| | Problems Running Software I am trying to run some software that is PC and Mac 10.4 compatible. It is software provided my a yearbook compilation company to do the layout and design of our school yearbook - and I can not get it to run. I have re-installed it several times - to no avail. Any ideas? The software is called ezbook7 version 7.2 |
| | Re: Problems Running Software Hi, Two things to try: 1) Right click the startup icon and use 'run as administrator'. 2) Right click the icon and choose properties. On the compatibility tab try running it under XP. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org "Problem running software" <Problem running software@discussions.microsoft.com> wrote in message news:6ABA0552-58B0-47E1-8672-B64F4E7BC01A@microsoft.com... >I am trying to run some software that is PC and Mac 10.4 compatible. It is > software provided my a yearbook compilation company to do the layout and > design of our school yearbook - and I can not get it to run. I have > re-installed it several times - to no avail. Any ideas? The software is > called ezbook7 version 7.2 |
| Problems running slow after update, IE but expecially running any | Vista music pictures video | |||
| Running software as an Administrator | Vista General | |||
| App-V running 2 versions of the same software | Virtual Server | |||
| Running Software at Start Up | Vista General | |||
| software running in the backround | Vista General | |||
