| | usb port problem Can't sincronize my blackberry with new notebook using Windows vista. A message on the blackberry says that the USB port doesn't have enough power. I check all in the device driver and all is OK. I can conect a camera do any of the ports. Nothing else is conected to the usb ports. Is that a windows vista problem? |
| | Re: usb port problem Many Pocket PCs/Blackberry Smart Phones draw a USB Root Hub limit of 500mA of current. Different devices draw different amounts of current. If the device is USB-2.0 then it is routed to an Enhanced controller/hub. If USB1(.l) then it routes to one of several Universal controller/hubs on your motherboard. To check USB Bandwidth and Power consumption. Open Device Manager. (Run (Type) DevMgmt.Msc [Enter] 1.) Expand the USB category 2.) Double-Click each Controller - when the details box opens click the Advanced (TAB) it will display the total % of bandwidth used and system reserved. 3.) Double-Click each Root Hub, from the details box click the Power (TAB). It will show the total current draw on the hub. I'd consult with the vendor. If the notebook can't natively handle a Blackberry you'd be advised to return it. "Fifi" <Fifi@discussions.microsoft.com> wrote in message news:2128B045-21F3-48AF-86E8-8794EE36336A@microsoft.com... > Can't sincronize my blackberry with new notebook using Windows vista. A > message on the blackberry says that the USB port doesn't have enough > power. I > check all in the device driver and all is OK. I can conect a camera do any > of > the ports. Nothing else is conected to the usb ports. Is that a windows > vista > problem? |
| | Re: usb port problem Thanks. Power was not the problem as the display message in the blackberry said. I unistalled the device, intstalled new drivers and voila, it is working. Wrong window messages are very misleading (the device manager also said the drivers were updated) "R. McCarty" wrote: > Many Pocket PCs/Blackberry Smart Phones draw a USB Root Hub > limit of 500mA of current. Different devices draw different amounts of > current. If the device is USB-2.0 then it is routed to an Enhanced > controller/hub. If USB1(.l) then it routes to one of several Universal > controller/hubs on your motherboard. > > To check USB Bandwidth and Power consumption. > Open Device Manager. (Run (Type) DevMgmt.Msc [Enter] > 1.) Expand the USB category > 2.) Double-Click each Controller - when the details box opens click > the Advanced (TAB) it will display the total % of bandwidth used > and system reserved. > 3.) Double-Click each Root Hub, from the details box click the Power > (TAB). It will show the total current draw on the hub. > > I'd consult with the vendor. If the notebook can't natively handle a > Blackberry you'd be advised to return it. > > "Fifi" <Fifi@discussions.microsoft.com> wrote in message > news:2128B045-21F3-48AF-86E8-8794EE36336A@microsoft.com... > > Can't sincronize my blackberry with new notebook using Windows vista. A > > message on the blackberry says that the USB port doesn't have enough > > power. I > > check all in the device driver and all is OK. I can conect a camera do any > > of > > the ports. Nothing else is conected to the usb ports. Is that a windows > > vista > > problem? > > > |
| | Re: usb port problem I have the same problem, where did you get the drivers? "Fifi" wrote: > Thanks. Power was not the problem as the display message in the blackberry > said. > I unistalled the device, intstalled new drivers and voila, it is working. > Wrong window messages are very misleading (the device manager also said the > drivers were updated) > > "R. McCarty" wrote: > > > Many Pocket PCs/Blackberry Smart Phones draw a USB Root Hub > > limit of 500mA of current. Different devices draw different amounts of > > current. If the device is USB-2.0 then it is routed to an Enhanced > > controller/hub. If USB1(.l) then it routes to one of several Universal > > controller/hubs on your motherboard. > > > > To check USB Bandwidth and Power consumption. > > Open Device Manager. (Run (Type) DevMgmt.Msc [Enter] > > 1.) Expand the USB category > > 2.) Double-Click each Controller - when the details box opens click > > the Advanced (TAB) it will display the total % of bandwidth used > > and system reserved. > > 3.) Double-Click each Root Hub, from the details box click the Power > > (TAB). It will show the total current draw on the hub. > > > > I'd consult with the vendor. If the notebook can't natively handle a > > Blackberry you'd be advised to return it. > > > > "Fifi" <Fifi@discussions.microsoft.com> wrote in message > > news:2128B045-21F3-48AF-86E8-8794EE36336A@microsoft.com... > > > Can't sincronize my blackberry with new notebook using Windows vista. A > > > message on the blackberry says that the USB port doesn't have enough > > > power. I > > > check all in the device driver and all is OK. I can conect a camera do any > > > of > > > the ports. Nothing else is conected to the usb ports. Is that a windows > > > vista > > > problem? > > > > > > |
| COM port problem | General Discussion | |||
| Problem with printer port | Vista print fax & scan | |||
| Port problem | Live Mail | |||
| Driver or USB Port Problem, PLZ Help! | Drivers | |||
| headphone port problem | Vista hardware & devices | |||
