| 04-07-2007 | #1 (permalink) |
| | Explorer.exe not running on system startup I'm running: Vista Home Premium Duo Core 6300 Nvidia 7600 and a GB of ram I'm not sure if I am going to have to re install vista to solve this problem: When starting up, the computer goes thru all the normal stages, then asks for my password. After I type this in, the computer takes a while to load, and then instead of getting my desktop up on the screen, it loads straight into windows explorer??? To start explorer.exe, I need to ctrl-alt-del and then go 'file' 'run'... this is getting to be a real P.I.T.A. I have tried running restore point and it wont run... (for whatever reason) Any Ideas??? ![]() |
| My System Specs |
| 04-10-2007 | #2 (permalink) |
| | Re: Explorer.exe not running on system startup Thanx for the tip... before I reboot and try it out I'll let you know what was in the 'value data' space: "Explorer.exe scvhost.exe" I have renamed it to just "Explorer.exe" Not too sure how it happened, but if it's fixed -thankyou very much ![]() Tim "DatsEvolution" wrote: > > I'm about to save you a world of headach and not have to reinstall > :smile: > > Follow these steps and your back in business... > > Open regedit then go to > > HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows > NT\CurrentVersion\Winlogon > > Look for the NAME: Shell > > My guess is the reg DATA might say something like this. > > Explorer.exe C:\WINDOWS\Config\csrss.exe > > If it is different I would like to know please post it. > > All you need to do is rename the Data to this > Explorer.exe > > Now all I need to figure out is what caused this in the first > place.................:biggrin: > > > -- > DatsEvolution > |
| My System Specs |
| 04-10-2007 | #3 (permalink) |
| | Re: Explorer.exe not running on system startup Actually, apon reboot I have experienced the same problem! ![]() I went back into regedit to find that it said "Explorer.exe scvhost.exe" again. I changed it back (again) and pressed F5; it changed from "Explorer.exe" to "Explorer.exe scvhost.exe" straight away. Any ideas to make it stick?? "spïrö" wrote: > Thanx for the tip... > > before I reboot and try it out I'll let you know what was in the 'value > data' space: > > "Explorer.exe scvhost.exe" > > I have renamed it to just "Explorer.exe" > > Not too sure how it happened, but if it's fixed -thankyou very much ![]() > > > Tim > > > > "DatsEvolution" wrote: > > > > > I'm about to save you a world of headach and not have to reinstall > > :smile: > > > > Follow these steps and your back in business... > > > > Open regedit then go to > > > > HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows > > NT\CurrentVersion\Winlogon > > > > Look for the NAME: Shell > > > > My guess is the reg DATA might say something like this. > > > > Explorer.exe C:\WINDOWS\Config\csrss.exe > > > > If it is different I would like to know please post it. > > > > All you need to do is rename the Data to this > > Explorer.exe > > > > Now all I need to figure out is what caused this in the first > > place.................:biggrin: > > > > > > -- > > DatsEvolution > > |
| My System Specs |
| 04-10-2007 | #4 (permalink) |
| | Re: Explorer.exe not running on system startup spïrö wrote: > Actually, apon reboot I have experienced the same problem! ![]() > > I went back into regedit to find that it said "Explorer.exe scvhost.exe" > again. > > I changed it back (again) and pressed F5; it changed from "Explorer.exe" to > "Explorer.exe scvhost.exe" straight away. Are you absolutely sure of the spelling of "scvhost.exe"? Because if you typed this correctly your computer is infected with some variant of the Agobot virus. "Svchost.exe" is the process belonging to Windows. The fact that you have "explorer.exe scvhost.exe" shows that you are indeed infected because the virus runs with explorer.exe every time. Go through these general malware removal steps systematically - http://www.elephantboycomputers.com/...moving_Malware You will see instructions to scan with either Sysclean or Multi_AV, following that with updating your full-featured antivirus and doing another scan. All scans should be done in Safe Mode. Standard caveat: If the procedures look too complex - and there is no shame in admitting this isn't your cup of tea - take the machine to a professional computer repair shop (not your local version of BigStoreUSA). Please be aware that not all local shops are skilled at removing malware and even if they are, your computer may be so infested that Windows will need to be clean-installed. Have all your data backed up before you take the machine into a shop. Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| My System Specs |
