerun those vssadmin commands. There must be no error from any writer. Take a look into Event Viewer, maybe there are registered errors from VSS or volsnap. -- M. [Windows - Shell/User MVP] /before private reply change px with pl in my e-mail address/ |
| Guest | Re: Can't create system restore points "Michal Kawecki" wrote: > "rwolds9" <rwolds9@discussions.microsoft.com> wrote in message > news:C38B2731-4A82-4AB8-86DF-6DA5F8F79D70@microsoft.com... > > > > "Michal Kawecki" wrote: > > > >> Run cmd.exe as administrator, then vssadmin list writers command. Do > >> you > >> see any error on the screen? Run vssadmin list shadowstorage. Do you > >> find allocated storage space assigned to your partition? > > > > > > The response was " no items found that satisfy the query" > > > Hm. Turn off System Restore on C:, then turn it on again. It will force > allocating a space for Shadow Copy storage area on this partition. Then > create one restore point and rerun those vssadmin commands. There must > be no error from any writer. > > Take a look into Event Viewer, maybe there are registered errors from > VSS or volsnap. > -- > M. [Windows - Shell/User MVP] > /before private reply change px with pl in my e-mail address/ > > It showed the allocated shadowcopy space,maximum space etc. Looking at the event viewer, there are volsnap and vss errors logged. There were 29 volsnap errors and 46 vss errors in the six weeks I've had Vista installed. |
| | #6 (permalink) |
| Guest | Re: Can't create system restore points "rwolds9" <rwolds9@discussions.microsoft.com> wrote in message news:41C4590D-8138-4231-8120-EA79EBF18BA4@microsoft.com... > "Michal Kawecki" wrote: >> >> Take a look into Event Viewer, maybe there are registered errors from >> VSS or volsnap. >> >> It showed the allocated shadowcopy space,maximum space etc. So, maybe it will work from now. Of course, do not run XP anymore because your problem will repeat. > Looking at the event viewer, there are volsnap and vss errors logged. > There > were 29 volsnap errors and 46 vss errors in the six weeks I've had > Vista > installed. Do you have any new errors after this repair? If so, be more detailed. -- M. [Windows - Shell/User MVP] /before private reply change px with pl in my e-mail address/ |
| | #7 (permalink) |
| Guest | Re: Can't create system restore points "Michal Kawecki" wrote: > "rwolds9" <rwolds9@discussions.microsoft.com> wrote in message > news:41C4590D-8138-4231-8120-EA79EBF18BA4@microsoft.com... > > "Michal Kawecki" wrote: > >> > >> Take a look into Event Viewer, maybe there are registered errors from > >> VSS or volsnap. > >> > >> It showed the allocated shadowcopy space,maximum space etc. > > So, maybe it will work from now. Of course, do not run XP anymore > because your problem will repeat. > > > Looking at the event viewer, there are volsnap and vss errors logged. > > There > > were 29 volsnap errors and 46 vss errors in the six weeks I've had > > Vista > > installed. > > Do you have any new errors after this repair? If so, be more detailed. > -- > M. [Windows - Shell/User MVP] > /before private reply change px with pl in my e-mail address/ > > No, the behavior is the same. When I opened system restore, it said no restore points were created. It also registered a volsnap error. Again, I havent booted into XP for days.I,m wondering if it could be related to how I set up the system. I installed Xp first on the raid volume and then installed vista on the other partition. Even though they are on separate partitions, does xp always see vista? Or, is there a problem with my Vista causing the restore to not function automatically? |
| | #8 (permalink) |
| Guest | Re: Can't create system restore points "rwolds9" wrote:The exact error was " shadow copies of volume C: were aborted during detection > > > "Michal Kawecki" wrote: > > > "rwolds9" <rwolds9@discussions.microsoft.com> wrote in message > > news:41C4590D-8138-4231-8120-EA79EBF18BA4@microsoft.com... > > > "Michal Kawecki" wrote: > > >> > > >> Take a look into Event Viewer, maybe there are registered errors from > > >> VSS or volsnap. > > >> > > >> It showed the allocated shadowcopy space,maximum space etc. > > > > So, maybe it will work from now. Of course, do not run XP anymore > > because your problem will repeat. > > > > > Looking at the event viewer, there are volsnap and vss errors logged. > > > There > > > were 29 volsnap errors and 46 vss errors in the six weeks I've had > > > Vista > > > installed. > > > > Do you have any new errors after this repair? If so, be more detailed. > > -- > > M. [Windows - Shell/User MVP] > > /before private reply change px with pl in my e-mail address/ > > > > No, the behavior is the same. When I opened system restore, it said no restore points were created. It also registered a volsnap error. Again, I havent booted into XP for days.I,m wondering if it could be related to how I set up the system. I installed Xp first on the raid volume and then installed vista on the other partition. Even though they are on separate partitions, does xp always see vista? Or, is there a problem with my Vista causing the restore to not function automatically? |
| | #9 (permalink) |
| Guest | Re: Can't create system restore points "rwolds9" <rwolds9@discussions.microsoft.com> wrote in message news:F43B3814-81CB-49F1-B5EF-6BFE82AFD288@microsoft.com... > > > "rwolds9" wrote:The exact error was " shadow copies of volume C: were > aborted during detection Do you use any McAfee product like virusscan? Maybe disable now any antivirus you have. I think you must also test your hard disk with some diagnostic tool. Here you find many utilities for testing different disks: http://www.tacktech.com/display.cfm?ttid=287 . Personally I recommend a very good freeware utlity MHDD http://hddguru.com/content/en/software/2005.10.02-MHDD/ . > No, the behavior is the same. When I opened system restore, it said no > restore points were created. It also registered a volsnap error. > Again, > I havent booted into XP for days.I,m wondering if it could be related > to how > I set up the system. I installed Xp first on the raid volume and then > installed > vista on the other partition. Even though they are on separate > partitions, > does xp always see vista? No, it's not possible. If you will not run Windows XP or Windows XP Recovery Console then it is meaningless, how and where was those systems installed. > Or, is there a problem with my Vista causing the > restore to not function automatically? IMO this is a problem with Vista or with your hdd, disk controller driver, or BIOS. -- M. [Windows - Shell/User MVP] /before private reply change px with pl in my e-mail address/ |
| Newbie nable to find or create system restore points | Vista General | |||
| Unable to create restore points | Vista performance & maintenance | |||
| Can't Create Restore Points | Vista General | |||
| System not able to create restore points | Vista General | |||
| Can't create restore points | Vista performance & maintenance | |||
