Vista Tutorial - Vista 64, Quicken Billminder problem.
Old 04-01-2007   #1 (permalink)
XS11E
Guest
I've posted this to the Quicken newsgroups but thought someone here
might be running Vista 64 and Quicken:
Billminder won't open on Vista Ultimate Edition 64 bit.
Double clicking on it pops up an error screen saying it failed to start
and do I want to search the net for a fix (futile as always) or stop
the program.
So...... I dragged the .exe file into startup, rebooted and got a
message that Billminder couldn't start because it can't find QWUTIL.dll
so.. copied QWUTIL.dll into c:\Program files and again into C:\Program
Files (x86) and noticed it is in the C:\Program Files\Qwicken folder.
No help, same message.
Anyone running Vista 64 bit and Quicken? The Quicken website is of no
help as always... <sigh>
BTW, all is well with Quicken on my XP installation.
Old 11-13-2008   #2 (permalink)
Newbie
Ultimate x64
Re: Vista 64, Quicken Billminder problem.
I cannot get quicken to even install on vista 64bit...!
Old 11-13-2008   #3 (permalink)
Mike Hall - MVP
Guest
"superiorjet" <guest@xxxxxx-email.com> wrote in message
news:b58e6f0f4fe3a14ebae9f9fa72312d75@xxxxxx-gateway.com...
Quote:
> Hi,
> superiorjet
Go to Quicken support forums for your answer..
Mike Hall - MVP
How to construct a good post..
http://dts-l.com/goodpost.htm
How to use the Microsoft Product Support Newsgroups..
http://support.microsoft.com/default...help&style=toc
Mike's Window - My Blog..
http://msmvps.com/blogs/mikehall/default.aspx
Old 11-13-2008   #4 (permalink)
Newbie
Ultimate x64
been there done that
Quicken print problem Software
Quicken 2009 PDF printer problem- mistake or intentional? Vista General
"quicken background agent" / "quicken scheduled updates" blocked in Vista Options Vista security
"quicken background agent" / "quicken scheduled updates" blocked in Vista Vista General
Anyone using Pocket Quicken 2.5, Quicken 2007 and Vista? Vista General
