| | #11 (permalink) |
| | Re: Gadget Calendar Problem Right I fixed mine it was the fact that somewhere along the vbscript.dll became unregisterd. This gave me just an orange box for the calendar gadget plus the stocks gadget stopped showing up in the sidebar altogether to fix the problems open a DOS command window in administrator mode. then type in regsvr32 vbscript.dll wait to see if you get the message succeded. ![]() "au8ust" wrote: > Uninstalled but still can't get the calendar gadget working ![]() > > Is there anyway to fix this? > > Thanks! > > "Richard" wrote: > > > -----BEGIN PGP SIGNED MESSAGE----- > > Hash: SHA1 > > > > GDyke wrote: > > > > > Hi there yes I have exactly the same problem I believe mine occurred after > > > loading the latest version of Nero I did not set a restore point so cant go > > > back ![]() > > > > > > Do you have a similar problem with the stocks gadget if you drop it on the > > > sidebar it dissapears ? > > > > I upgraded to the latest Nero & don't have this problem. > > I only installed the burning rom though & no other apps. > > > > > > -----BEGIN PGP SIGNATURE----- > > Version: GnuPG v1.4.7 (MingW32) > > Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org > > > > iD8DBQFGbw1HqDp2fu862vwRAvMZAJ9mWVF/9jqtEgoYkrz44L60XCXoUwCgi5CR > > z4tWMNccVGh0RKwUdBHsSFk= > > =EzLt > > -----END PGP SIGNATURE----- > > |
| | #12 (permalink) |
| | Re: Gadget Calendar Problem Oh! Yeah!! It's working right now! Thanks! "GDyke" wrote: > Right I fixed mine it was the fact that somewhere along the vbscript.dll > became unregisterd. > > This gave me just an orange box for the calendar gadget plus the stocks > gadget stopped showing up in the sidebar altogether to fix the problems > > open a DOS command window in administrator mode. > > then type in regsvr32 vbscript.dll > > wait to see if you get the message succeded. > > ![]() > > > "au8ust" wrote: > > > Uninstalled but still can't get the calendar gadget working ![]() > > > > Is there anyway to fix this? > > > > Thanks! > > > > "Richard" wrote: > > > > > -----BEGIN PGP SIGNED MESSAGE----- > > > Hash: SHA1 > > > > > > GDyke wrote: > > > > > > > Hi there yes I have exactly the same problem I believe mine occurred after > > > > loading the latest version of Nero I did not set a restore point so cant go > > > > back ![]() > > > > > > > > Do you have a similar problem with the stocks gadget if you drop it on the > > > > sidebar it dissapears ? > > > > > > I upgraded to the latest Nero & don't have this problem. > > > I only installed the burning rom though & no other apps. > > > > > > > > > -----BEGIN PGP SIGNATURE----- > > > Version: GnuPG v1.4.7 (MingW32) > > > Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org > > > > > > iD8DBQFGbw1HqDp2fu862vwRAvMZAJ9mWVF/9jqtEgoYkrz44L60XCXoUwCgi5CR > > > z4tWMNccVGh0RKwUdBHsSFk= > > > =EzLt > > > -----END PGP SIGNATURE----- > > > |
| Calendar Gadget Gone | Vista General | |||
| Broken Calendar Gadget | Vista General | |||
| Calendar gadget options | Vista General | |||
| Windows Live Calendar Gadget | Vista General | |||
| Calendar Gadget Stays on Same Day | Vista General | |||
