Vista - DiskProbe Functionality for Vista. (Urgent Help Required)
Old 04-11-2007   #1 (permalink)
developer28
Can anyone let me know if there is some version of DiskProbe that
works for Vista as well.
Or even if there is some other tool that works on vista and has the
same functionality as diskprobe or as diskedit by symantec.
I want to edit the hard disk on Vista.
Waiting for a reply.
Thanks for any help.
Regards,
Aman.
Old 04-11-2007   #2 (permalink)
Jon
Re: DiskProbe Functionality for Vista. (Urgent Help Required)
"developer28" <aman.k.sethi@gmail.com> wrote in message
news:1176271709.697734.210130@n76g2000hsh.googlegroups.com...
> Hi,
> Regards,
> Aman.
DskProbe seems to half work here, if you run it elevated. Works opening up a
'Physical Drive', but not a 'Logical Volume'.
Jon
BSoD Urgent Help Required - PLEASE General Discussion
URGENT HELP REQUIRED!!! How to re-install vista without the cd. Vista performance & maintenance
WinHlp32 Urgent help required Vista installation & setup
WIN key and poor functionality of Vista Vista General
Vista Search functionality Vista file management
