| | HELP! I have no desktop okie dokey... I'm not sure what happened, but if there is anyone out there with a solution, i'll forever be in your debt. I'll explain... I was playing a game and got called away to dinner. When I came back One Care told me that it just downloaded a new update and needed to install it and restart the computer. It said that this would happen in 5 1/2 hours or now (if i clicked now, which I did.) The computer restarted and instead of the desktop appearing with the sidebar and icons, it went straight into windows explorer. Thinking that this was a bit odd, I closed down explorer to find that my entire screen was black. I couldn't right click I couldn't use the keyb win logo key nothing I restarted the computer again; and again it opened up into win explorer. I located programfiles/internet explorer and navigated my way here to ask.... Does anyone know wtf is going on??? ;'( (I have tried restarting it in safe mode. same black screen with the 'safe mode' doodads in each corner...) |
| | Re: HELP! I have no desktop Try pressing ctrl alt delete and get the task manager up if you can hit file, and open or run, or what ever it is type in explorer.exe hit enter, and it SHOULD load your desktop.... if not i dont know how i would fix that. Worth a try though Mark "spïrö" <spr@discussions.microsoft.com> wrote in message news:8FA82A24-F8ED-4267-AC2F-B5A8D4A56022@microsoft.com... > okie dokey... > > I'm not sure what happened, but if there is anyone out there with a > solution, i'll forever be in your debt. > > I'll explain... > > I was playing a game and got called away to dinner. When I came back One > Care told me that it just downloaded a new update and needed to install it > and restart the computer. It said that this would happen in 5 1/2 hours > or > now (if i clicked now, which I did.) > The computer restarted and instead of the desktop appearing with the > sidebar > and icons, it went straight into windows explorer. > Thinking that this was a bit odd, I closed down explorer to find that my > entire screen was black. > I couldn't right click > I couldn't use the keyb win logo key > nothing > > I restarted the computer again; and again it opened up into win explorer. > > I located programfiles/internet explorer and navigated my way here to > ask.... > > Does anyone know wtf is going on??? ;'( > > > (I have tried restarting it in safe mode. same black screen with the > 'safe > mode' doodads in each corner...) > |
| | Re: HELP! I have no desktop OH MY GOODNESS...! Thankyou! Something so simple - but I never would have worked it out! I officially owe you a slab! ![]() spïrö "Mark Shirley" wrote: > Try pressing ctrl alt delete > and get the task manager up > if you can hit file, and open or run, or what ever it is > type in > explorer.exe > hit enter, and it SHOULD load your desktop.... if not i dont know how i > would fix that. > > Worth a try though > Mark > > "spïrö" <spr@discussions.microsoft.com> wrote in message > news:8FA82A24-F8ED-4267-AC2F-B5A8D4A56022@microsoft.com... > > okie dokey... > > > > I'm not sure what happened, but if there is anyone out there with a > > solution, i'll forever be in your debt. > > > > I'll explain... > > > > I was playing a game and got called away to dinner. When I came back One > > Care told me that it just downloaded a new update and needed to install it > > and restart the computer. It said that this would happen in 5 1/2 hours > > or > > now (if i clicked now, which I did.) > > The computer restarted and instead of the desktop appearing with the > > sidebar > > and icons, it went straight into windows explorer. > > Thinking that this was a bit odd, I closed down explorer to find that my > > entire screen was black. > > I couldn't right click > > I couldn't use the keyb win logo key > > nothing > > > > I restarted the computer again; and again it opened up into win explorer. > > > > I located programfiles/internet explorer and navigated my way here to > > ask.... > > > > Does anyone know wtf is going on??? ;'( > > > > > > (I have tried restarting it in safe mode. same black screen with the > > 'safe > > mode' doodads in each corner...) > > > |
