| | Built-in color selection (eyedropper) tool not working anywhere Ever since I migrated to a Vista Business computer, the eye dropper tool has stopped working in several applications, including FrontPage 2003, Adobe Photoshop Elements, and even my old standby, Image Composer. When I use this tool in any of the programs, it immediately displays black as the selected color (before I even click on another color) and won't change. I'm currently using a third-party utility (Colourificator) as a workaround, but that takes several additional steps to accomplish the same result that one click with the eyedropper used to handle. Is there anything that can be done to fix the problem in Vista itself? Perhaps a registry tweak? Vista is the only common denominator I have found since all of the programs still work properly on my WinXP machines. |
| | RE: Built-in color selection (eyedropper) tool not working anywhere PS: This problem is also occurring in the new Expression Web software that was just released to replace FrontPage. |
| | Re: Built-in color selection (eyedropper) tool not working anywhere On Wed, 4 Apr 2007 08:20:00 -0700, KFloyde <KFloyde@discussions.microsoft.com> wrote: >Ever since I migrated to a Vista Business computer, the eye dropper tool has >stopped working in several applications, including FrontPage 2003, Adobe >Photoshop Elements, and even my old standby, Image Composer. When I use this >tool in any of the programs, it immediately displays black as the selected >color (before I even click on another color) and won't change. > >I'm currently using a third-party utility (Colourificator) as a workaround, >but that takes several additional steps to accomplish the same result that >one click with the eyedropper used to handle. > >Is there anything that can be done to fix the problem in Vista itself? >Perhaps a registry tweak? Vista is the only common denominator I have found >since all of the programs still work properly on my WinXP machines. Interesting, I see the same kind of malfunction with the Vegas eyedropper tool as well. Vegas is a pro grade video editor. If I try to select an area with the eyedropper tool, it just shows a black area, and the color wheels in the filter it is suppose to effect don't change, so it don't automate a black or white point correction like it used to in XP. However if I just click on a single pixel with the eyedropper tool in Vegas, it still functions correctly. I was thinking it could be a video driver issue, maybe something wrong with Vegas (doubtful), maybe it is Vista itself. Don't know yet. Interesting others see it also in other applicatons with a different eyedropper tool. The one I'm referring to is build-into Vegas. Just curious, what video card and driver are you using? I'm using NVIDIA GeForce 7600 GT driver 7.15.10.9746. I tired a later driver that crashed so went back to this one. |
| | RE: Built-in color selection (eyedropper) tool not working anywhere I'm a bit embarrassed to admit this, but I'm not sure of the specs on my video card. It's a Dell Inspiron MXC061 notebook and when I look in Device Manager > Display Adapter, here's what it shows: Mobile Intel(R) 945GM Express Chipset Family (Driver 7.14.10.1147) Does this help? I know software, but when it comes to hardware issues, my brain does an automatic shutdown... |
| | Re: Built-in color selection (eyedropper) tool not working anywhere On Wed, 4 Apr 2007 10:24:02 -0700, KFloyde <KFloyde@discussions.microsoft.com> wrote: >I'm a bit embarrassed to admit this, but I'm not sure of the specs on my >video card. >It's a Dell Inspiron MXC061 notebook and when I look in Device Manager > >Display >Adapter, here's what it shows: >Mobile Intel(R) 945GM Express Chipset Family (Driver 7.14.10.1147) > >Does this help? I know software, but when it comes to hardware issues, my >brain >does an automatic shutdown... If you want to learn a lot about Vista knows about your hardware and software, just click on the Start button then type in 'system' then click on System Information if more than one hit shows up in the list. Quite detailed report and it normally will show conflicts detailed better than Device Manager. You do need to expand the folders in the left window pane to see all the details. For example if you expand Hardware, then pick memory, you'll get a list of how Vista is assigning memory and if anything has trouble. If you expand Software, then look in System Drivers, you see what drivers have been loaded and if or not some didn't make it, which would indicate something isn't right. Thanks for the info, sounds like you have graphics build in and not a seperate card, so that probably means my problem isn't my video card, but who knows. |
| | #6 (permalink) |
| | Re: Built-in color selection (eyedropper) tool not working Thank you very much for the information, Adam... even though it may not solve this eyedropper issue, I know that your instructions will come in handy for troubleshooting other problems that occur. I appreciate the time you took to give me this "hardware lesson"! 8) |
| | #7 (permalink) |
| | RE: Built-in color selection (eyedropper) tool not working anywhere Well, it looks like this apparent bug has been fixed by Windows Update. I used the eyedropper tool today in various programs and it worked like a charm. FYI, I'm on Version 6.0 (Build 6000). |
| | #8 (permalink) |
| | RE: Built-in color selection (eyedropper) tool not working anywher Well, it was nice while it lasted. I'm still on Version 6.0 (Build 6000), but since Friday, I've once again lost the functionality of the eye dropper tool in various programs. Does anyone know if any of the recent Windows Updates could have affected this feature? |
| | #9 (permalink) |
| | RE: Built-in color selection (eyedropper) tool not working anywher I finally figured out a solution to this... right-click on the EXE file for each program involved. Click the Compatibility tab and changing the setting to Windows XP. All of my color pickers work again! |
| Highlight or selection color | Live Mail | |||
| Menu selection color | Vista General | |||
| Selection Contrast Color | Vista General | |||
