| | Problem with help i'm having a problem with the offline help in vista. Instead of pictures its only showing the red crosses, like it couldn't find the picture. The same goes for my Sidebar and the gadgets who needs Pictures. I have looked araound for a solution to the problem and came across a .reg file that seem to have fixed this problem for a couple users but it does zip in my case. Still teh same problem. Does anybode got a clue on what to look for? -- eijnok ------------------------------------------------------------------------ eijnok's Profile: http://forums.techarena.in/member.php?userid=24236 View this thread: http://forums.techarena.in/showthread.php?t=719197 http://forums.techarena.in |
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 | Vista mail | |||
| Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! | Vista General | |||
| Generic McAfee Problem Message in Vista Problem Reports | Vista performance & maintenance | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