| 04-10-2007 | #5 (permalink) |
| | Re: Explorer.exe not running on system startup Thanx ![]() Yes, i'm sure on the spelling; and I managed to fix the problem by changing the registry line in safe mode. I have scanned for viruses and malware 3 times with 3 different programs. (Spybot, Symantec and vista one-care) none of which have found anything. There was some spyware simply called 'x' which I got rid of. I'm not sure if thats what caused the problem though. Thanx for your help Tim "Malke" wrote: > spïrö wrote: > > Actually, apon reboot I have experienced the same problem! ![]() > > > > I went back into regedit to find that it said "Explorer.exe scvhost.exe" > > again. > > > > I changed it back (again) and pressed F5; it changed from "Explorer.exe" to > > "Explorer.exe scvhost.exe" straight away. > > Are you absolutely sure of the spelling of "scvhost.exe"? Because if you > typed this correctly your computer is infected with some variant of the > Agobot virus. "Svchost.exe" is the process belonging to Windows. > > The fact that you have "explorer.exe scvhost.exe" shows that you are > indeed infected because the virus runs with explorer.exe every time. > > Go through these general malware removal steps systematically - > http://www.elephantboycomputers.com/...moving_Malware > > You will see instructions to scan with either Sysclean or Multi_AV, > following that with updating your full-featured antivirus and doing > another scan. All scans should be done in Safe Mode. > > Standard caveat: If the procedures look too complex - and there is no > shame in admitting this isn't your cup of tea - take the machine to a > professional computer repair shop (not your local version of > BigStoreUSA). Please be aware that not all local shops are skilled at > removing malware and even if they are, your computer may be so infested > that Windows will need to be clean-installed. Have all your data backed > up before you take the machine into a shop. > > > Malke > -- > Elephant Boy Computers > www.elephantboycomputers.com > "Don't Panic!" > MS-MVP Windows - Shell/User > |
| My System Specs |
| 04-10-2007 | #6 (permalink) |
| | Re: Explorer.exe not running on system startup spïrö wrote: > Thanx ![]() > > Yes, i'm sure on the spelling; and I managed to fix the problem by changing > the registry line in safe mode. > I have scanned for viruses and malware 3 times with 3 different programs. > (Spybot, Symantec and vista one-care) none of which have found anything. > > There was some spyware simply called 'x' which I got rid of. I'm not sure > if thats what caused the problem though. Well, if things stay good then you know you got it. As an aside, I don't recommend either Symantec or OneCare for antivirus protection. A much better solution is NOD32, Kaspersky, or even Avast if you need a free one. Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| My System Specs |
| 04-19-2007 | #7 (permalink) |
| | Hi.. I have the same problem (with vista 32bit). After the login screen, the screen remains completely black and explorer.exe does not load until I enter the task manager and run it manually. I have gone into regedit like you suggested .. but "winlogin" doesn't exist in my registry! What's going on? Thanks. |
| My System Specs |
| 04-19-2007 | #8 (permalink) |
| | Btw, I have 13 instances of svchost processes running in taskmanager.. is that normal? (they are all "svchost", not "scvhost"). |
| My System Specs |
| 04-20-2007 | #9 (permalink) |
| | Anyone know what could be causing this? ..should I just reinstall Vista? |
| My System Specs |
| 08-24-2007 | #10 (permalink) |
| | Re: Explorer.exe not running on system startup i hav the same problem with explorer and hav changed the registry in safe mode, but after a restart the shell in registry changes bac to explorer.exe svchost.exe. i used a system restore eariler and this fixed the problem somehow it has COME BACK AGAIN and i dont hav a recent enough restore point now. i can only run explorer.exe manually. any ideas? |
| My System Specs |
| Similar topics to: Explorer.exe not running on system startup | ||||
| Running a program on startup | Server General | |||
| Windows Explorer (explorer.exe) freezes at startup | Vista General | |||
| Can't stop Winmail from running at startup | Vista mail | |||
| do I need these running on startup? | Vista performance & maintenance | |||
| System running and and slow startup | Vista General | |||
