Vista Tutorial - "This device does not allow its write cache setting to be modified"
Old 04-09-2007   #1 (permalink)
R. J. Salvi
Guest
When trying to enable write caching in the HD disk properties of Device
Manager, the aforementioned (subject) line appears just below the tick box
to enable it. However, the following registry entry is set to "1":
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\IDE\DiskWDC_WD1500ADFD-00NLR1___________________20.07P20\4&35cc0339&0&0.0.0\Device
Parameters\Disk\UserWriteCacheSetting
The HD is set up as an AHCI volume on an Intel ICH7R controller (Intel's
Matrix Storage Console software installed) and the OS is Vista Business x86.
Is there something I'm missing, or is it because the drive is an AHCI
volume, as opposed to and IDE one, that I cannot enable it? Thanks.
RJ
In Outlook Express, how can I define the "columns" other than the "InBox" setting Live Mail
"Date Modified" Column Header Disappears Vista General
How to insert the "modified time" attribute in "date taken" attribute in batch mode-in vista or theough a software? Vista file management
How to insert the "modified time" attribute in "date taken" attrib Vista music pictures video
When listing XP files the "Date modified" could be in the future Vista file management
