Vista - OEM system builder pack
Old 04-07-2007   #1 (permalink)
KINTZY
I bought a Vista Ultimate OEM system builder pack (not upgrade) for my
home/family computer. I have a corrupt XP and my Internet Explorer will not
work. (I already tried updating) The package keeps talking about OPK and
when I go to the site it asks about my organization.(I don't have one)
Did I buy the wrong thing? I need help!!!
the product description is: Windows Vista Ultimate 64-bit English 1pk OEI
DVD
If I did buy the right package how do I go along installing it? Do I erase
everything then install?
Old 04-08-2007   #2 (permalink)
Andre Da Costa[ActiveWin]
Re: OEM system builder pack
I don't think its possible to do upgrades with OEM versions of Windows, it
has always been a clean install for me since XP.
"KINTZY" <KINTZY@discussions.microsoft.com> wrote in message
news:4476717D-660B-4FDE-94D8-09D2C1A9CE58@microsoft.com...
> not
> OEI
> DVD
> erase
Old 04-08-2007   #3 (permalink)
KINTZY
It's NOT an upgrade
Old 04-08-2007   #4 (permalink)
David A. Spicer
Boot from the DVD and do a clean install.
Disorder expands proportionately to the tolerance for it.
> not
> OEI
> DVD
> erase
Old 04-08-2007   #5 (permalink)
...winston
http://www.microsoft.com/oem/default.mspx
"KINTZY" <KINTZY@discussions.microsoft.com> wrote in message news:4476717D-660B-4FDE-94D8-09D2C1A9CE58@microsoft.com...
:I bought a Vista Ultimate OEM system builder pack (not upgrade) for my
: home/family computer. I have a corrupt XP and my Internet Explorer will not
: work. (I already tried updating) The package keeps talking about OPK and
: when I go to the site it asks about my organization.(I don't have one)
: Did I buy the wrong thing? I need help!!!
: the product description is: Windows Vista Ultimate 64-bit English 1pk OEI
: DVD
: If I did buy the right package how do I go along installing it? Do I erase
: everything then install?
Old 04-08-2007   #6 (permalink)
Alias
> It's NOT an upgrade
Exactly. You need to do a clean install.
Alias
Old 04-08-2007   #7 (permalink)
Bruce Chambers
> not
> OEI
> DVD
> erase
Yes, you have to format the hard drive and start clean. By design, OEM
CDs cannot perform upgrades; they are specifically designed to be installed
only onto clean (empty) partitions.
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety. -Benjamin Franklin
Many people would rather die than think; in fact, most do. -Bertrand Russell
Old 04-08-2007   #8 (permalink)
DP
I don't think you need to worry about OPK.
I bought an OEM version of Vista 64, which mentioned something about OPK.
But I didnt need it and just charged ahead with the install with no
problems.
I think the OPK is for things like customized startup screens, etc.
You will need to clean install, as Bruce says. But if you have a partition
or drive, you won't need to erase what you've already got (but should back
up anyway).
"Bruce Chambers" <bchambers@cable0ne.n3t> wrote in message
news:uiVttPfeHHA.5056@TK2MSFTNGP02.phx.gbl...
>> not
>> OEI
>> DVD
>> erase
> installed only onto clean (empty) partitions.
> Bruce Chambers
> Help us help you:
> safety deserve neither liberty nor safety. -Benjamin Franklin
> Russell
Old 04-08-2007   #9 (permalink)
DP
"DP" <nospam@nospam.com> wrote in message
news:eVU6xMkeHHA.5044@TK2MSFTNGP06.phx.gbl...
> problems.
> up anyway).
Meant to say if you have a CLEAN partition or drive.....
System builder media replacement Vista General
RE: Replacing System Builder software? Vista General
OEM Builder Pack and Dual Boot Vista General
OEM system builder pack? Vista General
64 Bit System Builder key on 32 Bit? Vista General
