System will not boot up and i have no disk
  1.    01 Apr 2007 #1
    ROCK Guest
    my windows vista system will not boot up i have tryed all i can here and i
    have no disk to help with booting up with my system is new and i still have
    my 1 year on it here are some codes 0x0000c1f5
    please can someone help me?
    if you need more info i'll try and get it
  2.    01 Apr 2007 #2
    Rick Rogers Guest
    Re: System will not boot up and i have no disk
    How far does it boot?
    Have you tried the safe mode options?
    What sort of recovery plan did your manufacturer provide?
    Best of Luck,
    Rick Rogers, aka "Nutcase" - Microsoft MVP
    http://mvp.support.microsoft.com/
    Windows help - www.rickrogers.org
    "ROCK" <ROCK@discussions.microsoft.com> wrote in message
    news:AC86ED50-06EF-4C71-B3EB-41E42FCCCB6F@microsoft.com...
    > have
  3.    01 Apr 2007 #3
    ROCK Guest
    Hello Rick tkxs 4 your help i have tryed the safe mode options with no luck
    and i have tryed the repair but with not boot pass the problem screen did the
    codes help any? is there more info you need to help me
    recovery plan did your manufacturer provide? none i think its a HP Pavillion
    dv 9000 new
    "Rick Rogers" wrote:
    > Hi,
    > Best of Luck,
    > > have
  4.    01 Apr 2007 #4
    Rick Rogers Guest
    As it's new, it will still be under warranty and you should contact HP for
    assistance. The error code is likely to indicate faulty hardware or a
    non-compliant BIOS.
    Best of Luck,
    news:FF55E5F3-2CD4-43D1-AD1D-B6C01ECC4A64@microsoft.com...
    > luck
    > the
    > Pavillion
    > dv 9000 new
    >> Hi,
    >> Best of Luck,
    >> > and i
    >> > have
  5.    01 Apr 2007 #5
    Rodney Farmer Guest
    Hi Rock,
    Try the following, which is extracted from the HP user guide on my HP
    dv9000:
    You can perform a recovery from the partition on the hard drive from either
    the Start button or f11.
    To restore the system from the partition, follow these steps:
    1. Access Recovery Manager in either of the following ways:
    ● Select Start > All Programs > Recovery Manager > Recovery Manager.
    ● Restart the computer and press f11 while the “Press <F11> for recovery”
    message is displayed on the screen. Then select Recovery Manager.
    Recovery Manager opens.
    2. Click Advanced Options.
    3. Click System recovery, and then click Next.
    4. Follow the on-screen instructions.
    best of luck,
    Rod
    > luck
    > the
    > Pavillion
    > dv 9000 new
    >> Hi,
    >> Best of Luck,
    >> > and i
    >> > have
Disk boot failure, insert system disk and press enter
Title says everything. So I inserted my System Disk (Installation Disk), that i bought from HP.com $15.00 It worked many times, This time when i...
Drivers
Hello all, I hope someone can help me further as I've pretty much exhausted all my knowledge and ideas I've managed to google up. I awoke one...
General Discussion
Hard Disk Boot Failure Insert System Disk
I formatted my hard drive today and after a reboot I got the message: "Hard Disk Boot Failure Insert System Disk And Press Enter" If I insert my...
General Discussion
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER
Prezados colegas, ocorreu a mensagem DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER. Acontece que comprei a licença do Windows Vista...
Vista General
I keep on getting this error message on Home Premium.Im running two 500GB Sata hard drives. I've tried changing BIOS settings plenty of times. Any...
Vista General
Issues with System drive in Disk Management on a Dual Boot system
At the moment I have XP x64 and Vista x64 installed on my machine. The way I'd like to have it setup is where the two operating systems do not...
Vista General
Disk Boot Failure, Insert system disk and press enter
Well I am just down to one issue with Vista 64. I can not boot to any OS with out the Vista DVD in the drive. If I do not have it in it will look...
Vista installation & setup
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
