| | NO Help If I Press F1 or Help (menu) View Help I get an error message stating: "Internet Explorer cannot download / from windows." If I try Help and Support from the Start Button I get an error message stating: "Internet Explorer cannot download / from help." Either/Both are followed with: "Internet Explorer was not able to open this internet site. The requested site is either unavailable or cannot be found. Please try again later." Any help in solving this will be appreciated. An aside - Why do I need a "site" to get help? What If I want to use Vista, and get help, sans an internet connection? |
| | Re: NO Help Try the fix offered at this site: Fix Windows Vista Help and Support http://www.windows-now.com/blogs/kmk...d-support.aspx It re-associates the .xml file type to its default settings. A recent installation of a program may have "stolen" the .xml association. Under Options > Settings... for Help and Support (on the upper right side of the H & S window), you can choose not to get content from the internet, but the .xml association would still need to be repaired. "Bill Lewis" <bwlII@msm.con> wrote in message news:uywsQAmeHHA.4916@TK2MSFTNGP06.phx.gbl... > If I Press F1 or Help (menu) View Help I get an error message stating: > > "Internet Explorer cannot download / from windows." > > If I try Help and Support from the Start Button I get an error message > stating: > > "Internet Explorer cannot download / from help." > > Either/Both are followed with: > > "Internet Explorer was not able to open this internet site. The requested > site is either unavailable or cannot be found. Please try again later." > > Any help in solving this will be appreciated. > > An aside - Why do I need a "site" to get help? What If I want to use > Vista, and get help, sans an internet connection? |
| | Re: NO Help Thank you - Kind Sir. "dean-dean" <dean-dean@discussions.microsoft.com> wrote in message news:ehXbiLmeHHA.4596@TK2MSFTNGP05.phx.gbl... > Try the fix offered at this site: > > Fix Windows Vista Help and Support > http://www.windows-now.com/blogs/kmk...d-support.aspx > > It re-associates the .xml file type to its default settings. A recent > installation of a program may have "stolen" the .xml association. > > Under Options > Settings... for Help and Support (on the upper right side > of the H & S window), you can choose not to get content from the > internet, but the .xml association would still need to be repaired. > > > "Bill Lewis" <bwlII@msm.con> wrote in message > news:uywsQAmeHHA.4916@TK2MSFTNGP06.phx.gbl... >> If I Press F1 or Help (menu) View Help I get an error message stating: >> >> "Internet Explorer cannot download / from windows." >> >> If I try Help and Support from the Start Button I get an error message >> stating: >> >> "Internet Explorer cannot download / from help." >> >> Either/Both are followed with: >> >> "Internet Explorer was not able to open this internet site. The >> requested site is either unavailable or cannot be found. Please try >> again later." >> >> Any help in solving this will be appreciated. >> >> An aside - Why do I need a "site" to get help? What If I want to use >> Vista, and get help, sans an internet connection? > |
| | Re: NO Help The first time you go to use Help you will be asked if you also want to go online to get the very latest help from the internet. This is a good thing, in my opinion, as with this new O/S the help files are liable to changes. If you say yes to this question, Help will always try to go online to update the help files. If you subsequently do not have an internet connection, you will be told so. I believe this is what you are seeing. You can disable this from happening from within the options | settings in the Help window. Just remove the check to "Include Windows Online Help". -- Regards, Richard Urban MVP Microsoft Windows Shell/User "Bill Lewis" <bwlII@msm.con> wrote in message news:uywsQAmeHHA.4916@TK2MSFTNGP06.phx.gbl... > If I Press F1 or Help (menu) View Help I get an error message stating: > > "Internet Explorer cannot download / from windows." > > If I try Help and Support from the Start Button I get an error message > stating: > > "Internet Explorer cannot download / from help." > > Either/Both are followed with: > > "Internet Explorer was not able to open this internet site. The requested > site is either unavailable or cannot be found. Please try again later." > > Any help in solving this will be appreciated. > > An aside - Why do I need a "site" to get help? What If I want to use > Vista, and get help, sans an internet connection? |
