| | Headphones problem I have a problem with my PC, I have a Windows Vista running and my speakers are working well, but when I unplug them and connect my headphones the Windows recognize them as normal speakers not as headphones, the headphones work and I can hear with them but I have problems in using them for chatting since they are not recognized as headphones, I don't know how to solve this??? |
| | Re: Headphones problem In message 9250AE0B-1EA9-4F37-AF35-3E9EE3B25CAA@microsoft.com, memo79 <memo79@discussions.microsoft.com> Proclaimed from the tallest tower: > I have a problem with my PC, I have a Windows Vista running and my > speakers are working well, but when I unplug them and connect my > headphones the Windows recognize them as normal speakers not as > headphones, the headphones work and I can hear with them but I have > problems in using them for chatting since they are not recognized as > headphones, > I don't know how to solve this??? Don't really see how Windows could tell the difference between speakers and headphones and switch automatically, as electronically speaking, they are pretty much the same thing...(?) Why is it a problem that it thinks they are speakers? If it IS important, I guess there must be a setting in the control panel for the sound system that lets you select one or the other...(??) -- Regards, Chris. (Remove Elvis's shoes to email me) |
| | Re: Headphones problem memo79 wrote: > I have a problem with my PC, I have a Windows Vista running and my speakers > are working well, but when I unplug them and connect my headphones the > Windows recognize them as normal speakers not as headphones, the headphones > work and I can hear with them but I have problems in using them for chatting > since they are not recognized as headphones, > I don't know how to solve this??? Advanced options for switching from headphones to speakers are usually included in the sound card drivers. Since you didn't tell us what sound card you have and whether you upgraded Vista or got it preinstalled, that's as specific as I can get. Check on the sound card mftr.'s website for updated Vista drivers or if you have an OEM machine (Dell, HP, etc.) check on the OEM's site for your specific model machine. A workaround is to get a simple switch into which you can plug your headphones. We use ones from Plantronics here. Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| Problem with switching from headphones to internal speakers | Sound & Audio | |||
| Re: Sound from headphones, but not without headphones? | Vista hardware & devices | |||
| Bluetooth Headphones problem with Vista | Vista hardware & devices | |||
| Headphones Problem | Vista hardware & devices | |||
| headphones | Vista hardware & devices | |||