| | RE: HELP! I have no desktop Try using System Restore to restore your PC to a time before the error started happening. System Restore can be found at C:\Windows\System32\rstrui.exe "spïrö" wrote: > okie dokey... > > I'm not sure what happened, but if there is anyone out there with a > solution, i'll forever be in your debt. > > I'll explain... > > I was playing a game and got called away to dinner. When I came back One > Care told me that it just downloaded a new update and needed to install it > and restart the computer. It said that this would happen in 5 1/2 hours or > now (if i clicked now, which I did.) > The computer restarted and instead of the desktop appearing with the sidebar > and icons, it went straight into windows explorer. > Thinking that this was a bit odd, I closed down explorer to find that my > entire screen was black. > I couldn't right click > I couldn't use the keyb win logo key > nothing > > I restarted the computer again; and again it opened up into win explorer. > > I located programfiles/internet explorer and navigated my way here to ask.... > > Does anyone know wtf is going on??? ;'( > > > (I have tried restarting it in safe mode. same black screen with the 'safe > mode' doodads in each corner...) > |
| | Re: HELP! I have no desktop unless you restore your PC you will have to do that every time! But thats your call, i would never use system restore, it pisses way to many things of in the process. There are soloutions, but i dont have the paitence to type up the way i would do it, involving regedit and startup scripts google it though should be 4 or 5pages of instructions Mark "spïrö" <spr@discussions.microsoft.com> wrote in message news:3B2EF779-A3EC-42E3-8162-05CFDA081B68@microsoft.com... > OH MY GOODNESS...! > > Thankyou! Something so simple - but I never would have worked it out! > > I officially owe you a slab! ![]() > > > spïrö > > > > "Mark Shirley" wrote: > >> Try pressing ctrl alt delete >> and get the task manager up >> if you can hit file, and open or run, or what ever it is >> type in >> explorer.exe >> hit enter, and it SHOULD load your desktop.... if not i dont know how i >> would fix that. >> >> Worth a try though >> Mark >> >> "spïrö" <spr@discussions.microsoft.com> wrote in message >> news:8FA82A24-F8ED-4267-AC2F-B5A8D4A56022@microsoft.com... >> > okie dokey... >> > >> > I'm not sure what happened, but if there is anyone out there with a >> > solution, i'll forever be in your debt. >> > >> > I'll explain... >> > >> > I was playing a game and got called away to dinner. When I came back >> > One >> > Care told me that it just downloaded a new update and needed to install >> > it >> > and restart the computer. It said that this would happen in 5 1/2 >> > hours >> > or >> > now (if i clicked now, which I did.) >> > The computer restarted and instead of the desktop appearing with the >> > sidebar >> > and icons, it went straight into windows explorer. >> > Thinking that this was a bit odd, I closed down explorer to find that >> > my >> > entire screen was black. >> > I couldn't right click >> > I couldn't use the keyb win logo key >> > nothing >> > >> > I restarted the computer again; and again it opened up into win >> > explorer. >> > >> > I located programfiles/internet explorer and navigated my way here to >> > ask.... >> > >> > Does anyone know wtf is going on??? ;'( >> > >> > >> > (I have tried restarting it in safe mode. same black screen with the >> > 'safe >> > mode' doodads in each corner...) >> > >> |
| | #6 (permalink) |
| | RE: HELP! I have no desktop thanx, i'll give it a go ![]() "SWWD" wrote: > Try using System Restore to restore your PC to a time before the error > started happening. > > System Restore can be found at C:\Windows\System32\rstrui.exe > > "spïrö" wrote: > > > okie dokey... > > > > I'm not sure what happened, but if there is anyone out there with a > > solution, i'll forever be in your debt. > > > > I'll explain... > > > > I was playing a game and got called away to dinner. When I came back One > > Care told me that it just downloaded a new update and needed to install it > > and restart the computer. It said that this would happen in 5 1/2 hours or > > now (if i clicked now, which I did.) > > The computer restarted and instead of the desktop appearing with the sidebar > > and icons, it went straight into windows explorer. > > Thinking that this was a bit odd, I closed down explorer to find that my > > entire screen was black. > > I couldn't right click > > I couldn't use the keyb win logo key > > nothing > > > > I restarted the computer again; and again it opened up into win explorer. > > > > I located programfiles/internet explorer and navigated my way here to ask.... > > > > Does anyone know wtf is going on??? ;'( > > > > > > (I have tried restarting it in safe mode. same black screen with the 'safe > > mode' doodads in each corner...) > > |
| Vista laptop...Linksys...XP desktop...can't connect to desktop?? | Vista networking & sharing | |||
| Running vista, and my desktop went black, and desktop icon went aw | Vista General | |||
| desktop files moved to another folder under \favorites\desktop. | Vista General | |||
| windows live desktop mail cannot read the draft by using desktop m | Vista mail | |||
| submitted feedback yesterday - Today desktop.ini on my desktop | Vista General | |||
