| | MS Streets & Trips 2006 Problem I received MS Streets & Trips 2006 from Gateway as part of MS Works Suite 2006 with my new computer. After installing and trying to access, I received the following error message: "Your registry settings for this application were not copied correctly. To correct these settings, run setup again for this application from the location where you originally installed it." After uninstalling/re-installing failed, I contacted Gateway. I was told that the only way to access MS Streets & Trips 2006 was to 'Turn Off User Account Control'. Doing this requires a re-start of the system. I was able to access MS Streets & Trips 2006 in this manner. This is clearly an issue. Is there another way to access this program without turning off UAC? Is MS aware of this issue? |
| | Re: MS Streets & Trips 2006 Problem You're not alone. I have the same exact problem, and receive the same exact message with MS Streets & Trips 2005. I have to log on as Administrator to use this program. It would be nice if someone here could offer us a better alternative...other than going out and buying MS Streets & Trips 2007. "CLK Group" <CLKGroup@discussions.microsoft.com> wrote in message news:C9115F35-2357-4A2C-BFB9-6F5ADD605C1B@microsoft.com... >I received MS Streets & Trips 2006 from Gateway as part of MS Works Suite > 2006 with my new computer. > > After installing and trying to access, I received the following error > message: > "Your registry settings for this application were not copied correctly. To > correct these settings, run setup again for this application from the > location where you originally installed it." > > After uninstalling/re-installing failed, I contacted Gateway. I was told > that the only way to access MS Streets & Trips 2006 was to 'Turn Off User > Account Control'. > Doing this requires a re-start of the system. > > I was able to access MS Streets & Trips 2006 in this manner. > > This is clearly an issue. Is there another way to access this program > without turning off UAC? Is MS aware of this issue? > > |
| | Re: MS Streets & Trips 2006 Problem "James" <anonymous> wrote in message news:ksmdnbAle4NnhIrbnZ2dnUVZ_h-vnZ2d@bright.net... > You're not alone. I have the same exact problem, and receive the same > exact message with MS Streets & Trips 2005. I have to log on as > Administrator to use this program. It would be nice if someone here could > offer us a better alternative...other than going out and buying MS Streets > & Trips 2007. > > "CLK Group" <CLKGroup@discussions.microsoft.com> wrote in message > news:C9115F35-2357-4A2C-BFB9-6F5ADD605C1B@microsoft.com... >>I received MS Streets & Trips 2006 from Gateway as part of MS Works Suite >> 2006 with my new computer. >> >> After installing and trying to access, I received the following error >> message: >> "Your registry settings for this application were not copied correctly. >> To >> correct these settings, run setup again for this application from the >> location where you originally installed it." >> >> After uninstalling/re-installing failed, I contacted Gateway. I was told >> that the only way to access MS Streets & Trips 2006 was to 'Turn Off User >> Account Control'. >> Doing this requires a re-start of the system. >> >> I was able to access MS Streets & Trips 2006 in this manner. >> >> This is clearly an issue. Is there another way to access this program >> without turning off UAC? Is MS aware of this issue? >> >> > Try right clicking on the icon and select run as administrator. |
| | Re: MS Streets & Trips 2006 Problem I agree with John's answer you can modify the shortcut to always run as administrator and if you want, you can set it to run in XP compatibility mode as well. "James" <anonymous> wrote in message news:ksmdnbAle4NnhIrbnZ2dnUVZ_h-vnZ2d@bright.net... > You're not alone. I have the same exact problem, and receive the same > exact message with MS Streets & Trips 2005. I have to log on as > Administrator to use this program. It would be nice if someone here could > offer us a better alternative...other than going out and buying MS Streets > & Trips 2007. > > "CLK Group" <CLKGroup@discussions.microsoft.com> wrote in message > news:C9115F35-2357-4A2C-BFB9-6F5ADD605C1B@microsoft.com... >>I