Vista - Help restoring missing recycle bin
Old 04-08-2007   #1 (permalink)
Paddle2day
Not sure how but my recycle bin dissappeared on my VISTA HOME PREMIUM
desktop. I made a short cut but have not figured out how to restore the
original to the desktop. I saw a regard on here thanking someone for the
answer but could not fond the answer. I would greatly appreciate any help
offered. Thank You in advance
Randy
Old 04-08-2007   #2 (permalink)
Rock
Re: Help restoring missing recycle bin
Common problem with a simple solution. Right click a blank area of the
Desktop | Personalize | Change desktop icons (left pane) | Put a tic in
Recycle Bin.
This occurred most likely because when right clicking on it to empty the
recycle bin you chose Delete instead of Empty Recycle bin.
Note Vista's Help and Support is quite good. Start | Help and Support |
Search on recycle bin. The first item in the list tells you how to do it.
Rock [MS-MVP User/Shell]
Old 04-08-2007   #3 (permalink)
Carey Frisch [MVP]
1. Click on Vista's blue Start button and then click on "Help and Support".
2. Type RECYCLE BIN in the Search box, press the Enter key.
3. Click on "Show or hide the Recycle Bin".
4. Follow the self-help instructions.
Carey Frisch
Microsoft MVP
Windows - Shell/User
Randy
Old 04-08-2007   #4 (permalink)
Paddle2day
Thank You Rock and Carey, your advise easily fixed my problem and I learned
something as well.
Randy
Old 04-08-2007   #5 (permalink)
Rock
> learned something as well.
> Randy
You're welcome Randy, glad I could help.
Old 04-09-2007   #6 (permalink)
Ramesh, MS-MVP
Right-click on the Desktop, click Personalize, and in the left pane, click Change desktop icons. In the Desktop Icon Settings dialog, enable the Recycle Bin checkbox. Click OK. See also:
How to restore the Recycle bin icon that has been accidentally deleted:
http://www.winhelponline.com/articles/141/1/
How to hide the "Delete" command from Recycle Bin context menu in Windows Vista:
http://www.winhelponline.com/articles/142/1/
Regards,
Ramesh Srinivasan, Microsoft MVP [Windows Shell/User]
Windows® Troubleshooting http://www.winhelponline.com
"Paddle2day" <NoThanks@NoSpam> wrote in message news:CBE2D4DE-0641-476A-9D6C-DD1153663EF0@microsoft.com...
Randy
Old 04-28-2007   #7 (permalink)
Sarah Martin
Missing Recycle Bin on Vista
Right click on your desktop. Choose Personalize. At top left hand side of screen there will be a spot to choose "change desktop icons". When this window comes up - check the box next to the recycling bin. It should then show up again. If it continues to disappear as mine did - when it is on your desktop - right click on the recycling bin, make a shortcut to it and leave it on your desktop. The shortcut will not dissapear when the original icon does.
EggHeadCafe.com - .NET Developer Portal of Choice
http://www.eggheadcafe.com
restoring (some) recycle bin icons in system32 imagesres.dll General Discussion
Renaming and copying files in recycle bin before restoring Vista General
restoring file from emptied recycle bin Vista General
fully restoring recycle bin icon Vista General
Restoring Folder in Recycle Bin & Renaming Folders Vista General
