| | Microphone works in Sound Recorder, but not in Speech Recognition I have installed my mic, and it registers on the device selection screen, and in Sound Recorder, and in Ventrilo, but when I try to configure my Speech Recognition, it gets to the page where I am supposed to read the sentence aloud, and the bar doesn't move at all when I talk. Is this a problem with the speech recognition software, or what? |
| | Re: Microphone works in Sound Recorder, but not in Speech Recognition Depends what microphone you are using. I have the same problem. If i use my webcam microphone i get the message, as you do, 'speech recgonition cannot hear anything' A desktop mic does the same, but a headset mic works - well at least for me. having said that, make sure the coirrect mictophone is elected as default in the sound options (recording) you might also try putting a check mark in the 'alternate microphone' option on the custom tab just to see if that helps. I did bug this problem during the beta test of Vista, with particular reference to my logitech webcam microphone. The bug report reply from Microsoft was 'won't fix' so i don't bother with speech recognition now. It's another useless addition to Vista! -- John Barnett MVP Associate Expert Windows - Shell/User Web: http://xphelpandsupport.mvps.org Web: http://vistasupport.mvps.org The information in this mail/post is supplied "as is". No warranty of any kind, either expressed or implied, is made in relation to the accuracy, reliability or content of this mail/post. The Author shall not be liable for any direct, indirect, incidental or consequential damages arising out of the use of, or inability to use, information or opinions expressed in this mail/post.. "ZRustin" <ZRustin@discussions.microsoft.com> wrote in message news:8B03F9F5-443D-456E-9490-E7B32FFCE427@microsoft.com... >I have installed my mic, and it registers on the device selection screen, >and > in Sound Recorder, and in Ventrilo, but when I try to configure my Speech > Recognition, it gets to the page where I am supposed to read the sentence > aloud, and the bar doesn't move at all when I talk. Is this a problem with > the speech recognition software, or what? |
| | Re: Microphone works in Sound Recorder, but not in Speech Recognition Disappointing to hear ![]() John Barnett MVP wrote: > I did bug this problem during the beta test of Vista, with particular > reference to my logitech webcam microphone. The bug report reply from > Microsoft was 'won't fix' so i don't bother with speech recognition now. > It's another useless addition to Vista! > |
| | Re: Microphone works in Sound Recorder, but not in Speech Recognition Yes i agree it is disappointing to hear but then a lot of problems that occurred in the Vista beta have been labelled 'will not fix'. One particular one, in my case, is re-connecting to the internet after sleep or hibernation. I use a speedtouch 330 DSL modem and no way will it connect to the internet after i sleep the computer or hibernate it. Instead i have to forget sleep and hibernation mode and simply close down and reboot. Once again, half a dozen bug reports through every later build of the beta version of Vista bought back the same reply 'won't fix' and true to their word, they haven't fixed it. On that basis, sleep and hibernation are an untter waste of time and effort on my pc. The only sane option is to close down completely! -- John Barnett MVP Associate Expert Windows - Shell/User Web: http://xphelpandsupport.mvps.org Web: http://vistasupport.mvps.org The information in this mail/post is supplied "as is". No warranty of any kind, either expressed or implied, is made in relation to the accuracy, reliability or content of this mail/post. The Author shall not be liable for any direct, indirect, incidental or consequential damages arising out of the use of, or inability to use, information or opinions expressed in this mail/post.. "Daze N. Knights" <Daze@Microdot.dot> wrote in message news:eCrGgAgeHHA.3960@TK2MSFTNGP02.phx.gbl... > Disappointing to hear ![]() > > John Barnett MVP wrote: > >> I did bug this problem during the beta test of Vista, with particular >> reference to my logitech webcam microphone. The bug report reply from >> Microsoft was 'won't fix' so i don't bother with speech recognition now. >> It's another useless addition to Vista! >> |
| | Re: Microphone works in Sound Recorder, but not in Speech Recognition Sounds almost like "criminal neglect" might be a more apt description Daze -------- John Barnett MVP wrote: > Yes i agree it is disappointing to hear but then a lot of problems that > occurred in the Vista beta have been labelled 'will not fix'. One > particular one, in my case, is re-connecting to the internet after sleep > or hibernation. I use a speedtouch 330 DSL modem and no way will it > connect to the internet after i sleep the computer or hibernate it. > Instead i have to forget sleep and hibernation mode and simply close > down and reboot. Once again, half a dozen bug reports through every > later build of the beta version of Vista bought back the same reply > 'won't fix' and true to their word, they haven't fixed it. On that > basis, sleep and hibernation are an untter waste of time and effort on > my pc. The only sane option is to close down completely! > |
| | #6 (permalink) |
| | Re: Microphone works in Sound Recorder, but not in Speech Recognition I don't think Microsoft will agree with that assumption, Daze -- John Barnett MVP Associate Expert Windows - Shell/User Web: http://xphelpandsupport.mvps.org Web: http://vistasupport.mvps.org The information in this mail/post is supplied "as is". No warranty of any kind, either expressed or implied, is made in relation to the accuracy, reliability or content of this mail/post. The Author shall not be liable for any direct, indirect, incidental or consequential damages arising out of the use of, or inability to use, information or opinions expressed in this mail/post.. "Daze N. Knights" <Daze@Microdot.dot> wrote in message news:ON$RYIkeHHA.3884@TK2MSFTNGP04.phx.gbl... > Sounds almost like "criminal neglect" might be a more apt description > > Daze > -------- > > John Barnett MVP wrote: >> Yes i agree it is disappointing to hear but then a lot of problems that >> occurred in the Vista beta have been labelled 'will not fix'. One >> particular one, in my case, is re-connecting to the internet after sleep >> or hibernation. I use a speedtouch 330 DSL modem and no way will it >> connect to the internet after i sleep the computer or hibernate it. >> Instead i have to forget sleep and hibernation mode and simply close down >> and reboot. Once again, half a dozen bug reports through every later >> build of the beta version of Vista bought back the same reply 'won't fix' >> and true to their word, they haven't fixed it. On that basis, sleep and >> hibernation are an untter waste of time and effort on my pc. The only >> sane option is to close down completely! >> |
| | #7 (permalink) |
| | Re: Microphone works in Sound Recorder, but not in Speech Recognition No, probably not ![]() John Barnett MVP wrote: > I don't think Microsoft will agree with that assumption, Daze > |
| Speech Recognition-cannot begin to adjust microphone | Vista General | |||
| Sound recorder doesn't work with microphone in Vista | Vista General | |||
| Sound Recorder USB Microphone Distortion | Vista General | |||
| Speech recognition - digital recorder compatibility | Vista General | |||
| Microphone Button in Speech Recognition | Vista General | |||
