Right-Click EDIT menu. How to change it?
  1.    09 Apr 2007 #1
    Paul Guest
    How do I change paint.exe from opening each time I click EDIT from the
    Windows Explorer right-click menu?
  2.    09 Apr 2007 #2
    Andre Da Costa[ActiveWin] Guest
    Re: Right-Click EDIT menu. How to change it?
    Right click > Open With > Choose Default Program. See the application you
    want to use, and click OK. "Always use the selected program to open this
    kind of file" should already be preselected. If you don't see the
    application you want to use, click Browse to find the appropriate program.
    Andre
    Blog: http://adacosta.spaces.live.com
    My Vista Quickstart Guide:
    http://adacosta.spaces.live.com/blog...3DB!9709.entry
    "Paul" <Paul@discussions.microsoft.com> wrote in message
    news:66DBE552-5591-48B1-9F77-2708E56FC840@microsoft.com...
  3.    09 Apr 2007 #3
    Paul Guest
    I have done that.
    I have it set to open jpg and gif files with Windows Gallery.
    It does that OK but when I click EDIT it opens paint.exe and I want to use
    fireworks.
    > Andre
  4.    09 Apr 2007 #4
    Paul Guest
    Ok. Currently that shows "%systemroot%\system32\mspaint.exe" "%1"
    How do i chnage it to open fireworks.exe which is in c:\program
    files\macromedia\fireworks 8\fireworks.exe
    "." wrote:
    > Verb editing was removed from Vista.
    > You have to dit here in the registry
    > HKEY_CLASSES_ROOT\Paint.Picture\shell\edit\command
    > news:677D71BD-1548-431F-9C72-FD39883D9DF1@microsoft.com...
    > >I have done that.
    > > fireworks.
    > >> program.
    > >> Andre
  5.    09 Apr 2007 #5
    Guest
    "c:\program files\macromedia\fireworks 8\fireworks.exe" "%1"
    %1 gets replaced with the file you click.
    news:98D44440-EB07-4A61-B8AC-4CC7075D182C@microsoft.com...
    >> >I have done that.
    >> > use
    >> > fireworks.
    >> >> you
    >> >> this
    >> >> program.
    >> >> Andre
    >> >> > the
  6.    09 Apr 2007 #6
    Paul Guest
    just tried that and re-booted but still paint opens all graphic files.
    > >> >I have done that.
    > >> > use
    > >> > fireworks.
    > >> >> you
    > >> >> this
    > >> >> program.
    > >> >> Andre
    > >> >> > the
  7.    09 Apr 2007 #7
    Guest
    It default value should be Paint.Picture
  8.    09 Apr 2007 #8
    Paul Guest
    Basically, all I want to do is edit jpg, png and gif in fireworks. At the
    moment they edit in Paint by default if i right click and select EDIT.
    When i just click on them i want then to open in windows gallery which they
    do now.
  9.    09 Apr 2007 #9
    Guest
    Change it to paint.picture
    news:3CBFE421-DC25-408F-9CB9-85F5CEBBFF30@microsoft.com...
    > they
    > do now.
  10.    09 Apr 2007 #10
    Paul Guest
    Sorry. Paint is still the default editor for bmp, jpg, png.
    > > they
    > > do now.
Page 1 of 3 123 LastLast
Right click menu (Context menu) sometimes invisible!
Hello, I have this rather annoying problem in Vista 32bit SP2. Sometimes my right click menu (Context menu) is invisible. I do see the...
General Discussion
Can I change the Default Edit Program in Pictures Context Menu?
This is the Context Menu that I'm referring to, accessed by Start>Pictures>, Right-click on Thumbnail. 18115 With my current settings , if I...
General Discussion
Edit right click menu.
1)How to add programs to the right click menu? 2)How to remove programs from the right click menu?
General Discussion
Edit Start Menu
In order to clean up the start menu, I would like to move all the "Windows..." applets to a "Windows" folder (15 of them). Whenever I try to open...
Vista General
How do I change double click from SEARCH to OPEN on drop down menu
How do I change double click from SEARCH to OPEN on drop down menu? I'm used to clicking on a file and having it open that file. Now when I double...
Vista file management
How do I change the mouse click to just one click
I would love to be able to just use one mouse click to execute a program, I can't figure it out.....Peter
Vista General
hot to change mouse to single click instead of double click to ope
how can I change from double clicking to single click. In XP you can go to folder options and make the change, here I can't find that option in...
Vista hardware & devices
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
