IE7 problem
  1. #1
    ddnoc Guest
    IE7 problem
    I can access the internet from a program ie: the online help menu of my anti
    virus program, but if I try to use my IE icon, I get an error message. (IE
    has stopped working, blah blah blah) Any ideas?
  2. #2
    Rick Rogers Guest
    Re: IE7 problem
    Click start, type 'Internet Options' and hit <enter>. Go to the programs
    tab, click the button to manage add-ons. Start disabling them a few at a
    time. Retry opening IE7 in between. Once it opens successfully, you will
    know it is one of the ones you just disabled. Some experimentation should
    reveal what the problem is.
    Best of Luck,
    Rick Rogers, aka "Nutcase" - Microsoft MVP
    http://mvp.support.microsoft.com/
    Windows help - www.rickrogers.org
    "ddnoc" <ddnoc@discussions.microsoft.com> wrote in message
    news:1BDE2220-ACF5-4CB9-9092-46CBCFFC1A0A@microsoft.com...
    >anti
IE7 problem problems?
the problem with ndis.sys Blue Screen of Death problem solved? liketofindoutwhy Vista General 6 24 May 2009
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Rainald Taesler Vista mail 14 17 May 2009
Generic McAfee Problem Message in Vista Problem Reports cyberbuff53 Vista performance & maintenance 0 01 Dec 2007
fixed unable to delete email problem, now I have new problem j2 Vista mail 19 29 Mar 2007
Vista Upgrade Problem - Windows Explorer Loop problem Steve S Vista installation & setup 0 27 Jun 2006