received MS Streets & Trips 2006 from Gateway as part of MS Works Suite >> 2006 with my new computer. >> >> After installing and trying to access, I received the following error >> message: >> "Your registry settings for this application were not copied correctly. >> To >> correct these settings, run setup again for this application from the >> location where you originally installed it." >> >> After uninstalling/re-installing failed, I contacted Gateway. I was told >> that the only way to access MS Streets & Trips 2006 was to 'Turn Off User >> Account Control'. >> Doing this requires a re-start of the system. >> >> I was able to access MS Streets & Trips 2006 in this manner. >> >> This is clearly an issue. Is there another way to access this program >> without turning off UAC? Is MS aware of this issue? >> >> > |
| | Re: MS Streets & Trips 2006 Problem Dale & John - Thank you, I created a short-cut icon, right clicked, and was able to open as administrator. "Dale White" wrote: > I agree with John's answer you can modify the shortcut to always run as > administrator and if you want, you can set it to run in XP compatibility > mode as well. > > > "James" <anonymous> wrote in message > news:ksmdnbAle4NnhIrbnZ2dnUVZ_h-vnZ2d@bright.net... > > You're not alone. I have the same exact problem, and receive the same > > exact message with MS Streets & Trips 2005. I have to log on as > > Administrator to use this program. It would be nice if someone here could > > offer us a better alternative...other than going out and buying MS Streets > > & Trips 2007. > > > > "CLK Group" <CLKGroup@discussions.microsoft.com> wrote in message > > news:C9115F35-2357-4A2C-BFB9-6F5ADD605C1B@microsoft.com... > >>I received MS Streets & Trips 2006 from Gateway as part of MS Works Suite > >> 2006 with my new computer. > >> > >> After installing and trying to access, I received the following error > >> message: > >> "Your registry settings for this application were not copied correctly. > >> To > >> correct these settings, run setup again for this application from the > >> location where you originally installed it." > >> > >> After uninstalling/re-installing failed, I contacted Gateway. I was told > >> that the only way to access MS Streets & Trips 2006 was to 'Turn Off User > >> Account Control'. > >> Doing this requires a re-start of the system. > >> > >> I was able to access MS Streets & Trips 2006 in this manner. > >> > >> This is clearly an issue. Is there another way to access this program > >> without turning off UAC? Is MS aware of this issue? > >> > >> > > > > > |
| | #6 (permalink) |
| | Re: MS Streets & Trips 2006 Problem "John" <nospam@nospam.com> wrote in message > Try right clicking on the icon and select run as administrator. Unfortunately the Administrator option is grayed out and has an empty checkbox, and "Run in separate memory space" is checked. As a result, I am not able to change this as you advised. I actually have to log in as Administrator to run the program. Any ideas? |
| | #7 (permalink) |
| | Re: MS Streets & Trips 2006 Problem "Dale White" <dale.white@NOinsightbb.NOcom> wrote in message >I agree with John's answer you can modify the shortcut to always run as >administrator and if you want, you can set it to run in XP compatibility >mode as well. "XP compatibility? " This mode is not available as a "Properties" option. I've looked under all the shortcut icon "Properties" tabs. Where is this supposed to be at? |
| | #8 (permalink) |
| | Re: MS Streets & Trips 2006 Problem "James" <anonymous> wrote in message: > "XP compatibility? " This mode is not available as a "Properties" option. > > I've looked under all the shortcut icon "Properties" tabs. Where is this > supposed to be at? Never mind. I found the options as described. My problem was that I was clicking on the shortcut icon rather than the actual application icon. |
| Transfer Pushpins from Streets & Trips 2006 to 2009? | .NET General | |||
| Microsoft Streets & Trips 2006 | Vista installation & setup | |||
| Streets and Trips 2007 Install Problem | Vista General | |||
| MS Streets & Trips 2006 w/ GPS | Vista hardware & devices | |||
| MS Streets & Trips 2006 w/GPS | Vista hardware & devices | |||
